Trying to create a UPS from
Sir Cedric
Hello all, I have been trying to create a Form so that anyone in our company
can place all of their information into this form and send it to me so that I
can get their deliveries out on time, I have the form set up in Design mode,
but everytime that I try to publish this form, I keep getting (can not
publish the form because of a MAPI error) also, when I tary to run this form
it says(you can not change this field in this item, the property does not
exist, the field you want to modity is not valid for this type of item) can
anyone shine some light on this issue?
Sue Mosher [MVP]
You've described two separate problems, as far as I can tell. Regarding the
publishing issue, you should check with your Exchange administrator to make
sure you have the permissions necessary to publish a form to the
Organizational Forms library.
Regarding the property warning, what fields did you add to the form? Outlook
allows you to add fields from any type of item to any other type of item, but
they're not always functional or compatible.
Sir Cedric
Thank you very much Sue,
have a great and peaceful day/weekend!
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
M outlook 365 trying to finish my sentences Using Outlook 0
O The page that you are trying to access cannot be loaded. Using Outlook 0
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
T Outlook "A program is trying to access Outlook" Using Outlook 3
KURTiS MAXiMUS Trying to appactivate ERP window Outlook VBA and Custom Forms 16
R Trying to extract information between two symbols from outlook subject Using Outlook 2
Danie Lawson Trying to recover calendar Using Outlook 4
L Trying to open contacts pst. file in outlook 365 Using Outlook 3
L Trying to check for the absence of mail. Outlook VBA and Custom Forms 1
D Trying to repair Outlook rules Using Outlook 5
S Outlook 2010 trying to default Data file to outlook.com calendar Using Outlook 6
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R Trying to sync my Outlook email on iphone Using Outlook 1
A outlook trying to keep sending Using Outlook 1
P Trying to add subject and name to an email using VB Code Using Outlook 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
P Outlook works, but freezes when trying to use calender v2007 (vista prof) Using Outlook 1
K A program is trying to send an e-mail message on your behalf... Using Outlook 1
P Trying to get 'Calendar Name' to appear like 'Subject' and 'Location' in event Calendar Printing Assistant 0
S Trying to have a prompt to ask for text to be added to subject before sending. Using Outlook 3
A Trying to connect to exchange Exchange Server Administration 3
K Wont send or recieve now with new server keeps asking for password when trying Using Outlook 1
D Outlook "Trying to Connect" Exchange Server Administration 1
P Word experienced and error trying to open the file Using Outlook 2
S Trying to install BCM 2010 x64, getting error BCM (Business Contact Manager) 8
D Outlook 2003 - A program is trying to access e-mail addresses Outlook VBA and Custom Forms 5
T Trying to start Outlook from VBA or VBS not working. Outlook VBA and Custom Forms 4
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
A Error: 3033 when trying to OpenDatabase using DAO Outlook VBA and Custom Forms 3
U Recovered PST file "Cannot move item" error when trying to move e- Using Outlook 6
D Error trying to connect to database on the server BCM (Business Contact Manager) 1
D Trying to reconnect BCM databases in Outlook 2003 BCM (Business Contact Manager) 1
P Can I create a Rule that sends me an email when I get a Task? Using Outlook 3
C Can't create Outlook data file Outlook Wishlist 0
