Custom rule to filter on sender name
P
Philip Beaurline
I am getting a lot of spam with things like "viagra" and "cialis" in the
sender name, where the sender address changes constantly. I'd like a rule to
filter on this. Can anyone tell me how?
Philip
Michael Bauer
Create a rule for specific words in the text, there's no need for VBA.
Best regards
Michael Bauer
Am Wed, 11 Nov 2009 08:23:08 -0800 schrieb Philip Beaurline:
to
> Thanks
> Philip
P
Philip Beaurline
Thanks for your reply.
I do have rules for the sender address, subject, message header and message
body, but they don't catch words in the SenderName field. I am trying to
cobble together a custom rule but my VBA skills are next to nothing.
> > Best regards
> Michael Bauer
> to
> > Thanks
> > Philip
Michael Bauer
The message header should do it.
Best regards
Michael Bauer
Am Thu, 12 Nov 2009 06:27:02 -0800 schrieb Philip Beaurline:
message
>> > > Best regards
> > Michael Bauer
rule
> > to
>>> Thanks
> >> Philip
P
Philip Beaurline
Well I thought so too. Something is apparently blocking the rule from reading
the SenderName in the header. I tested this by creating a rule that
successfully detected part of the email address, but my Sender Name rule
would not detect anything in SenderName. Hence my quest to make a custom
rule. Is there something I am missing?
Thanks for your help with this.
> > Best regards
> Michael Bauer
> message
> >> > >> Best regards
> >> Michael Bauer
> rule
> >> to
> >>> Thanks
> >>> Philip
P
Philip Beaurline
Oh nevermind. I just figured out that the rule filter words are case
sensitive. Argh.
> > > > Best regards
> > Michael Bauer
> > message
> > >> > > >> Best regards
> > >> Michael Bauer
> > rule
> > >> to
> > >>> Thanks
> > >>> Philip
I Create custom Outlook 2013 Rule in Office 365 Outlook VBA and Custom Forms 5
S Creating custom rule to move if "NAME" is in body but ignore the phrase "Hi NAME" in the search Using Outlook 2
D Custom Cc rule Using Outlook 1
L Creating Custom Rule to Forward emails to a BCC Using Outlook 1
D Running a Program from Custom Action Rule Outlook VBA and Custom Forms 1
Q How do I create a custom action for a rule? (Save as "Nfy.MSG") Outlook VBA and Custom Forms 1
E Custom formula for columns Using Outlook 3
