Is it possible to INSERT a string into email body via Shortcut.
ThomasAJ
In my Access program I can insert predefined string content into Text Boxes
using various shortcust like Alt+1, Alt+2 etc. (I monitor for that in the
Form_KeyDown event).
I would love to be able to do similar inserts into email body. (yes each
user could set up their own strings in Signatures but I would rather have the
many commonly used ones stored in the Access DB)
I have not programmed Outlook other than to use Automation in Access to fill
out an email's To, Subject, Body etc and send it off. (I use Redemption).
Regards
Tom
Michael Bauer
The only way in Outlook to define shortcuts is to customize the toolbar, add
your own button, and find an accelerator for it that isn't used yet. In
order to define the accelerator, use the ampersand in the button's caption.
Chances are good that &1, &2, etc. are available.
Best regards
Michael Bauer
Am Fri, 11 Sep 2009 19:36:01 -0700 schrieb ThomasAJ:
Boxes
the
fill
ThomasAJ
Re: Is it possible to INSERT a string into email body via Shortcut
Yes I understand.
BUT
I meant to do Signature type inserts programmatically from Access.
eg user opens new mail item, clicks on my Access app, presses Alt+1 and then
via Automation the insert occurs. I was hoping for some code in Access to
manipulate the insertion into the email body.
Regards
Tom
> > Best regards
> Michael Bauer
> Boxes
> the
> fill
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
S Is it possible to cusstomise selectable Options in Kalander. Outlook VBA and Custom Forms 1
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
J Is this possible to do with a macro? Outlook VBA and Custom Forms 17
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
H Is it possible to create a view that only show the first task in a list? Using Outlook 1
H Is It Possible to See Who Has Viewed My Calendar in Exchange? Using Outlook 2
C in outlook 2007-Contact Group-One name have 3 mail id-its possible? Using Outlook 3
J convert .pst to .eml, how is it possible? Using Outlook 1
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
M Is it possible to restore deleted webmail to server? Using Outlook 3
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
D is it possible to have both a POP and IMAP account in Outlook 2013? Using Outlook 5
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Possible to link to ics file without importing? Using Outlook 4
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
B Is it possible with Outlook form Outlook VBA and Custom Forms 5
Steve Jacobs Possible to configure TNEF options based on *sender*? Exchange Server Administration 3
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
E Show field from account on contact form - possible? BCM (Business Contact Manager) 1
A Possible to modify people preview window? Using Outlook 1
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
C Is it possible: List of URL fields BCM (Business Contact Manager) 0
D Frequently used response short cut possible macro Using Outlook 1
Commodore Exporting all contacts to VCF files possible? Using Outlook 4
M I'd like to alter the appointment balloons. Possible? Calendar Printing Assistant 6
J Is it possible to highlight a folder in Outlook 2007? Using Outlook 2
L I want ONE calendar if possible with no overlaying Using Outlook 1
S possible to access my PST file on the Internet Using Outlook 2
N Outlook Rules - is this possible? Using Outlook 3
G Possible to create reports that return contacts based on account criteria? BCM (Business Contact Manager) 0
N Citrix installation possible? BCM (Business Contact Manager) 1
T Is it possible to hide a mailbox but still send on the behalf of. Exchange Server Administration 1
D Is it possible to set up an email rule for a user based on alias address? Exchange Server Administration 3
K Possible to have a calendar which defaults to no reminder? Using Outlook 3
