Outlook macro help please
V
Victor Delta
Can anyone please tell me how to record a macro on Outlook please (I'm using
Office 2003). I was expecting the same sort of 'record new macro' facility
as exists in Word and Excel, but it doesn't seem to be there.
All I'm trying to do is create a macro which changes the active printer,
prints the current email, and then resets the active printer to the default
printer.
Without the usual macro 'wizard', so far I've only got as far as '
ActivePrinter "Printer2" '.
Can anyone help please?
TIA
V
K
Ken Slovak - [MVP - Outlook]
No macro recorder in Outlook, never was, never will be.
Outlook reads the default system printer on startup and the only print
method you have is to print. No arguments, no settings, just print. That's
it.
"Victor Delta" <none@nospam.com> wrote in message
news:eqFJCyaoJHA.3572@TK2MSFTNGP05.phx.gbl...
> using Office 2003). I was expecting the same sort of 'record new macro'
> facility as exists in Word and Excel, but it doesn't seem to be there.
> default printer.
> TIA
> V
V
Victor Delta
" - " <kenslovak@mvps.org> wrote in message
news:utMuEBboJHA.4372@TK2MSFTNGP02.phx.gbl...
> it.
Thanks, Ken. So, if I understand you correctly, you're saying that the
simple task I am attempting is just not possible (using a macro anyway)? Is
that so?
V
K
It's not possible at all in Outlook. If you want to format your printout, be
selective in what's printed or print to a specific printer or use background
printing most of us use Word and take the data we want and put it into a
Word template and then do the printing using the Word object model.
news:%237Vt7mboJHA.1172@TK2MSFTNGP05.phx.gbl...
> > That's it.
> Is that so?
> V
V
Victor Delta
news:OjzgqBcoJHA.504@TK2MSFTNGP06.phx.gbl...
> be selective in what's printed or print to a specific printer or use
> background printing most of us use Word and take the data we want and put
> it into a Word template and then do the printing using the Word object
> model.
Many thanks for that, although I have to say I am very surprised and
disappointed that VBA in Outlook is so limited. I gather you cannot even set
the active printer as in other Office applications.
However, I haven't given up quite yet and wondered if anyone knows if there
are any third party applications that would help? For example, there used to
be a nifty freeware programme available that enabled one to automate certain
routine tasks but I can't remember it's details. Certainly changing the
printer is not terribly complicated in terms of key strokes so I don't know
if this would be a possibility?
Incidentally the reason I am trying to do this is to use Green Print with
Outlook (only). Green Print can be downloaded from www.printgreener.com (the
'world' version is free) and it works between applications and one's printer
and enables one to easily stop blank or unimportant pages being printed. So
for Outlook it is ideal - and saves what you describe about having to copy
and paste data to Word etc for controlled printing. However, for Word etc it
just slows things down (an unnecessary extra stage in the printing process)
and so I don't want it to be the default printer.
V
PS Suppose one way round this would be set Green Print as the default
printer and then write macros for all the other Office programmes to set
their active printers to the 'real' printer? A laboriously long way round...
P
PaulD
This can be done by changing the default printer using vba but it takes a
little bit of code. I will do my best to explain.
First create a new module in the vba editor in outlook (VbaProject.OTM), you
can set the name to anything you would like
at the very top (just below Option Explicit if it's there) paste the
following
Public Declare Function GetProfileString Lib "kernel32" _
Alias "GetProfileStringA" _
(ByVal lpAppName As String, _
ByVal lpKeyName As String, _
ByVal lpDefault As String, _
ByVal lpReturnedString As String, _
ByVal nSize As Long) As Long
Sub PrintGreen()
Dim strDefault As String
Dim WshNetwork As WshNetwork
Dim i As Integer
Dim myOlApp As Outlook.Application
Dim mySelection As Selection
Set myOlApp = Application
Set mySelection = myOlApp.ActiveExplorer.Selection
Set WshNetwork = CreateObject("WScript.Network")
strDefault = DefaultPrinter
WshNetwork.SetDefaultPrinter ("ENTER YOUR PRINTER NAME HERE!")
For i = mySelection.count To 1 Step -1
If mySelection.Item(i).Class = olMail Then mySelection.Item(i).PrintOut
Next i
WshNetwork.SetDefaultPrinter (strDefault) ' restore default
Public Function DefaultPrinter() As String
Dim strReturn As String
Dim intReturn As Integer
strReturn = Space(255)
intReturn = GetProfileString("Windows", ByVal "device", "", _
strReturn, Len(strReturn))
If intReturn Then
strReturn = UCase(Left(strReturn, InStr(strReturn, ",") - 1))
DefaultPrinter = strReturn
End Function
You can now create a button and assign the PrintGreen macro to it and it
should print any emails you have selected to your specified printer. I did
test this on my computer and found there is a several second (ok like 10)
delay while printing. You may or may not have this issue. Anyway, post
back if you have any questions.
Paul D
news:uUteDDpoJHA.504@TK2MSFTNGP06.phx.gbl...
: " - " <kenslovak@mvps.org> wrote in message
: news:OjzgqBcoJHA.504@TK2MSFTNGP06.phx.gbl...
: > It's not possible at all in Outlook. If you want to format your
printout,
: > be selective in what's printed or print to a specific printer or use
: > background printing most of us use Word and take the data we want and
put
: > it into a Word template and then do the printing using the Word object
: > model.
: Many thanks for that, although I have to say I am very surprised and
: disappointed that VBA in Outlook is so limited. I gather you cannot even
set
: the active printer as in other Office applications.
: However, I haven't given up quite yet and wondered if anyone knows if
there
: are any third party applications that would help? For example, there used
to
: be a nifty freeware programme available that enabled one to automate
certain
: routine tasks but I can't remember it's details. Certainly changing the
: printer is not terribly complicated in terms of key strokes so I don't
know
: if this would be a possibility?
: Incidentally the reason I am trying to do this is to use Green Print with
: Outlook (only). Green Print can be downloaded from www.printgreener.com
(the
: 'world' version is free) and it works between applications and one's
printer
: and enables one to easily stop blank or unimportant pages being printed.
So
: for Outlook it is ideal - and saves what you describe about having to copy
: and paste data to Word etc for controlled printing. However, for Word etc
it
: just slows things down (an unnecessary extra stage in the printing
process)
: and so I don't want it to be the default printer.
: V
: PS Suppose one way round this would be set Green Print as the default
: printer and then write macros for all the other Office programmes to set
: their active printers to the 'real' printer? A laboriously long way
round...
V
Victor Delta
"PaulD" <nospam> wrote in message
news:uOJOi%231oJHA.3984@TK2MSFTNGP02.phx.gbl...
> you
> following
> Sub PrintGreen()
> Dim i As Integer
> Next i
> End Sub
> If intReturn Then
> End If
> End Function
> did
> Paul D
Paul
Many thanks - that's very interesting. I'll give it a try and let you know
how I get on.
V
V
Victor Delta
> > did
> > Paul D
Paul
Just a thought. In view of the delay, would it be better to write the code
so that the printer is changed when Outlook opens?
V
P
PaulD
Victor,
That could easily be done, the only issue I see is if you leave outlook open
all the time (like I do), then the default printer will be incorrect for
other programs until you close outlook. Maybe not an issue for you, so if
that's the case you would have to add some event code to ThisOutlookSession:
Option Explicit
Dim strDefaultPrinter As String
If intReturn Then
strDefaultPrinter = strReturn 'save default printer
WshNetwork.SetDefaultPrinter ("YOUR PRINTER NAME HERE")
Set WshNetwork = Nothing
Private Sub Application_Quit()
WshNetwork.SetDefaultPrinter (strDefaultPrinter) ' restore default
I would leave the Public Declare function GetProfileString in its own module
called Declarations and delete the sub PrintGreen and function
DefaultPrinter
Paul D
news:On9$IsBpJHA.4448@TK2MSFTNGP05.phx.gbl...
:> "PaulD" <nospam> wrote in message
: >> You can now create a button and assign the PrintGreen macro to it and
it
: >> should print any emails you have selected to your specified printer. I
: >> did
: >> test this on my computer and found there is a several second (ok like
10)
: >> delay while printing. You may or may not have this issue. Anyway,
post
: >> back if you have any questions.
: >> Paul D
: Paul
: Just a thought. In view of the delay, would it be better to write the code
: so that the printer is changed when Outlook opens?
: V
V
Victor Delta
news:uAOTVAkpJHA.5280@TK2MSFTNGP02.phx.gbl...
> Victor,
> open
> ThisOutlookSession:
> Option Explicit
> Private Sub Application_Startup()
> If intReturn Then
> End If
> End Sub
> End Sub
> module
> DefaultPrinter
> Paul D
Thanks, good point!
V
V
Victor Delta
> you
> following
> Sub PrintGreen()
> Dim i As Integer
> Next i
> End Sub
> If intReturn Then
> End If
> End Function
> did
> Paul D
Paul
I followed your instructions and tried your original code today.
However, when I tried to run it, a compile error message came up -
'WshNetwork As WshNetwork' was highlighted and the message said
'User-defined type not defined'. Any idea how to resolve this?
V
V
Victor Delta
news:ugA5UAzpJHA.5832@TK2MSFTNGP06.phx.gbl...
> > you
> > following
>> Sub PrintGreen()
> > Dim i As Integer
> > Next i
> > End Sub
> > If intReturn Then
> > End If
> > End Function
> > did
> > Paul D
> Paul
> V
Paul
After a bit of experimentation, I changed the line to
Dim WshNetwork As Object
and the macro now runs. However, it just seems to still send documents to
the default printer - even through I changed "ENTER YOUR PRINTER NAME HERE!"
to "GreenPrint"?
V
K
Outlook only reads the printer to use when it starts up. You can change the
system printer as often as you want and it won't matter if you don't do it
before Outlook starts. There is no way, using the Outlook item.PrintOut()
method to select or change the printer being used.
news:eqxffV0pJHA.3380@TK2MSFTNGP04.phx.gbl...
<snip>
> HERE!" to "GreenPrint"?
> V
P
PaulD
Ken,
Intesting comment since I tested this using Outlook 2003 and it does work.
Have you tested this yourself ? Without any code you can test this by
printing an email, then going into your printers settings, changing your
default printer then printing the email again.
Paul D
news:u1c9km8pJHA.5880@TK2MSFTNGP05.phx.gbl...
: Outlook only reads the printer to use when it starts up. You can change
the
: system printer as often as you want and it won't matter if you don't do it
: before Outlook starts. There is no way, using the Outlook item.PrintOut()
: method to select or change the printer being used.
: "Victor Delta" <none@nospam.com> wrote in message
: news:eqxffV0pJHA.3380@TK2MSFTNGP04.phx.gbl...
: <snip
: > After a bit of experimentation, I changed the line to
: > Dim WshNetwork As Object
: > and the macro now runs. However, it just seems to still send documents
to
: > the default printer - even through I changed "ENTER YOUR PRINTER NAME
: > HERE!" to "GreenPrint"?
: > V
P
PaulD
Victor,
My mistake for not telling you to set the appropriate reference. Anyway, I
would assume you may not have the correct printer name being used. To
verify this set your "GreenPrint" as the default printer first, then set a
break point in the PrintGreen sub at the line
Now run the code to your breakpoint and verify what text is being stored in
the strDefault string. This text is the exact text you need to used in the
"ENTER YOUR PRINTER..." area
Paul D
: news:ugA5UAzpJHA.5832@TK2MSFTNGP06.phx.gbl...
: > "PaulD" <nospam> wrote in message
: > news:uOJOi%231oJHA.3984@TK2MSFTNGP02.phx.gbl...
: >> This can be done by changing the default printer using vba but it takes
a
: >> little bit of code. I will do my best to explain.
: >> First create a new module in the vba editor in outlook
(VbaProject.OTM),
: >> you
: >> can set the name to anything you would like
: >> at the very top (just below Option Explicit if it's there) paste the
: >> following
: >> Public Declare Function GetProfileString Lib "kernel32" _
: >> Alias "GetProfileStringA" _
: >> (ByVal lpAppName As String, _
: >> ByVal lpKeyName As String, _
: >> ByVal lpDefault As String, _
: >> ByVal lpReturnedString As String, _
: >> ByVal nSize As Long) As Long
: >> Sub PrintGreen()
: >> Dim strDefault As String
: >> Dim WshNetwork As WshNetwork
: >> Dim i As Integer
: >> Dim myOlApp As Outlook.Application
: >> Dim mySelection As Selection
: >> Set myOlApp = Application
: >> Set mySelection = myOlApp.ActiveExplorer.Selection
: >> Set WshNetwork = CreateObject("WScript.Network")
: >> strDefault = DefaultPrinter
: >> WshNetwork.SetDefaultPrinter ("ENTER YOUR PRINTER NAME HERE!")
: >> For i = mySelection.count To 1 Step -1
: >> If mySelection.Item(i).Class = olMail Then
: >> mySelection.Item(i).PrintOut
: >> Next i
: >> WshNetwork.SetDefaultPrinter (strDefault) ' restore default
: >> End Sub
: >> Public Function DefaultPrinter() As String
: >> Dim strReturn As String
: >> Dim intReturn As Integer
: >> strReturn = Space(255)
: >> intReturn = GetProfileString("Windows", ByVal "device", "", _
: >> strReturn, Len(strReturn))
: >> If intReturn Then
: >> strReturn = UCase(Left(strReturn, InStr(strReturn, ",") - 1))
: >> End If
: >> DefaultPrinter = strReturn
: >> End Function
it
: >> did
10)
post
: >> Paul D
: > Paul
: > I followed your instructions and tried your original code today.
: > However, when I tried to run it, a compile error message came up -
: > 'WshNetwork As WshNetwork' was highlighted and the message said
: > 'User-defined type not defined'. Any idea how to resolve this?
: > V
: Paul
: After a bit of experimentation, I changed the line to
: Dim WshNetwork As Object
: and the macro now runs. However, it just seems to still send documents to
: the default printer - even through I changed "ENTER YOUR PRINTER NAME
HERE!"
: to "GreenPrint"?
: V
K
I haven't tested that in a few years, unless something changed that's the
way it always was. It's possible that MS changed things to read the current
printer when PrintOut() is called however.
news:ucM1CD%23pJHA.4516@TK2MSFTNGP02.phx.gbl...
> Ken,
> Paul D
V
Victor Delta
news:u8sUMG%23pJHA.5880@TK2MSFTNGP05.phx.gbl...
> Victor,
> I
> in
> the
> Paul D
Paul
Many thanks for that. However, I'm still having problems.
I followed your advice above and found that the correct printer name is
GREENPRINT so inserted this in the code which now looks like this (by the
way, was I correct about changing to 'Dim WshNetwork As Object'?):
Sub PrintGreen()
Dim i As Integer
WshNetwork.SetDefaultPrinter ("GREENPRINT")
For i = mySelection.Count To 1 Step -1
Next i
If intReturn Then
End Function
However, when I run this with the original default printer set, the print
goes to the default printer not Green Print! Have I made a mistake
somewhere?
Obviously it's working at your end - have you made any other changes
perhaps?
I'm glad this is possible because although I'm sure Ken is very expert in
such matters, it must be possible to change the Outlook printer otherwise
one wouldn't be able to do it manually so easily (couple of clicks) via the
print dialogue box. I just couldn't understand this before.
Thanks again for all your help...
V
P
PaulD
Victor,
You were correct to change 'Dim WshNetwork As Object', that should work.
Since you could follow my directions before, I would recommened you try
this: set a break point on the line
in the PrintGreen sub and then run the code. You should be able to hover
over the strDefault variable to see if it was set, then open your printers
and faxes window and see if the default printer was switched. To make sure
I have the same code as you I copied the code from your post below into a
new module and ran it to make sure it worked. I got an error saying it
couldn't find the printer "GREENPRINT" which is good since I don't have that
printer. I changed it to a network printer I do have (CutePDF) and it
worked. Investigae some more and post back with your results
Paul D
news:err7j%23AqJHA.2392@TK2MSFTNGP04.phx.gbl...
: "PaulD" <nospam> wrote in message
: news:u8sUMG%23pJHA.5880@TK2MSFTNGP05.phx.gbl...
: > Victor,
: > My mistake for not telling you to set the appropriate reference.
Anyway,
: > I
: > would assume you may not have the correct printer name being used. To
: > verify this set your "GreenPrint" as the default printer first, then set
a
: > break point in the PrintGreen sub at the line
: > WshNetwork.SetDefaultPrinter ("ENTER YOUR PRINTER NAME HERE!")
: > Now run the code to your breakpoint and verify what text is being stored
: > in
: > the strDefault string. This text is the exact text you need to used in
: > the
: > "ENTER YOUR PRINTER..." area
: > Paul D
: Paul
: Many thanks for that. However, I'm still having problems.
: I followed your advice above and found that the correct printer name is
: GREENPRINT so inserted this in the code which now looks like this (by the
: way, was I correct about changing to 'Dim WshNetwork As Object'?):
: Public Declare Function GetProfileString Lib "kernel32" _
: Alias "GetProfileStringA" _
: (ByVal lpAppName As String, _
: ByVal lpKeyName As String, _
: ByVal lpDefault As String, _
: ByVal lpReturnedString As String, _
: ByVal nSize As Long) As Long
: Sub PrintGreen()
: Dim strDefault As String
: Dim i As Integer
: Dim myOlApp As Outlook.Application
: Dim mySelection As Selection
: Set myOlApp = Application
: Set mySelection = myOlApp.ActiveExplorer.Selection
: Set WshNetwork = CreateObject("WScript.Network")
: strDefault = DefaultPrinter
: WshNetwork.SetDefaultPrinter ("GREENPRINT")
: For i = mySelection.Count To 1 Step -1
: If mySelection.Item(i).Class = olMail Then mySelection.Item(i).PrintOut
: Next i
: WshNetwork.SetDefaultPrinter (strDefault) ' restore default
: End Sub
: Public Function DefaultPrinter() As String
: Dim strReturn As String
: Dim intReturn As Integer
: strReturn = Space(255)
: intReturn = GetProfileString("Windows", ByVal "device", "", _
: strReturn, Len(strReturn))
: If intReturn Then
: strReturn = UCase(Left(strReturn, InStr(strReturn, ",") - 1))
: End If
: DefaultPrinter = strReturn
: End Function
: However, when I run this with the original default printer set, the print
: goes to the default printer not Green Print! Have I made a mistake
: somewhere?
: Obviously it's working at your end - have you made any other changes
: perhaps?
: I'm glad this is possible because although I'm sure Ken is very expert in
: such matters, it must be possible to change the Outlook printer otherwise
: one wouldn't be able to do it manually so easily (couple of clicks) via
the
: print dialogue box. I just couldn't understand this before.
: Thanks again for all your help...
: V
V
Victor Delta
news:%23cCpZtJqJHA.1172@TK2MSFTNGP05.phx.gbl...
> Victor,
> sure
> that
> Paul D
Paul
Thanks. This is most odd. Followed your instructions and sure enough, using
the break point, the default printer does change to Green Print and then
changes back. However, the print out still seems to go through to the wrong
printer, although on a couple of occasions when using Step into (F8) I got
it to go to Green Print. I've been trying again and for the last 10 minutes
it will only go to the wrong printer!
I'll do some more experimentation but not quite sure why it should be so
inconsistent! Any ideas? We're so nearly there...
V
V
Victor Delta
news:OKENscNqJHA.5832@TK2MSFTNGP06.phx.gbl...
> > Victor,
> > printers
> > sure
> > that
> > Paul D
> Paul
> using
> wrong
> minutes
Have done some more experimentation and believe I have now found the
problem - and it's very interesting.
To aid clarity lets call the two printers Printer A (normal default) and
Printer Green. Once Outlook is open, if you change the default printer
(either manually or via your macro with the break point on the "For i = ..."
line) if you hover over the Print button at the top of any email, you will
see the name of the new printer (in my case Printer Green). This looks very
promising...
However, there's a big gotcha! If you now open the Outlook Print dialogue
box (Ctrl +P), although you will see the little black tick against the name
of the new default printer, the original printer (Printer A) is actually
still selected (highlighted in blue). So if you now print, either by
clicking the button or running the second part of your code, the email goes
to the original printer. I guess this is what Ken was telling us all along!
If only there were a way to 'refresh' the printer selection to the new
default printer it would work but, so far, I haven't thought of one. Any
ideas?
The only surprise now is that you've managed to make it work at your end.
I've been using Windows XP with Outlook XP/2002 and, on another machine,
Outlook 2003. Same as you?
V
A newb outlook macro help Outlook VBA and Custom Forms 1
F Help with Outlook 2007 Macro Please! Using Outlook 4
S Outlook macro help Using Outlook 10
S Outlook 2003: Help with setting up a macro to reply to selected emails Using Outlook 2
L Help for writing an Outlook 2007 macro Outlook VBA and Custom Forms 7
C Outlook Subject Line Macro Outlook VBA and Custom Forms 0
P Macro to attach a file in a shared Outlook draft folder Outlook VBA and Custom Forms 2
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
L Outlook 2007 - Macro Re Search Using Outlook 16
L Outlook 2007 Macro to Contact From a Field Using Outlook 3
Diane Poremsky Macro to Bulk Import Contacts and vCards into Outlook Using Outlook 0
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
S Macro in an excel for outlook. Outlook VBA and Custom Forms 2
A Outlook Macro Causing Excel Error Outlook VBA and Custom Forms 0
S Outlook Macro Reply to a message Outlook VBA and Custom Forms 1
Diane Poremsky Macro to Bulk Import vCards into Outlook Using Outlook 0
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
P Outlook Macro sends information to Excel Using Outlook 1
B Looking for Outlook 2013 update for Send Drafts Macro Using Outlook 4
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
S Macro for Reply All in 2013 Outlook Outlook VBA and Custom Forms 10
L Outlook 2007 Macro Save Contact Using Outlook 10
