How to add fields to customize reports in BCM?
N
nre503
I am a Realtor, and my contacts' mailing address is their home address.
However, when i run a report, only the business address is on the report.
The home address/mailing address is not an option when I try to modify the
report.
I need the addresses because i am importing this lint to Excel to send to my
printer for mailers. If there is another way, please share.
P
Poohbear
I am not to sure if this will help. You have additional user-defined field at
the bottom of the page either on accounts or business contacts.
You may want to chose either accounts or business contacts; once you have
decided which contact you want to implement the new added fields. Go to
Business contact manager tab, chose custom forms-manage user-defined
fields-chose either, accounts or business contacts (for your additional form)
dialog box opens, under general tab- you can add your group (business or home
address) and create a field to make an additional address field. Try to run
your modify report to see which address populates for your report.
This may help... It seems like a lot of work but the results are beautiful...
> report.
> Thanks.
TonyaG
Can you use the user defined fields if you wanted to further categorize your
clients? For example, if I wanted to print up a report of all of the
architects that I have in my database, could I use the user defined fields in
the accounts somehow to do that?
We have a database and in it are all of our accounts including all different
types of vendors, contractors, designers etc. I want to figure out a way to
categorize each client so that if i wanted to, I could print up a report
containing all contractors or engineers. Does that make sense? It sounds
like you'd be able to do the same thing but i"m new to the program.
any thoughts you have woudl be appreciated - thanks!
TNG
> > report.
> > Thanks.
Abbey Lehman
I am using BCM 2010 & I am having this issue. I export contact data to Excel for various things and this particular project requires the contact's mailing address. The address info will only show in the report if it is the business address--how can I see the *mailing* address, regardless of which type it is?
I am using BCM on a networked PC, but only 3 computers actually access the database. There is a server in the office. but it only provides access to the computer the database lives on, which is just another PC in the office, not the server. I am the owner of the database, but I typically log in as various users for sending emails (for other people), etc., since the owner account does not have an email address, and the emails have to show as coming from specific people. I do NOT know how to customize forms, except through the BCM dragging & dropping--SQL stuff makes my head spin. Also I am not physically near the network--I am in Ohio and it is in Arizona.
Is there an easy way to do this, or do I need to involve the difficult-to-reach outside IT guy who maintains the server?
Thanks!!
Abbey
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge New Slipstick.com Articles 0
Diane Poremsky Add attachments and set email fields during a mail merge to email New Slipstick.com Articles 0
M Predefined Outlook Fields not available to add into a BCM record BCM (Business Contact Manager) 0
B Would like to add more fields in the Genral contacts tab Using Outlook 1
A ability to add comments to frequently used fields of a contact Outlook Wishlist 0
L How do I add fields to Contact Manager Outlook VBA and Custom Forms 7
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
B Task Filter Not Working When I add too many criteria Using Outlook 0
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
