importing contacts from excel
Julie
I'm having trouble importing contacts into Microsoft Outlook Business Contact
Manager 2007 from an Excel spreadsheet. I have two questions:
1. The mapping process appears to be very simple, but the fields that show
up in the left box that should represent the fields in my Excel spreadsheet
is incomplete so I am unable to map all the fields.
2. I've tried mapping the fields that are available and the wrong
information lands in the contact manager. For example, I very clearly drag
NAME from my spreadsheet over to full name in contact manager. For some
reason TITLE from my spread sheet lands in the name area. I've double
checked myself several times, and I appear to be mapping correctly, but it
just doesn't work right.
Any ideas?
Julie
K
Karl Timmermans
It's been a long time since working with BCM in terms of import/export but
believe the following is the same as standard Outlook and still holds true
for BCM. On that basis (and will gladly stand corrected if anyone determines
the following to be incorrect as applied to BCM)......
Re: #1 - Available fields
Whether BCM or standard Outlook, the fields that can be mapped are limited
to those listed within the Import/Export wizard. There is no facility to
import data to any custom/user-defined fields.
Re: #2 - FullName
The <FullName> field is a <derived> field that is actually the <sum of its
parts> which are <Title, FirstName, MiddleName, LastName, Suffix>. If you
simply import a <name> to the <Full Name> field, Outlook will attempt to
deciper what component parts are included in the name you are importing and
may or may not correctly make that determination. To ensure accurate info,
the component elements should be imported to the corresponding individual
Outlook names.
Karl
_____________
ContactGenie - Importer 1.3 / DataPorter 2.0 / Exporter
"Power contact importers/exporters for MS Outlook '2000/2007"
"Julie" <Julie> wrote in message
news:3435350B-A13A-46E4-B37D-C6485A9FFDCE@microsoft.com...
> Contact
> spreadsheet
> drag
> Any ideas?
> > Julie
Julie
Thank-you for writing back, Karl.
I think maybe BCM has changed since you last saw it. In the import wizard
there is a box on the left listing the fields in the file from which I am
importing. Then, there is a box on the right with fields BCM is set up with.
My data has the contact's full name in one cell. Since BCM has a fields set
up for first name, last name, and also one set up for full name, I have
mapped my full name to BCM's full name. For some reason TITLE from my data
falls into both the TITLE field and the FULL NAME field in BCM.
Also, BCM does have an option of mapping to a new field, but I probably
shouldn't use it for the name.
Is there an easy way in excel to split first and last names into two cells,
or do I have to do that all manually, (I have hundreds of records to import).
If I have to do it manually, I'll probably have to look for a different
Contact Management System. I'm just getting started now.
Julie
> Re: #2 - FullName
> Outlook names.
> Karl
> _____________
> > Contact
> > spreadsheet
> > drag
> > Any ideas?
> > > > Julie
K
Karl Timmermans
Check out "Split names by using the Convert Text to Columns Wizard" in the
Excel help file - should do the trick for you depending on what is contained
in the FullName field in Excel.
Karl
_____________
news:6AD09410-9253-4E44-9929-25B65FA64E96@microsoft.com...
> with.
> set
> data
> cells,
> import).
> Thanks,
> Julie
> > but
> > true
> > determines
> > limited
>> Re: #2 - FullName
> > its
> > and
> > info,
> > Outlook names.
>> Karl
> > _____________
> > > Contact
> > > show
> > > spreadsheet
> > > drag
> > > some
> > > it
> >> > Any ideas?
> > > > > > Julie
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
N Importing Google contacts from CSV file removes recipient names in autocomplete list Using Outlook 0
S Importing emails to contacts Using Outlook 3
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
V Problem not having Contacts folder after importing emails from Yahoo. Using Outlook 0
O Importing contacts from CSV, comma delimited Using Outlook 7
wallisellener BCM 2013 importing contacts from CSV file BCM (Business Contact Manager) 8
R Exporting and importing contacts in Outlook 2007 Using Outlook 1
K Importing CSV contacts- doesnt allow me to map or move forward V 2007 Using Outlook 1
J importing contacts, data, emails and attached files from ACT 2009 BCM (Business Contact Manager) 1
C Importing emails/contacts to Outlook 2007 from Windows Mail Outlook VBA and Custom Forms 3
P Importing contacts from Excell file BCM (Business Contact Manager) 1
R importing contacts BCM (Business Contact Manager) 1
B Importing Contacts Does Not Use Defined Custom Form in Outlook 2007 Outlook VBA and Custom Forms 1
W Primary Contacts and importing BCM (Business Contact Manager) 1
M Importing Contacts from Act 6.0 to Outlook 2007 BCM (Business Contact Manager) 3
J Importing Business Contacts linked to Accounts BCM (Business Contact Manager) 1
O Importing Mbox - anyone out there having experience with this tool... Using Outlook 2
B Importing business card into Outlook for SIgnature Using Outlook 1
S Importing Ribbons Not Saved Using Outlook 7
Diane Poremsky Importing Lists from Excel to Outlook New Slipstick.com Articles 0
B Importing Text from Excel to Outlook 2013 Calender Using Outlook 0
Christopher M Importing from Eudora Update Using Outlook 5
Christopher M Importing from Eudora Using Outlook 7
Z Importing PST files from Outlook 07 to Outlook mac Preview Using Outlook 1
Z how to make OL (2007) to use custom contact form when importing / opening .VCF? Using Outlook 1
P Importing Thunderbird email to outlook Using Outlook 2
K Importing appointment body from excel in outlook 2010 Using Outlook 1
A Importing too many emails from Gmail Using Outlook 2
J Importing to the correct calendar from Excel 2010 to Outlook 2010 Outlook VBA and Custom Forms 2
S Possible to link to ics file without importing? Using Outlook 4
L Importing Opportunities in to BCM 2013 BCM (Business Contact Manager) 0
LarryH Importing csv file to custom form/fields? Using Outlook 3
T Importing Excel 2010 data into Outlook Calendar 2010 Using Outlook 12
W Importing .pst from Outlook 2010 (Win7) to Outlook 2013 (Win8.1) Using Outlook 2
V Importing Rules in Outlook 2013 Using Outlook 2
D Importing custom fields into custom form in BCM BCM (Business Contact Manager) 1
B importing Outlook from a backup on an external hard drive Using Outlook 5
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
T BCM not importing address BCM (Business Contact Manager) 1
T Importing OE6 e-mail to Outlook via Store Folder Using Outlook 9
H Importing Windows Live Mail Contact into Outlook 2010 Using Outlook 0
T Limit on importing Inbox mail from OE6 Using Outlook 16
Commodore Importing RSS on another computer (and feed locations) Using Outlook 8
M importing email address list from excel Using Outlook 6
O Importing pst, archive pst and address not working Using Outlook 17
