SQL Server Setup failed - Please help?!
Ramscove
Microsoft SQL Server 2005 9.00.2047.00
OS Version : Microsoft Windows XP Professional Service Pack 3 (Build
2600)
Time : Tue Nov 10 16:04:35 2009
Machine : FAMILY-F52DE565
Product : Microsoft SQL Server Setup Support Files (English)
Product Version : 9.00.2047.00
Install : Successful
Log File : c:\Program Files\Microsoft SQL Server\90\Setup
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_SQLSupport_1.log
------------------------------------------------Machine : FAMILY-F52DE565
Product : Microsoft SQL Server Native Client
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_SQLNCLI_1.log
Product : Microsoft SQL Server VSS Writer
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_SqlWriter_1.log
Product : MSXML 6 Service Pack 2 (KB954459)
Product Version : 6.20.1099.0
Install : Failed
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_MSXML6_1.log
Error Number : 1603
------------------------------------------------SQL Server Setup failed. For more information, review the Setup log file in
%ProgramFiles%\Microsoft SQL Server\90\Setup Bootstrap\LOG\Summary.txt.
Time : Tue Nov 10 16:06:28 2009
List of log files:
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_Core(Local).log
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_Datastore.xml
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_.NET Framework 2.0.log
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_Support.log
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_Core.log
c:\Program Files\Microsoft SQL Server\90\Setup Bootstrap\LOG\Summary.txt
Bootstrap\LOG\Files\SQLSetup0002_FAMILY-F52DE565_SCC.log
MikeInMiami
> 2600)
> ------------------------------------------------------------------------------> Machine : FAMILY-F52DE565
> Install : Failed
> Error Number : 1603
> ------------------------------------------------> SQL Server Setup failed. For more information, review the Setup log file in
> List of log files:
I had the same problem on one of my employees computer. I ended up calling
microsoft. A guy in India took control of the computer and tried everything.
after 1.5 hours he ended up uninstalling SQL by hand by going into the
registery. he then reinstalled SQL and BCM and it worked fine. Cost me $49
flat fee and was worth every penny.
Rajesh Rao
On Nov 10, 11:42 am, Ramscove <Ramsc...
wrote:
> MicrosoftSQLServer2005 9.00.2047.00
> 2600)
> Product         : MicrosoftSQLServerSetup Support Files (English)
> Log File        : c:\Program Files\MicrosoftSQLServer\90\Setup
> ---------------------------------------------------------------------------­---> Machine         : FAMILY-F52DE565
> Product         : MicrosoftSQLServerNative Client
> Product         : MicrosoftSQLServerVSS Writer
> Install         : Failed
> Error Number    : 1603
>  SQLServerSetup failed. For more information, review the Setup log filein
> %ProgramFiles%\MicrosoftSQLServer\90\Setup Bootstrap\LOG\Summary.txt.
> List of log files:
>         c:\Program Files\MicrosoftSQLServer\90\Setup Bootstrap\LOG\Summary.txt
Can you post the error that you aer getting in the log file, may be
that would do some help. As Mike has said, you can also remove sql
server, clean the registry and try installing it again from your side.
If that works, definitely that is goind to save a few bugs.
Rajesh
K BCM on SQL Server 2012? BCM (Business Contact Manager) 7
P Installation BCM impossible due to untraceable old SQL-server remains BCM (Business Contact Manager) 6
O x86 vs. x64 Sql Server 08 Dbase Questions BCM (Business Contact Manager) 2
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
P BCM 2013, Microsoft SQL Server 2008 R2 (SP2), attachment issue n database size BCM (Business Contact Manager) 2
M BCM in Outlook reports maximum database size to 4GB despite SQL Server 2008 R2 BCM (Business Contact Manager) 1
M "No database found" but successful connection to SQL server.What am I missing? BCM (Business Contact Manager) 5
J Moving BCM 2007 Database to a SQL 2005 Server BCM (Business Contact Manager) 2
V Business Contact Manager 2007 and SQL Server 2008 BCM (Business Contact Manager) 3
V Connecting BCM 2007 to SQL Server 2007 BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
C Cannot seem to use BCM Database Tool on SQL Server 2008 BCM (Business Contact Manager) 4
S will SQL 2003 work for remote server BCM (Business Contact Manager) 1
D 2003 Outlook with BCM SQL server failure BCM (Business Contact Manager) 1
J BCM Database and SQL Server Issues? BCM (Business Contact Manager) 7
D Outlook 2007 BCM SQL server problem BCM (Business Contact Manager) 1
D Installing SQL Server 2008 Express with BCM installed BCM (Business Contact Manager) 3
D Install SQL on a remote server for 2003? BCM (Business Contact Manager) 1
V Unable to Install Microsoft SQL Server 2005 express BCM (Business Contact Manager) 2
daveTQM Sync address book / contacts to SQL / Azure Exchange Server Administration 1
H SQL update column BCM (Business Contact Manager) 0
J Install BCM Client without an local SQl Database BCM (Business Contact Manager) 6
crazyboy SQL 2014 and BCM BCM (Business Contact Manager) 1
D What is this SQL filter that is applied to my Inbox? Using Outlook 6
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
B How to create the customized Outlook SQL DASL for selected days? Outlook VBA and Custom Forms 2
M How to connect to SQL DB from outlook programmatically? Outlook VBA and Custom Forms 1
O transfer BCM SQL data without backup BCM (Business Contact Manager) 1
H Outlook 2007 SQL syntax to filter views of tasks and todo items Outlook VBA and Custom Forms 1
M Outlook / BCM / SQL 2005 Express Windows 7 BCM (Business Contact Manager) 3
S BCM install fails at SQL install BCM (Business Contact Manager) 1
M Grab info from attachment and put into SQL db Outlook VBA and Custom Forms 1
J pulling SQL records Outlook VBA and Custom Forms 1
E Display Outlook Data from more than one Folder like SQL JOIN Outlook VBA and Custom Forms 3
N Can I install BCM client without SQL Express? BCM (Business Contact Manager) 1
D 1 user account not working - SQL Permissions BCM (Business Contact Manager) 1
J Microsoft SQL control within custom form Outlook VBA and Custom Forms 1
M MSO OL sp2 for BCM broke SQL Database connection BCM (Business Contact Manager) 2
K Auto-linking emails by default shared DB BCM 2007 on SQL 2008 BCM (Business Contact Manager) 4
B IMAP server rejects sent email - cannot deliver messages Using Outlook 2
C Pop Server Changing Verizon/Aol to Yahoo Using Outlook 6
icacream Outlook 2016 “Enter your user name and password for the following server.” Using Outlook 5
R Outlook 365 update sets delete from server flag Using Outlook 2
J Importing N2K from a different Exchange Server Using Outlook 1
