Restrict throwing 'Condition is not valid' error
Mark McGinty
Greets,
Out of the thousands of installed copies of our AddIn, exactly one throws an
error when we call Restrict aginsts the items collection of the default
contacts folder. The filter expression is static, and is as folllows:
[MessageClass] <> 'IPM.DistList'
Since it works as expected on every other machine, I can't imagine how this
might be a problem in my code, because I can't imagine how this condition
would be invalid in any folder.
The system is Outlook 2003, connected to Exchange, using CEM. I asked the
user to perform an advanced search using the same criteria on this machine,
he said it returned the items he expected.
The user logged-into Exchange from another machine, and our AddIn ran
against his contacts without errors. The user said he forced the .OST to be
regenerated on the problem machine, he said it didn't change the problem.
Anyone ever seen this, or have an idea what might cause it? I'm thinking
Outlook might need to be reinstalled, but I don't want to suggest that
frivolously.
TIA,
Mark
Sue Mosher [MVP]
Is there a possibility that this machine is set to use Outlook in a language
other than English?
Sue Mosher
"Mark McGinty" wrote:
> Greets,
> frivolously.
> TIA,
> Mark
Karl Timmermans
Outlook 2013 32 bit
What is the exact error that is being thrown? (We apply the exact same
filter in our products and have never run across this as an issue so curious
as to what the error is that you're running into)
For what it's worth given your description being that it works accessing
same account from a different machine which indicates that the folder
contents are valid - would try the following:
#1) do a detect and repair on problem machine (but really don't see
how this would affect filtering on a single message class)
#2) have the user connect to the account in "non-cached" mode to see
if the problem persists
Message classes are not language dependant so that wouldn't be the cause.
Karl
________________
"Mark McGinty" <mmcginty@spamfromyou.com> wrote in message
news:eSHH2J2UKHA.5368@TK2MSFTNGP02.phx.gbl...
> Greets,
> an error when we call Restrict aginsts the items collection of the default
> this might be a problem in my code, because I can't imagine how this
> condition would be invalid in any folder.
> machine, he said it returned the items he expected.
> be regenerated on the problem machine, he said it didn't change the
> problem.
> frivolously.
> TIA,
> Mark
Mark McGinty
"Sue Mosher [MVP]" <suemvp@gmail.com> wrote in message
news:123BB3DF-4855-492D-AD8C-5AB79149FED0@microsoft.com...
> language
> other than English?
Hi Sue,
Did I ever send you a WTG note about your book? (You may recall helping me
a couple of years ago, and I bought a copy of your book to keep a clear
conscience.) If not, nicely done, concise yet sufficiently detailed; a
useful reference without a doubt! (My intentions are always golden when I
decide to send such notes; follow-through could use some work.) :)
Anyways, I can't say no possibility but I think it unlikely, the PC is in
the US, in email replies from this box, the header that describes the
original email are generated in English, date format is US... make that
highly unlikely.
But for argument's sake, what if it is? OOM property names aren't
language-specific, right?
Mark
> Sue Mosher
> > Greets,
> > an
> > this
> > the
> > machine,
> > be
> > frivolously.
>> TIA,
> > Mark
Mark McGinty
"Karl Timmermans" <karl@claxton.com> wrote in message
news:uUfuc24UKHA.4360@TK2MSFTNGP04.phx.gbl...
> curious as to what the error is that you're running into)
The exact error is:
Description: Condition is not valid.
Number: -451805175
He did that on his own, no affect.
Hmm... I've already scheduled him some more time on the proverbial
treadmill, I asked him to create another user login, connect Outlook to
Exchange, etc to see if the problem is machine wide or user profile
specific. I'll add that to his exercises... but I hope that's not it, we
need CEM.
Mark
> Karl
> ________________
> > Greets,
> > default contacts folder. The filter expression is static, and is as
> > folllows:
> > the user to perform an advanced search using the same criteria on this
> > problem.
> > frivolously.
>> TIA,
> > Mark
Karl Timmermans
Outlook 2013 32 bit
Given that the most salient item in this problem is that it occurs only on
one machine - logic dictates that the issue is configuration related so
having just stated the obvious.......if this scenario was reported to us,
the key things we'd be asking/looking at/for would be:
1) Did this ever work on this machine? If it did, what was installed between
the time it worked and the time it stopped?
2) What add-ins exist on this machine that don't exist on others - active or
not? Simply disabling an addin doesn't preclude potential issues that could
result simply from it (and any of its related components) being installed.
3) Even for same add-ins - are these all at the same version level?
4) What Outlook related 3rd party software is installed on this machine
versus the others (if any)? For that matter, what 3rd party stuff has been
installed previously that may have been uninstalled? (i.e. for the
possibility that something has replaced the mapi dlls with a customized
version)
5) Further to item#4 - are the mapi dlls the same version on all machines?
Some "shot in the dark" - background questions:
6) What are you using to filter - OOM? CDO? Redemption? That's a strange
error number that doesn't seem to show up anywhere.
7) Are there any PDLs in this account? If yes, can they be opened normally
via Outlook on the problem machine. If no, if one was created - does the
issue still exist?
Karl
________________
news:e5ETwJAVKHA.1372@TK2MSFTNGP02.phx.gbl...
> The exact error is:
> Number: -451805175
> need CEM.
> Mark
>> Karl
> > ________________
> >> Greets,
> >> throws an error when we call Restrict aginsts the items collection of
> >> the default contacts folder. The filter expression is static, and is as
> >> folllows:
> >> to be regenerated on the problem machine, he said it didn't change the
> >> problem.
> >> thinking Outlook might need to be reinstalled, but I don't want to
> >> suggest that frivolously.
>>> TIA,
> >> Mark
L Restrict accepted appts to specific calendar Using Outlook 2
oliv- .RESTRICT returning birthdays regardless of the filtering date Outlook VBA and Custom Forms 8
M Using .Restrict with a UserProperty in an Exchange folder Outlook VBA and Custom Forms 4
JorgeDario restrict access to a certain folder with vba Outlook VBA and Custom Forms 3
JorgeDario How to restrict the creation of new folders? Outlook VBA and Custom Forms 2
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
V How to restrict users to not change Download Headers only Using Outlook 2
L Restrict group creation in Outlook Using Outlook 4
J Restrict info in Contacts Using Outlook 1
E how to restrict user to change pop account settings Using Outlook 1
A Restrict users to 1 computer at a time. Using Outlook 1
M unable to open PDF or (http, www or utube) link attachment to outlook messages because of ' RESTRICT Using Outlook 1
S Restrict method question on email. What am I doing wrong? Outlook VBA and Custom Forms 2
M Restrict Appointments by EntryID not working Outlook VBA and Custom Forms 1
S Send email from excel based on a condition (outlook 2007) Outlook VBA and Custom Forms 1
D Outlook Rules - How to use a variable in the subject condition Outlook VBA and Custom Forms 9
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
W Filter condition "contains"/"doesn't contain" doesn't always work Using Outlook 10
S the folder condition is necessary in Outloook VBS Outlook VBA and Custom Forms 8
M Auto-color all Calendar items based on condition: Private Using Outlook 6
F Create a rule that requires the message be 'read' as a condition for action. Using Outlook 1
J change "OR" condition to "AND" in "specific words" rules Using Outlook 1
P Outlook 2010 Rules: Need a condition for time of day Using Outlook 2
