Where does Outlook 2007 save the default reminder settings?
H
Hai
Outlook 2003 used to save the default reminder settings in the registry, such as: HKCU\Software\Microsoft\Office\12.0\Outlook\Preferences\Remi ndDefault.
However, although this key and value still exists in Outlook 2007, it looks that Outlook 2007 actually save this settings in another place. The value "RemindDefault" is synced to the other hidden value when Outlook starts in a profile. In this way, Outlook 2007 can set different values for separate profiles.
Does anyone know where Outlook saves this settings? Possibly some hidden message in the message store, or xml file...
Thanks for any information!
H
Hai
I have found it: it is saved in a hidden message (IPM.Configuration.Calendar) in the default Calendar folder.
D Where does Outlook store signatures? Outlook VBA and Custom Forms 9
J Where does BCM store User-Defined fields in the database? BCM (Business Contact Manager) 3
J OUTLOOK 2016 FILE STORAGE WHERE COMMAND Using Outlook 12
C Long List Of Outlook 2016/Outlook.com Bugs // Where To Report? Using Outlook 10
S Views ans Where Settings AreSavd Using Outlook 4
F Move mails from Deleted Items folder back to its original folder where the mails got deleted Using Outlook 0
N Wishlist Opening Outlook where we left off Outlook Wishlist 0
Horsepower Where did Evenote come from? Using Outlook 6
tswatek Issue with where Outlook saves new contacts Using Outlook 3
snissen Where is "Edit Message" in Outlook 2016? Using Outlook 2
Mark Foley Where are Outlook categories save for IMAP? Using Outlook 12
T Where did my categorized emails go? Using Outlook 1
H Where to post code in Outlook Outlook VBA and Custom Forms 1
P Where are the cached emails stored? Using Outlook.com accounts in Outlook 2
R Outlook 2013 People Pane - Where is the "Add" button for social networks? Using Outlook 4
J Lost contacts.pst afer sync with iCloud: where has contact.pst disapperaed to? Using Outlook 3
O Outlook 2013 contacts - Where to find "Display as"-field Using Outlook 2
J Linking Contacts to a Message Where the Contact isn't an Addressee Using Outlook 1
L How do i choose where i file my sent messages? Using Outlook 1
C Outlook 2007 Contact Card opens in margin of screen where I can't see it Using Outlook 3
P Where the heck is the data? Using Outlook 10
G Modify Subject line of incoming mail where I am in Cc line Using Outlook 1
B Can't locate in Outlook custom form where is message from Using Outlook 4
B help: where are outlook2000 email accounts stored Using Outlook 14
Rupert Dragwater Where to find folders in Outlook 2010 Using Outlook 4
S Where is the BCM SDK?? BCM (Business Contact Manager) 1
B Where are my emails that I already? Using Outlook 1
G Where are Saved Reports physically stored? BCM (Business Contact Manager) 0
O Where is Launcher, the custom action for Exchange server? Exchange Server Administration 1
J Where is Final Release BCM 2010, Microsoft? Why is Dev Team silent BCM (Business Contact Manager) 2
B Where is RTM version of BCM 2010? BCM (Business Contact Manager) 2
N Where have all the helpful people gone in this forum? BCM (Business Contact Manager) 3
S Custom Fields - Deleting And Where Are They Saved Outlook VBA and Custom Forms 8
M WHERE without using CASE Outlook VBA and Custom Forms 3
S Where to publish my custom form ? Outlook VBA and Custom Forms 4
P Where are User-defined fields stored in BCM 2010 database? BCM (Business Contact Manager) 2
E Where is Business Contact Manager?? BCM (Business Contact Manager) 2
T Where is "administrative groups" Exchange Server Administration 9
K Get folder path where an account stores messages Outlook VBA and Custom Forms 5
A COM add-in causes Outlook 2007 to periodically crash where it did not in Outlook 2003 Outlook VBA and Custom Forms 3
1 Where Can I get hold of a copy of Business Contact Manager BCM (Business Contact Manager) 4
J How can I search my contacts by where businesses are located? BCM (Business Contact Manager) 2
K Where is BCM BCM (Business Contact Manager) 2
