Ability to define shortcuts to folders
phs3
I have an Exchange mailbox and a ton o' POP accounts. 99% of the POP mail goes into one of three folders. I'd like to be able to go to those by shortcut -- <Cntrl><Shift>P or something *I* define.
And I rarely go to the Outbox, so the fact that <Cntrl><Shift>O takes me there is a waste. So for extra credit, this should allow me to override the built-in shortcuts.
phs3
Gah, the one time I *don't* do Preview, and it eats the less-than/greater-than signs. The shortcuts were cntrl-shift-p, cntrl-shift-o.
Forum Admin
I have an Exchange mailbox and a ton o' POP accounts. 99% of the POP mail goes into one of three folders. I'd like to be able to go to those by shortcut -- <CNTRL><SHIFT>P or something *I* define.
And I rarely go to the Outbox, so the fact that <CNTRL><SHIFT>O takes me there is a waste. So for extra credit, this should allow me to override the built-in shortcuts.
When in the folder list, outlook will jump you to the folders as you type the first letter - although its somewhat pointless in outlook 2007 since the message list takes focus. For this reason alone, the ability to assign shortcuts would be nice.
To do it now - tab to bring the list in focus (usually 3 times) and press a letter - ie, I for inbox, O for Outbox, P for "Phs3 Inbox" and pess enter. If you have multiple folders beginning with a letter you need to press the letter multiple times.
K Intermittent ability to send to single domain. "Connection refused" Exchange Server Administration 1
J Ability to notify attendees when canceling past meeting is gone Using Outlook 1
A Add Contact to Public Folder Ability Outlook Wishlist 3
N Business Contact Manager - Ability to use BCM (Business Contact Manager) 8
A ability to add comments to frequently used fields of a contact Outlook Wishlist 0
T Define how my account is named Using Outlook.com accounts in Outlook 2
G Addin to define message format on a per-contact basis? Outlook VBA and Custom Forms 1
N How to disable shortcuts for Pilcrow in Outlook (Show or hide paragraph marks) Using Outlook 0
N How to disable shortcuts for Pilcrow in Outlook Using Outlook 0
Diane Poremsky Shortcuts and the Missing Outlook:// Protocol New Slipstick.com Articles 0
L any ways to create shortcuts to a public mail folder Using Outlook 4
L Navigation Pane selection with shortcuts Using Outlook 2
Commodore Favorites vs. Shortcuts Using Outlook 1
T Displaying Shortcuts in Outlook 2010 Using Outlook 7
L Macro Shortcuts Using Outlook 1
L Outlook 2007 Keyboard Shortcuts Using Outlook 8
R Custom Keyboard Shortcuts for 2010 Using Outlook 3
C Configuring Navigation shortcuts Using Outlook 3
D Outlook and the Dreaded Losing Shortcuts Issue Using Outlook 4
D Shortcuts in Outlook Business Manager not wokring BCM (Business Contact Manager) 3
J Outlook 2000 "My Shortcuts" question Outlook VBA and Custom Forms 2
