Re: Convert Oportunity to Project?
AMAZINO
And here we are in April 2009!
Any update on this subject?
I tried to joinn the BCM blob on http://blogs.msdn.com/bcm but did not manage.
Andrew
"themurf" wrote:
> I started this very basic concept in February of 2007 and here we are in July
> of 2008 and still no update to allow this to happen. Too bad as this is the
> one feature that makes BCM not really work. I tried for several years to make
> OA and BCM work but the disconnect is too great. I have become convinced that
> the MS design staff does not have real world job experience in the field
> where the product they are developing will be used. Do you think this very
> basic functionality failure will even be addressed? Jim
> "Mukesh Agarwal [MSFT]" wrote:
> > Current version of BCM doesn't allow converting a opp into the project. We
> > have gotten this feature request and added to list of things we are planning
> > to do for next version.
> > Thanks for your feedback.
> > Visit team blog at http://blogs.msdn.com/bcm
> > This posting is provided "AS IS" with no warranties, and confers no rights
> > "Ed Marmon" <unlisted@.com.com> wrote in message
> > news:Xns98E4F1341637Aedmarmailcom@207.46.248.16...
> > > Is there not an answer to this? Ive created many new opportunities, and
> > > they are precipitating many project tasks now, and I'm not sure how to
> > > convert an oppty into a project either. How do these two work together?
> > > > =?Utf-8?B?dGhlbXVyZg==?= <themurf> wrote in
> > > news:4D01A297-E3FE-4012-BD45-E998559BDE2E@microsoft.com:
> > > >> I have been looking for a way to convert an Oportunity into a project.
> > >> Any Oportunity I might close will become a project. All of the
> > >> tracking emails and other documents need to be associated then with
> > >> the project. It seems to me there swhould be a way to make a simle
> > >> conversion from one BCM type to another. Does anyone know how I might
> > >> do this? If not I suggest that that feature be incorporated. Thanks,
> > >> Jim
booster
I am looking for a answer to see if this was ever solved? now 2010 and still
no feedback???? guess the IT dollars go towards a different program that will
link...
> Andrew
> > > >> Jim
rondragon
I was originally using Thunderbird for my email which I was happy with.
However I needed a CRM system which brought together my emails, calendar and
task so I started to use BCM with Outlook 2007. I found Outlook much more
cumbersome to use that Thunderbird and spent ages sorting out the email
signature. Now I've started to use BCM and find that an opportunity cannot be
converted to a business project which renders the whole Outlook / BCM
software useless to me. As mentioned many times before, a lot of work can go
into the formulation of a quote, and then if you win the quote then the
'project' starts. However all the information used in the quotation (the
Opportunity) forms the basis of the project or in my case sometimes, almost
the whole of the project.
I assume this massive lack of functionality has not been addressed even
though it is a number of YEARS since this thread began... lame Microsoft..
why did I even bother?
L
Leonid S. Knyshov // SBS Expert
I will look into feasibility of creating an add-on to convert
opportunity to project. It will not be free, but I am certain it's
possible. :)
Thank you for the idea.
Leonid S. Knyshov
Try Exchange Online http://bit.ly/free-exchange-trial
K Need to convert .mmf file to .pst format Outlook VBA and Custom Forms 4
M Convert Subject Line to Internet Header version of Subject Outlook VBA and Custom Forms 10
P How do I convert outlook “to-do” items to “tasks” Outlook VBA and Custom Forms 1
C convert an .ost to .pst Using Outlook 3
D The way to convert ost to pst Using Outlook 2
sneaky30 convert text to date Outlook VBA and Custom Forms 1
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) New Slipstick.com Articles 0
S How to do I convert OST file to PST? Exchange Server Administration 3
J convert .pst to .eml, how is it possible? Using Outlook 1
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
V Check/convert to emailaddresses Outlook VBA and Custom Forms 11
R Convert Access table to pst Using Outlook 1
L Convert Distribution List of Contacts to Single Contacts Using Outlook 6
G Is there any way to convert outlook 2003 to outlook 2007 Using Outlook 5
D Outlook contacts no in address book - 2002 pst file convert to 2007 pst file? Using Outlook 0
A Outlook 2003: convert all RTF emails to HTML Outlook VBA and Custom Forms 1
J How to convert BCM contacts to normal Outlook contacts BUT... BCM (Business Contact Manager) 2
G Tasks - convert email to task & attach email Outlook VBA and Custom Forms 6
B convert VBA code to Add-in Outlook VBA and Custom Forms 1
Q How tough is it to convert VBA to Addin Outlook VBA and Custom Forms 1
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
Diane Poremsky Project and Business Process Management Tools New Slipstick.com Articles 0
T link multiple emails to one project in one way BCM (Business Contact Manager) 1
P Autopopulate Email Subject from Project BCM (Business Contact Manager) 6
C Project Management and Communication History BCM (Business Contact Manager) 2
P Simple contact and project manger like MissingLink for Outlook Using Outlook 1
wallisellener Marketing and Project Management field are not displaying BCM (Business Contact Manager) 2
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
T sequential project numbers in Business Contact Manager BCM (Business Contact Manager) 2
M How do I get the version number of the Setup project? Outlook VBA and Custom Forms 1
E trust access to visual basic project greyed out in outlook 2003 Outlook VBA and Custom Forms 1
S O2K vbe error message "Can't find project or library"? Outlook VBA and Custom Forms 3
C All my projects and project tasks are gone - OL BCM 2007 BCM (Business Contact Manager) 2
M Best way to distribute VBA project Outlook VBA and Custom Forms 4
J No setup project with Outlook 2007 Add-In project Outlook VBA and Custom Forms 16
M Adding another add-in to a project Outlook VBA and Custom Forms 1
J Can I link a single project to multiple accounts / business contac BCM (Business Contact Manager) 1
