Best way to distribute VBA project
Maurice
Hi guys,
I programmed some functionality in Outlook 2003. My client wants to
distribute this in an easy way. Is it possible to distribute this easily or
do I need to make an add in out of it. I guess this has to be done via VSTO
right? If you know of any other way pls let me know.
What needs distributing: two modules and two userforms
Version: Outlook 2003
Windows XP
thanks in advance
Maurice Ausum
Sue Mosher [MVP]
The best solution would be to build an add-in, using what you've learned in
writing the VBA code.
If you want to look at VBA distribution options, see
http://www.outlookcode.com/article.aspx?id=28, but you're heading into
unsupported territory there.
Sue Mosher
"Maurice" <Maurice> wrote in message
news:0FB36A57-40A5-42A3-AE31-8CC43CC833B8@microsoft.com...
> Hi guys,
> or
> VSTO
> Windows XP
> thanks in advance
> > Maurice Ausum
K
Ken Slovak - [MVP - Outlook]
To add to what Sue mentioned, you can use VSTO if you want or you can use a
managed code shared addin.
"Sue Mosher [MVP]" <suemvp@turtleflock.com> wrote in message
news:uW6Q36MJKHA.3632@TK2MSFTNGP05.phx.gbl...
> in writing the VBA code.
> > Sue Mosher
Maurice
Thanks for the reply Sue, i'll take a look at the link you posted.
Maurice Ausum
> > Sue Mosher
> > Hi guys,
> > or
> > VSTO
> > Windows XP
> > thanks in advance
> > > > Maurice Ausum
Maurice
Thanks for the reply Ken, that's what i figured. I'll have a go at it.
Maurice Ausum
> > > > Sue Mosher
Rupert Dragwater What is the best way to back up pst Using Outlook 4
Diane Poremsky The Best Outlook Store Add-ins Contest New Slipstick.com Articles 0
X Best utility for repairing PST files? Using Outlook 3
D a suggestion ...sent with the best intentions Using Outlook 1
M How best to track OUTGOING referrals? BCM (Business Contact Manager) 2
M best duplicate contact remover? Using Outlook 6
G what is the best way to organize outlook contacts Using Outlook 1
D What would be the best strategy? Using Outlook 3
J Best way to move form old to new, larger pst? Using Outlook 2
M Best way to move outlook? Using Outlook 1
R Best way to share outlook calendar with 10 laptops Using Outlook 9
B Best way to get a pick-list on a form? Outlook VBA and Custom Forms 1
T Is Explorer.FolderSwitch the best event for hiding commandbarbutton? Outlook VBA and Custom Forms 5
D Distribute Form Regions Using Outlook 0
F Creating Meeting Request Custom form and distribute it to domain user HELP!!! Using Outlook 0
R Outlook Template: Looking to distribute a VBA Outlook template to other people Using Outlook 1
L Modifying VBA script to delay running macro Outlook VBA and Custom Forms 0
