how to disable spell checker
Allen_N
I have built an Excel utility that fetches e-mail addresses from a database
of users and e-mails a prepared message (from a text box in a worksheet) to
some or all of the addresses. The e-mail addresses are fetched by a query and
populate a column in a worksheet. When all are to be e-mailed, I build the
recipient list from the column cells and call ShellExecute/mailto once. When
only selected addresses are to be e-mailed, I call ShellExecute/mailto in a
loop, so that the messages can be individually customised in the Outlook
composer window.
My only problem is that, in the latter mode, the Outlook spell checker is
invoked each time a new message/recipient is created.
Is it possible to programmatically disable Outlook's spell checker (from
Excel VBA), then re-enable it when done?
Al
K
Ken Slovak - [MVP - Outlook]
The setting for spell checking is in the registry. Outlook reads the setting
on startup, then caches the setting and any changes in memory while Outlook
is running. If you change the Options dialog to disable spell check on send
Outlook writes the change to the registry but still relies on the in-memory
cached setting for its operations. So any change you make needs to be when
Outlook is not running.
The registry location is at
HKCU\Software\Microsoft\Office\11.0\Outlook\Options\Spelling, in the
registry value Check (a REG_DWORD value). 1 means spell check is enabled, 0
means it's disabled.
That registry path is specific to Outlook 2003, for 2007 it would be "12.0"
instead of "11.0", etc.
"Allen_N" <AllenN> wrote in message
news:1A8FB39D-1CA1-4470-8449-41938252402C@microsoft.com...
> to
> and
> When
> a
> composer window.
> Thanks!
> Al
Allen_N
Thanks, Ken.
I don't think I want to start programmatically altering Registry keys
especially if I'm going to share the app with other people in the company.
Is there a way to detect whether or not the spell checker process runs after
invoking Outlook from ShellExecute? If I could do that, I could use SendKeys
to dismiss the spell checker pop-up and carry on with the mailing loop.
Regards,
Al
> > to
> > and
> > When
> > a
> > composer window.
> > Thanks!
> > Al
K
The only way I know of to do that is to use Win32 API calls to find the
spelling window class and then send a Windows Message to that window to
close down. You'd have to use Spy++ or a similar utility to find the
spelling window class name and use that in calls to something like
FindWindow() or FindWindowEx(). Then a SendOrPost to that window with
WM_CLOSE as the message should do it.
news:B665C2C0-CA88-4566-8D73-23311B1197F1@microsoft.com...
> Thanks, Ken.
> I don't think I want to start programmatically altering Registry keys > especially if I'm going to share the app with other people in the company.
> after
> SendKeys
> Regards,
> Al
Allen_N
Thanks again, Ken !
> > Thanks, Ken.
> > I don't think I want to start programmatically altering Registry keys > > especially if I'm going to share the app with other people in the company.
> > after
> > SendKeys
> > Regards,
> > Al
M Disable Contact Card Results when using "Search People" in Outlook Ribbon Using Outlook 4
U Disable "Always ask before opening" Dialog Using Outlook 3
J How do I disable advertising in Outlook 2019? Using Outlook 13
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
N How to disable shortcuts for Pilcrow in Outlook Using Outlook 0
P Disable Spam Notifications & Sounds Using Outlook 3
Diane Poremsky Disable Protected View for Outlook Attachments New Slipstick.com Articles 0
Diane Poremsky Disable Outlook Add-ins (Apps) New Slipstick.com Articles 0
J Using VBA to disable alerts / warnings Using Outlook 2
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments New Slipstick.com Articles 0
N How to disable user defined fields in BCM forms Using Outlook 2
Diane Poremsky Disable Live Preview in Outlook and Word New Slipstick.com Articles 0
D Preventing users to disable an Outlook Add-in Using Outlook.com accounts in Outlook 5
F Disable "Find related messages" Using Outlook 1
davecazz Anyway to disable the peek rollovers? Using Outlook 1
R Outlook Cache Mode Terminalserver disable through Registry Using Outlook 1
S Cannot disable OWA light Exchange Server Administration 5
A How to disable the pop-up “Reponses to this meeting will not be tallied." Using Outlook 0
D Show this folder as an e-mail Address Book is enabled but I want to disable Using Outlook 2
Rupert Dragwater how to disable billingual dictionary in outlook 2010 Using Outlook 9
J How to disable syncing folder views/layouts Using Outlook 5
A Disable hotmail from Outlook email account Using Outlook 1
R Disable request to share a calendar Using Outlook 1
T Disable the To-Do Bar permanently Using Outlook 15
J Outlook's auto time zone update for meeting requestsHow to REMOVE or DISABLE? Using Outlook 1
D Disable Junk Email in the Registry? Using Outlook 8
A How to disable bcc option in GAL - Address Book - Exchange 2007 Exchange Server Administration 4
P disable image compression Using Outlook 5
J Disable outlook 2010 no-subject warning Using Outlook 4
E Disable outlook 2010 no-subject warning Using Outlook 9
C Disable printing Outlook VBA and Custom Forms 1
A disable a menu in active inspector Outlook VBA and Custom Forms 1
N Disable control CTRL button when dragging items/folders - Outlook Outlook VBA and Custom Forms 2
D Disable Junk E-mail Filter in Outlook 2007 Using Outlook 13
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 1
J How to hide/disable send button in Outlook 2007 Outlook VBA and Custom Forms 2
P Disable Instant Search in Outlook 2007 Outlook VBA and Custom Forms 9
S how to disable security message in save attachments macro "A programis trying to access e-mail addre Outlook VBA and Custom Forms 5
