Is it possible to use BCM 2003 with Outlook 2007?
K
KMM
I had Outlook 2003 with BCM and recently upgraded to Outlook 2007, but it
does not have Business Contact Manager. Is it possible to install just BCM
from my 2003 disk to use with Outlook 2007? When I try to it says I have to
install Outlook 2003 before it can install BCM.
DL
I think you answered your own Q
"When I try to it says I have to install Outlook 2003 before it can install
BCM"
"KMM" <KMM> wrote in message
news:CB577C5B-9F54-4867-8336-76BC21EFFE2F@microsoft.com...
> to
> Thanks
K
KMM
I'm hoping there is a way to tell BCM2003 that Outlook is installed, it's
just Outlook 2007 instead of 2003.
> BCM"
> > to
> > Thanks
Cathy Rhone
Outlook 2013 32 bit
Exchange Server 2010
No. You need to have the same version of Outlook and BCM.
Cathy Rhone
Outlook 2013 32 bit
No, you can't. Use BCM 2007 instead.
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
K Is it possible to sync IPhone to BCM Outlook contact, calendars ... all data? BCM (Business Contact Manager) 16
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
S Is it possible to cusstomise selectable Options in Kalander. Outlook VBA and Custom Forms 1
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
J Is this possible to do with a macro? Outlook VBA and Custom Forms 17
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
H Is it possible to create a view that only show the first task in a list? Using Outlook 1
H Is It Possible to See Who Has Viewed My Calendar in Exchange? Using Outlook 2
C in outlook 2007-Contact Group-One name have 3 mail id-its possible? Using Outlook 3
J convert .pst to .eml, how is it possible? Using Outlook 1
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
M Is it possible to restore deleted webmail to server? Using Outlook 3
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
D is it possible to have both a POP and IMAP account in Outlook 2013? Using Outlook 5
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Possible to link to ics file without importing? Using Outlook 4
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
B Is it possible with Outlook form Outlook VBA and Custom Forms 5
Steve Jacobs Possible to configure TNEF options based on *sender*? Exchange Server Administration 3
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
E Show field from account on contact form - possible? BCM (Business Contact Manager) 1
A Possible to modify people preview window? Using Outlook 1
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
C Is it possible: List of URL fields BCM (Business Contact Manager) 0
D Frequently used response short cut possible macro Using Outlook 1
Commodore Exporting all contacts to VCF files possible? Using Outlook 4
M I'd like to alter the appointment balloons. Possible? Calendar Printing Assistant 6
J Is it possible to highlight a folder in Outlook 2007? Using Outlook 2
L I want ONE calendar if possible with no overlaying Using Outlook 1
S possible to access my PST file on the Internet Using Outlook 2
N Outlook Rules - is this possible? Using Outlook 3
G Possible to create reports that return contacts based on account criteria? BCM (Business Contact Manager) 0
N Citrix installation possible? BCM (Business Contact Manager) 1
T Is it possible to hide a mailbox but still send on the behalf of. Exchange Server Administration 1
D Is it possible to set up an email rule for a user based on alias address? Exchange Server Administration 3
