copying a custom view from a public folder and distributing programatically
ram1
I am probably making this way more complicated than it needs to be. I know little about vba.
I am trying to piece together snippets of code to get the result. In a nutshell, I have created a custom view and assigned it to a particular public folder.
I want to be able to create a macro that a user can run, to copy that view in the public folder into their outlook and let the view be used for all mail folders.
The name of the Public Folder is "Public Folders\All Public Folders\VorysViews"
The ViewDriver sub and CreateView Function work if I use the original
Set objViews = objName.GetDefaultFolder(FolderType:=cnstFolderName).Views
but not with what I have been trying
Set objViews = GetFolder("Public Folders\All Public Folders\VorysViews").
Views
I have been unsuccessful getting objViews to be the views in "Public Folders\All Public Folders\VorysViews"
The other Function "GetFolder" is where I went off on a tangent because I don't think I need to return just the final folder name. I just need to copy the views from "Public Folders\All Public Folders\VorysViews" and then save the view for all mail and post folders.
I'm sure I'm overlooking the obvious. Leading me in the right direction would be really helpful.
I bought "Microsoft Outlook Programming" but don't have the 2007 version yet.
Sub ViewDriver()
'Calls the CreateView function to return a view.
Dim objView As View
Set objView = CreateView(strName:="Main Inbox Table_bymacro", cnstFolderName:=olFolderInbox, cnstViewType:=olTableView)
'MsgBox "cnstFolderName is " & cnstFolderName
If objView Is Nothing Then
MsgBox "The view was not created."
'MsgBox "The view: " & objFolder.Name & " is failing badly."
'MsgBox "objview is " & objView.Name
MsgBox "The view: " & objView.Name & " was created sucessfully."
Function CreateView(ByVal strName As String, ByVal cnstFolderName As OlDefaultFolders, ByVal cnstViewType As OlViewType) As View
'If succesful, returns a new view.
Dim objName As NameSpace
Dim objViews As Views
Set objName = olApp.GetNamespace(Type:="MAPI")
'Set objViews = objName.GetDefaultFolder(FolderType:=cnstFolderName).Views
Set objViews = GetFolder("Public Folders\All Public Folders\VorysViews").Views
'Set objFolder =  GetFolder("Public Folders\All Public Folders\Company\Sales")
'Create the new view.
Set CreateView = objViews.Add(Name:=strName, ViewType:=cnstViewType,
SaveOption:=olViewSaveOptionAllFoldersOfType)
End Function
'SaveOption:=olViewSaveOptionAllFoldersOfType)
'The above SaveOption will save the view to all folders of this type
Public Function GetFolder(strFolderPath As String) As MAPIFolder
' strFolderPath needs to be something like
'   "Public Folders\All Public Folders\Company\Sales" or
'   "Personal Folders\Inbox\My Folder"
Dim colFolders As Outlook.Folders
Dim objFolder As Outlook.MAPIFolder
Dim arrFolders() As String
Dim I As Long
strFolderPath = Replace(strFolderPath, "/", "\")
arrFolders() = Split(strFolderPath, "\")
Set objApp = Application
Set objNS = objApp.GetNamespace("MAPI")
Set objFolder = objNS.Folders.Item(arrFolders(0))
If Not objFolder Is Nothing Then
For I = 1 To UBound(arrFolders)
Set colFolders = objFolder.Folders
Set objFolder = Nothing
Set objFolder = colFolders.Item(arrFolders(I))
If objFolder Is Nothing Then
Exit For
Set GetFolder = objFolder
MsgBox "GetFolder is " & objFolder.Name
MsgBox "objFolder is " & GetFolder.Name
Set colFolders = Nothing
Set objNS = Nothing
Set objApp = Nothing
End Function
K
Ken Slovak - [MVP - Outlook]
Are we to assume you are using Outlook 2003 at the moment?
Dim pub As Outlook.MAPIFolder
Set pub =
NameSpace.GetDefaultFolder(olPublicFoldersAllPublicFolders).Folders("VorysViews")
Get the view from this:
Set oView = pub.Views.Item("whateverTheViewNameIs")
Before saving the view at the target folder set the SaveOption property to
olViewSaveOptionAllFoldersOfType.
witzker
Hi I look for the same possibility in OL 2010
B Copying data between atbs in a custom form Outlook VBA and Custom Forms 4
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
T Copying Outlook Account Setup For Desktop App Using Outlook 5
Thiago Manzano Copying E-mails to a folder on HD Using Outlook 1
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
Paul Butticaz Copying Contacts from SharePoint List (connected to Outlook) to another Conacts folder Using Outlook 1
K Outlook 2010 Not responding after IMAP folder deletion or copying. Using Outlook 2
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
S Calendar items are not being uploaded to outlook.com after copying Using Outlook.com accounts in Outlook 1
P open reminders missing after copying outlook pst file Using Outlook 2
L Copying Emails using drag and drop Using Outlook 2
O New to Outlook 2013, dealing with copying vs. moving sent items Using Outlook 0
S Recover messages that disappeared when copying to folder Using Outlook 1
S Copying multiple messages to folders and keeping date/time detail Using Outlook 1
D Copying POP3 folders from Inbox to IMAP Inbox in Outlook 2003 Using Outlook 0
M Copying setups for mutiple users Using Outlook 2
T Location and simple copying of emails and settings, OL 2010 and Win 7 64bit. Using Outlook 3
A Copying additional contact fields when chosing "Contact from the same company" Using Outlook 5
A Copying cc email addresses to Excel - does not copy the <joe.bloggs@isp.com> Using Outlook 1
S Search Indexing (Copying Folders) Using Outlook 0
I copying messages from inbox to folder outside outlook Using Outlook 2
C Copying an email. Using Outlook 1
B Moving or copying a Hotmail Folder to an external Hard Disk?____ Using Outlook 2
F copying outlook Using Outlook 3
T Copying contacts Using Outlook 3
I Copying mailboxes from Exchange 2003 to Exchange 2010 Exchange Server Administration 3
1 Error message when copying contacts from one group to another Using Outlook 2
R copying or cutting an appointment to paste it to a different date Using Outlook 1
O Copying Outlook Categories to the attachment (MS word) body in bulk. Is this possible? Using Outlook 7
J Random copying of emails in inbox and calendar appointments deleted Using Outlook 1
S How to retain "Date Sent" and "Date Received" data when copying email messages from Outlook to an Ex Using Outlook 2
A Copying Outlook to Windows 7 Using Outlook 1
A Copying Outlook t5o Windows 7 Using Outlook 1
J Outlook won't allow hyperlink in email to work, but copying & posting hyperlink in browser works OK. Using Outlook 1
S Copying suggested outlook names from Outlook 2003 to 2010. Using Outlook 1
T Adding or copying a duplicate contact does not get detected and stopped Using Outlook 1
P copying calendar from desktop computer for use on laptop computer Using Outlook 1
Q Copying Outlook 2003/XP contact list to Outlook 2007/Windows 7 Using Outlook 25
E Copying multiple folders to PST Outlook VBA and Custom Forms 2
N error when copying outlook data "can not copy: the path too deep" Using Outlook 6
N Copying outlook macros between pcs Outlook VBA and Custom Forms 1
R Copying Data from Exchange to PST file Outlook VBA and Custom Forms 1
V Copying contents from one field to another field Outlook VBA and Custom Forms 6
