How to Sort by Unread and then Read mail in Outlook 2007
At College
In Outlook 2007 on exchange server, I want messages sorted so that the unread
ones are at the top of the list and read ones after that. Within each group
of unread and read messages, I want them sorted by date-newest first. I can
add the read field with Field Chooser, but cannot sort by it - when clicking
on the icon I get a " You cannot sort by this field" message.
I know how to use the search folder to list unread messages or the Current
view box on the Advanced toolbar. But I want the entire message list, not
just the unread ones.
Brian Tillman
"At College" <AtCollege> wrote in message
news:B719F268-638F-4744-BEB3-8965C22DA3A6@microsoft.com...
> unread
You cannot group by date and by Read and you cannot sort by Read. In short, I
don't think you can get what you want, which appears to be grouped by date and
then by Read.
Motley
I wonder why this is not a valid way of sorting messages as it is extremely
useful if you want to sort by date in ascending order but still keep your
unread emails at the top of the list. I sure hope Microsoft plans on adding
this ability as I know several people who would prefer to sort that way. If
there is an issue with sorting by read/unread status then there should at
least be an option to keep unread email at the top regardless of your sorting.
> > unread
> then by Read.
C
censoredsoft
How is this not a feature?
The data is recorded somewhere as we can see columns for read but the UI
isn't capable of doing this sort. Being a developer I'm sure there is a
logical programmatic reason as UI people took the time to say "hey, this
isn't possible"
By why?
> > > unread
> > then by Read.
Bob I
You have an Unread message folder already.
> isn't possible"
> By why?
> >>>unread
> >>then by Read.
GeorgeRC
After reading this thread and getting frustrated (there isn't an Unread messages folder in Outlook 2007). I went to View > Current View and selected "Unread Messages in this folder". That gave me the 4 unread messages I have been trying to track down (including one very old one). I hope this helps others. :D
Forum Admin
There is an unread search folder - if its not in the Search folder, you can make a new search folder. (It's a predefined search folder).
dan man
To choose a different starting folder in Outlook, go to Tools, Options, and select the Other tab.Then click theAdvanced button under the General section. In the Advanced Options window, click the Browse button to access the menu of Outlook folders. You can choose from any Outlook folder, including ones you have created. To select the To Do list, scroll to the very top of the list, select it and click OK.
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
King Mustard Sort search groups by amount of items? Using Outlook 1
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
Diane Poremsky Sort messages by Sender domain Using Outlook 1
J Can I sort meeting requests by the date of meeting? Using Outlook 4
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
L Sort bar at top of inbox preview outlook 2013 Using Outlook 1
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
D Contacts Sort Order Using Outlook 0
kburrows Office 365 - Contacts Sort First, Last instead of Last, First. How to Reset? Using Outlook 4
I 2013 Calendar sort date Using Outlook 3
J outlook having sort by date or from unable to display sender name. Using Outlook 2
J Macro to periodically sort emails by flag status? Using Outlook 1
2 Sort taks by folder then by date? Using Outlook 5
S Outlook 2007 Sort Column Shading Using Outlook 1
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
D Sort e-mail by sender's domain - Outlook 2007 Using Outlook 2
B outlook sort by Using Outlook 2
A Sorting of existing contact in Outlook 2003 just will not sort Using Outlook 2
J Outlook 2010 Inbox sort FROM column not working Using Outlook 29
S changing number sort BCM (Business Contact Manager) 1
B Macro to Change sort and collapse groups in Mail folder Outlook VBA and Custom Forms 9
L Interating throught a task list, respecting sort rules in the view Outlook VBA and Custom Forms 1
S How do i sort email by Domain? Outlook VBA and Custom Forms 2
K sort over flagstatus Outlook VBA and Custom Forms 4
T E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
J Old unread emails on current date (MDaemon Server) Using Outlook 1
S Mark as Unread unless Categorized by Color Using Outlook 0
C Unread email count not displaying on Inbox sub-folders Using Outlook 0
F Automatically close email after selecting mark unread Using Outlook 1
B Unread Undead Using Outlook 1
Commodore Message becomes "unread" after moving to a local folder Using Outlook 2
