Accessing .pst folder in outlook using VBA Code
Abhijat
Hi group,
I need some help regarding accessing .pst folder using VBA. I want to
replicate the code code below (done for Inbox) for a folder in my .pst
(the path of .pst file is say "C:\Outlook\Personal Folders.pst"
Set ns = appOl.GetNamespace("MAPI")
Set Inbox = ns.GetDefaultFolder(olFolderInbox)
For Each Item In Inbox.Items
Next Item
Any help in this regard with be truly appreciated.
Abhijat
Michael Bauer
If the file isn't opend yet, see the AddStore method. Then the store is
available in the Namespace.Folders collection.
Best regards
Michael Bauer
Am Mon, 12 Oct 2009 09:29:22 -0700 (PDT) schrieb Abhijat:
> Hi group,
> -> -> Next Item
> Abhijat
Abhijat
Hi Michael,
Thanks a lot.
Yes. I can open the .pst file as
ns.AddStore ("P:\Outlook\Personal Folders.pst"). So the code now
becomes:
Its fine till here.
My problem is : my code is not able to point at a sub-folder (call it
"TEST") which is made in the .pst file.
Just to reiterate:
I can have a code that can point at the "Test" sub-folder under my
server Inbox like this:
Set newInbox = Inbox.Folders("Test")
I am looking for a code that may point at the "TEST" sub-folder lying
under my .pst file.
Thanks for your help again!
Best regards,
Abhijat.
On Oct 12, 10:18 pm, "Michael Bauer " <m...@mvps.org
> > Best regards
> Michael Bauer
> > Hi group,
> > -> > -> > Next Item
> > Abhijat-
Michael Bauer
The store has a Folders collection, that's where you start to find your
folders by name.
Unfortunately, AddStore doesn't return the added folder. So, you need to
find it in Session.Folders, maybe by comparing what has been there before
and what's new. You cannot rely on the index.
It's a lot easier with the Redemption (www.dimastr.com). Its AddPSTStore
function does return the added store.
Best regards
Michael Bauer
Am Tue, 13 Oct 2009 03:46:52 -0700 (PDT) schrieb Abhijat:
> Hi Michael,
> Thanks a lot.
> becomes:
> Its fine till here.
> Just to reiterate:
> under my .pst file.
> Best regards,
> Abhijat.
>> > > Best regards
> > Michael Bauer
> >> Hi group,
> >> -> >> -> >> Next Item
> >> Abhijat-
Abhijat
Hi Michael,
Thanks a lot.
I think I need to work on my skills before I can use your suggestion.
Once again, thanks a lot for your time and guidanace.
Best regards,
Abhijat.
On Oct 13, 9:14 pm, "Michael Bauer " <m...@mvps.org
> folders by name.
> > Best regards
> Michael Bauer
> > Hi Michael,
> > Thanks a lot.
> > becomes:
> > Its fine till here.
> > Just to reiterate:
> > under my .pst file.
> > Best regards,
> > Abhijat.
> >> > >> Best regards
> >> Michael Bauer
> >>> Hi group,
> >>> -> >>> -> >>> Next Item
> >>> Abhijat-
RBLampert Accessing Outlook accounts from multiple computers Using Outlook 8
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
J Accessing calendar items for Resource Mailboxes Outlook VBA and Custom Forms 2
J Accessing Hotmail accounts with Outlook 2016 Using Outlook 3
n2b Accessing Plain Text Draft Without Outlook Using Outlook 3
G Issues with accessing Outlook Contact Picture with VBA Outlook VBA and Custom Forms 4
M Accessing ExpiryTime property Outlook VBA and Custom Forms 1
C Problem accessing events for folder "username" Server Threw Exception Calendar Printing Assistant 1
P accessing custom task pane with Outlook ActiveInspector Using Outlook 1
mikecox Accessing Outlook on my Win7 desktop from Win8 laptop Using Outlook 1
A "Unable to display the folder" error when accessing Group mailbox Using Outlook 0
Commodore Accessing mail from multiple devices Using Outlook 1
S Programmatically accessing Outlook Calendar data Using Outlook 1
E Accessing User Defined Fields in BCM Database part 2 BCM (Business Contact Manager) 0
E [SOLVED] Accessing User Defined Fields in BCM Database part 1 BCM (Business Contact Manager) 9
K trying to sync my samsung galaxy to my outlook 2010 calender. it says execution privilege prevents me from accessing outlook Using Outlook 1
P time delay between accessing Outlook file folders, up 20+ second delay Using Outlook 1
S Accessing source information Using Outlook 1
J After Window update of 12/15/2010, outlook 2007 gives error (0x800CCC18) when accessing gmail using Using Outlook 6
S Outlook 2010 freezes and not responding when accessing, moving or deleting files Using Outlook 2
N Problems accessing network files via OWA Using Outlook 5
J Problems accessing console of Exchange 2010 on Windows Server 2008 R2 Please help me Exchange Server Administration 4
R Accessing folder 'Other Contacts' Outlook VBA and Custom Forms 1
E Accessing a Form Region from an Inspector Outlook VBA and Custom Forms 3
D Accessing Global Address List details with VBA Outlook VBA and Custom Forms 1
H Accessing a control on a frame in Outlook with VBScript Outlook VBA and Custom Forms 1
K Programmatically accessing Outlook properties Outlook VBA and Custom Forms 3
K assistant accessing from her home computer BCM (Business Contact Manager) 2
J Outlook closes when accessing History in BCM BCM (Business Contact Manager) 4
B Accessing Outlook 2003 Signature Programmatically using C# Outlook VBA and Custom Forms 6
L Outlook Forms-Accessing Outlook VBA and Custom Forms 1
C Accessing _RecipientControl1 (Assigned To) Outlook VBA and Custom Forms 2
K Accessing contact's custom properties in a Outlook 2007 form region Outlook VBA and Custom Forms 1
V Outlook custom form - installing and accessing Outlook VBA and Custom Forms 1
A Daily hours of recurring/ multi-day appts, & accessing mult calend Outlook VBA and Custom Forms 2
R New users creating get page cannot be displayed when accessing OWA Exchange Server Administration 16
K Export Folder to PST Outlook VBA and Custom Forms 2
HarvMan Outlook 365 PST Report Using Outlook 1
P PST file is getting huge under POP 3 Using Outlook 2
