Outlook 2007 BCM SQL server problem
DNC
When I launch Outlook 2007 I am suddenly recieving the following message:
Cannot connect to the local SQL server service (the Business Contact Manager
database service) is not running. You can connect to a BCM that is stored on
a different computer. For more information on starting the SQL service click
help.
When I cllick help the create or select a BCM database screen appears with
my computer name and no database name. Then a message appears that it cannot
access the database on my computer.
If I go to the SQL Configuration manager the server has a red light and it's
state is stopped. If I tried to start it the error message says: The request
failed or the service did not respond in a timely fashion. Consult the event
log or other applicatable error logs for details.
I have tried loging in as administrator and any other way that I can think
of. The database is definately on this computer. I am running Vista and think
this started right after a windows update.
Any help will be appreciated,
DNC
L
Luther Blissett
> database service) is not running. You can connect to a BCM that is storedon
> help.
> DNC
It's possible that the Windows Update changed some permissions that
prevent Sql from accessing some resource.
I think this has been discussed in tha past, so you could try
searching this newsgroup.
Or search the sql and windows event logs for details on why BCM's sql
service won't start.
M Adding BCM to Outlook 2007 BCM (Business Contact Manager) 1
F Outlook 2007 BCM Exporting Files BCM (Business Contact Manager) 2
L How do you Recover from An Outlook 2007 & BCM Crash BCM (Business Contact Manager) 1
A Add BCM to outlook 2007 BCM (Business Contact Manager) 1
C Error when installing BCM for outlook 2007 from disk 2 BCM (Business Contact Manager) 3
B Outlook 2007 BCM will not recognize data files BCM (Business Contact Manager) 1
J BCM 2007 Shutting Down Outlook BCM (Business Contact Manager) 2
P Windows 7 / Outlook BCM 2007 Stability BCM (Business Contact Manager) 1
N Outlook 2007 w/BCM - Email issues BCM (Business Contact Manager) 5
N Email issues since installing BCM with Outlook 2007 BCM (Business Contact Manager) 1
M Outlook 2007 with BCM - Tasks being created automatically BCM (Business Contact Manager) 1
D Outlook 2007 BCM - Win 7 BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
A Outlook 2007 ca+n't find bcm BCM (Business Contact Manager) 1
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
H How to get BCM in OUtlook 2007 on Vista to detect my MDF file? BCM (Business Contact Manager) 1
D Outlook 2007 + BCM & SP2 - windows7 ? BCM (Business Contact Manager) 6
K Is it possible to use BCM 2003 with Outlook 2007? BCM (Business Contact Manager) 4
R BCM 2007 no longer showing up within Outlook 2007 BCM (Business Contact Manager) 3
P Outlook 2007 with BCM - Out of Memory BCM (Business Contact Manager) 13
M Outlook 2007 crashes with BCM BCM (Business Contact Manager) 1
K Moving data from Outlook 2007 to Outlook 2007 with BCM BCM (Business Contact Manager) 3
B BCM freezes Outlook 2007 BCM (Business Contact Manager) 3
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
L Outloook 2007 Ultimate BCM and Outlook Contacts? BCM (Business Contact Manager) 6
