Beginner Needs VBA Help in Modifying Code
C
Cody
I am using Outlook 2003 and want to do the following:
Email received between 6 pm to 9 am is forwarded to zyx@123.lyz
Email received between Friday @ 6pm to Monday @ 9 am is forwarded to
zyx@123.lyz
Email received between 9am to 6pm is forwarded to abc@123.lyz
I have looked on the web and found the following code on the MS website; but
unfortunately I am not sure where I am suppose to modify it. If you can
give me any guidance, I would appreciate it.
Public WithEvents myOlItems As Outlook.Items
Public Sub Application_Startup()
' Reference the items in the Inbox. Because myOlItems is declared
' "WithEvents" the ItemAdd event will fire below.
Set myOlItems = Outlook.Session.GetDefaultFolder(olFolderInbox).Items
Private Sub myOlItems_ItemAdd(ByVal Item As Object)
' If it's currently not between 9:00 A.M. and 5:00 P.M.
If Time() < #9:00:00 AM# Or Time() > #5:00:00 PM# Then
' Check to make sure it is an Outlook mail message, otherwise
' subsequent code will probably fail depending on what type
' of item it is.
If TypeName(Item) = "MailItem" Then
' Forward the item just received
Set myForward = Item.Forward
' Address the message
myForward.Recipients.Add "myaddress@mydomain.com"
' Send it
myForward.Send
Thanks...Cody
JP
I responded to this exact question yesterday, see
http://groups.google.com/group/micr.../browse_thread/thread/f4f24cb355cac433?hl=en#
--JP
> Email received between 6 pm to 9 am is forwarded to z...@123.lyz
> z...@123.lyz
> Email received between 9am to 6pm is forwarded to a...@123.lyz
> End Sub
>       ' of item it is.
>          myForward.Recipients.Add "myaddr...@mydomain.com"
>          ' Send it
>          myForward.Send
>       End If
>    End If
> End Sub
> Thanks...Cody
Michael Bauer
There's already the code for items received between 5pm and 9am. If you want
to add another condition, you can use the ElseIf statement like this:
If ... Then
ElseIf ... Then
Best regards
Michael Bauer
Am Thu, 24 Sep 2009 09:54:01 -0700 schrieb Cody:
> zyx@123.lyz
but
> End Sub
> ' of item it is.
> ' Send it
> myForward.Send
> End If
> End If
> End Sub
> Thanks...Cody
N Beginner - Setting SMTP settings/travelling Using Outlook 4
lotsbg Loads of junk in second email needs fixing Using Outlook 1
R Narcotics Police Officer Needs help Using Outlook 1
Y Changing colour of selection bar in Outlook (too light, needs to be grey) Using Outlook 4
J Newbie needs help Outlook VBA and Custom Forms 2
J To-do bar needs to show appointments from multiple calendars Outlook Wishlist 3
Forum Admin What needs fixing in Outlook? Outlook Wishlist 18
