Trying to start Outlook from VBA or VBS not working.
Trefor
I have the following code in a VBS, but Outlook is not starting. Am I missing
something?
Dim ObjOL
Set ObjOL= GetObject("Outlook.Application")
If Err <> 0 then
Err.Clear
Set ObjOL= CreateObject("Outlook.Application")
I have also tried similar code from VBA and this does not work either and
there are no errors in VBA to give me a clue.
Trefor
K
Ken Slovak - [MVP - Outlook]
Do you have any On Error Resume Next statements in your code? I'm surprised
that you did not get some error message if you don't, usually something like
a 429 error (ActiveX cannot create object). Usually this is due to lack of
permissions or some script stopper running. Many A-V products such as Norton
or McAfee have script stoppers like that. If this is due to McAfee then you
can tell it to trust your code, go their support site to find out how. If
it's Norton then you're out of luck unless you disable the script stopper,
Norton doesn't care what you want to do.
"Trefor" <Trefor@home.com> wrote in message
news:D0051806-ACE2-4347-A130-23AF051053D6@microsoft.com...
> missing
> something?
> Dim ObjOL
> If Err <> 0 then
> Err.Clear
> End If
> > Trefor
Trefor
Ken,
Thanks for the reply. There is nothing wrong with the VBScript running
because other code is running fine.
I replaced: Set ObjOL= CreateObject("Outlook.Application")
with: WshShell.run "Outlook"
and of course:
Dim WshShell
Set WshShell=WScript.CreateObject("WScript.Shell")
and it works fine. Doesn't make sense to me, but it works so I'm happy ;)
Trefor
> >missing
> > something?
> > Dim ObjOL
> > If Err <> 0 then
> > Err.Clear
> > End If
> > > > Trefor
Trefor
Ken,
I found one of your posts re checking Send/Receive has completed using
Events. I seem to be having having the same issue using "synch.Start" as I
did using CreateObject to start Outlook i.e. it does nothing:
blnFinished = False
Set synch = olNS.SyncObjects.Item(1)
synch.Start
While blnFinished = False
DoEvents
Loop
This works fine for checking if it started ok though????
Set ObjOL= GetObject(, "Outlook.Application")
Trefor
"Trefor" wrote:
> Ken,
> and of course:
> Dim WshShell
> Thanks.
> > Trefor
> > >missing
> > > something?
> > > > Dim ObjOL
> > > If Err <> 0 then
> > > Err.Clear
> > > End If
> > > > > > > > Trefor
K
Does that synch.Start code have an event handler for the completion of the
synch that would set your blnFinished flag to True? If not that's a nice
endless loop you've set up.
The only reason I can think of for a failure for CreateObject() or New is
that there is some problem with the Outlook installation/registrations or
the aforementioned script stopper.
news:EF73F395-9789-48C4-A5D9-E2BFB9C3D0C5@microsoft.com...
> Ken,
> blnFinished = False
> synch.Start
> DoEvents
> Loop
> > Trefor
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
M outlook 365 trying to finish my sentences Using Outlook 0
O The page that you are trying to access cannot be loaded. Using Outlook 0
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
KURTiS MAXiMUS Trying to appactivate ERP window Outlook VBA and Custom Forms 16
R Trying to extract information between two symbols from outlook subject Using Outlook 2
Danie Lawson Trying to recover calendar Using Outlook 4
L Trying to open contacts pst. file in outlook 365 Using Outlook 3
L Trying to check for the absence of mail. Outlook VBA and Custom Forms 1
D Trying to repair Outlook rules Using Outlook 5
S Outlook 2010 trying to default Data file to outlook.com calendar Using Outlook 6
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R Trying to sync my Outlook email on iphone Using Outlook 1
A outlook trying to keep sending Using Outlook 1
P Trying to add subject and name to an email using VB Code Using Outlook 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
P Outlook works, but freezes when trying to use calender v2007 (vista prof) Using Outlook 1
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
P Trying to get 'Calendar Name' to appear like 'Subject' and 'Location' in event Calendar Printing Assistant 0
S Trying to have a prompt to ask for text to be added to subject before sending. Using Outlook 3
A Trying to connect to exchange Exchange Server Administration 3
K Wont send or recieve now with new server keeps asking for password when trying Using Outlook 1
D Outlook "Trying to Connect" Exchange Server Administration 1
P Word experienced and error trying to open the file Using Outlook 2
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
D Outlook 2003 - A program is trying to access e-mail addresses Outlook VBA and Custom Forms 5
S Trying to create a UPS from Outlook VBA and Custom Forms 2
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
A Error: 3033 when trying to OpenDatabase using DAO Outlook VBA and Custom Forms 3
U Recovered PST file "Cannot move item" error when trying to move e- Using Outlook 6
D Error trying to connect to database on the server BCM (Business Contact Manager) 1
D Trying to reconnect BCM databases in Outlook 2003 BCM (Business Contact Manager) 1
A End-time meeting reminder (or "negative" time relative to the meeting start time) Using Outlook 1
N Multiple instances of Outlook on Start Menu Using Outlook 2
P Automate Outlook Start - No Active Explorer Object Found Using Outlook 10
P Outlook 2016 won't Start Using Outlook 3
O Outlook 2016 crashes at start Using Outlook 14
S Calendar loops when clicking on calendar link to start it Using Outlook 1
