How does BCM links items
E
Evelyn
- A linked email from Inbox to BCM-contact/account is a copy of the original
email.
- When the Inbox-email will be deleted, the copy of this item remains with
contact/account it was linked to.
- When I remove the item from contact/account the email stays in the Inbox,
but the link (copy of the item) moves into the deleted folder.
Is this correct, how BCM works?
L
Luther Blissett
> email.
Nope. BCM does copy some fields from the email into its database, but
essentially it just links the BCM contact/account to the Outlook
email. If you delete the Outlook email, then BCM will open a form with
the fields it copied from the original email.
Removing a link between an email and a bcm contact, simply removes the
link and does not touch the email.
Note that when you delete an item in Outlook, it simply moves the item
to the Deleted Items folder, and BCM can still open it.
J What exactly does the BCM Database tool actually do? BCM (Business Contact Manager) 3
A BCM does not start correctly BCM (Business Contact Manager) 10
T Office2013 and BCM on Windows 8.1 -- install of BCM does not work? BCM (Business Contact Manager) 2
E BCM Search does not show results BCM (Business Contact Manager) 1
D Why does BCM not always load when I restart Outlook? BCM (Business Contact Manager) 1
D Does BCM integrate with Navision Dynamics 5.0 or greater? BCM (Business Contact Manager) 1
J WINDOWS EASY TRANSFER does not allow for BCM BCM (Business Contact Manager) 1
D Win7 x64 - Outlook 2010Beta x64 - BCM 2010 x64 does not install BCM (Business Contact Manager) 1
S BCM does not load in Windows 7 BCM (Business Contact Manager) 1
J Where does BCM store User-Defined fields in the database? BCM (Business Contact Manager) 3
L Does this really work and get thru virus and malware blocks? Using Outlook 3
N Free/busy publish at http location does not work Using Outlook 1
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
Mark Foley Time span on WebDAV published Calendars does not appear to be working Using Outlook 7
snhnic Macro that does not overwrite but add a number Outlook VBA and Custom Forms 1
Rupert Dragwater Deleting email from Deleted Items does not work Using Outlook 0
G Outlook does not show new appointments in To-Do-Bar Using Outlook 0
G Calendar does not point to deafult data file Using Outlook 0
Diane Poremsky What does the "J" mean? New Slipstick.com Articles 0
