Business Contact Manager for Outlook Problem
Daniela
I have Windows Vista and just upgraded my office from 2000 to 2007 because my
outlook did not work anymore. Now after loading 2007, as I open Outlook, I
get an immediate message: BCM:Cannot complete selected action due to external
error. If I click ok, BCM stops working and then when I try to enter a task,
I get another error: messaging interface has returned an unknown error. I
didn't even buy the Office with BCM, it just came with it - now I wish I
didn't have it. PLEASE HELP ME!!!
DL
If you dont want to use BCM just uninstall it via Add/Remove its a seperate
entry "BCM"
And if you upgraded an existing Outlook / Office 2k installation, create a
new Mail Profile - not copy the old
"Daniela" <Daniela> wrote in message
news:FCDDA102-C271-49BB-94B9-7217A5D34D97@microsoft.com...
> my
> I
> external
> task,
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
C Business Contact Manager Using Outlook 3
O Calendar and business contact manager Using Outlook 0
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
M Looking for trainer in Business Contact Manager BCM (Business Contact Manager) 0
M Queries on Business Contact Manager (BCM) with Outlook 2013 Using Outlook 1
V Custom UI Runtime Error in Business Contact Manager for Outlook (2013) BCM (Business Contact Manager) 6
R "business contact manager logon failure server is in single user mode" - HELP! BCM (Business Contact Manager) 4
P Business Contact Manager without Exchange? BCM (Business Contact Manager) 1
G Sharing Business contact manager BCM (Business Contact Manager) 5
T Merging multiple Business Contact Manager files BCM (Business Contact Manager) 0
U business contact manager add in Using Outlook 1
M Business Contact Manager Marketing Campaign default address BCM (Business Contact Manager) 0
S Business Contact Manager (BCM) causing Outlook crash loop BCM (Business Contact Manager) 3
K Business Contact Manager add-on for Windows 7 Professional Plus? BCM (Business Contact Manager) 3
A Can Business Contact Manager be downloaded seperately? BCM (Business Contact Manager) 1
D Downloaded ultimate 2007 - Can't Find Business Contact Manager BCM (Business Contact Manager) 1
A Business Contact Manager Error BCM (Business Contact Manager) 1
D business contact manager did not install with outlook 7 BCM (Business Contact Manager) 2
H I have installed Business Contact Manager but cannot find to use BCM (Business Contact Manager) 1
N Business Contact Manager - Ability to use BCM (Business Contact Manager) 8
C "Business Contact Manager for Outlook could not connect to db BCM (Business Contact Manager) 1
J outlook 2003 business contact manager BCM (Business Contact Manager) 1
C Moving Business Contact Manager to Pro Plus, dropping Accounting BCM (Business Contact Manager) 1
R My email merge/business contact manager fields are not populating BCM (Business Contact Manager) 1
C Business Contact manager wont open BCM (Business Contact Manager) 1
N How do you share your business contact manager with coworkers BCM (Business Contact Manager) 1
A Microsoft Office 2003 Business Contact Manager and Windows 7 BCM (Business Contact Manager) 1
C Outlook Business Contact Manager Beta Not Working BCM (Business Contact Manager) 2
G Training on Business contact manager BCM (Business Contact Manager) 1
R RE: Business Contact manager failed to install BCM (Business Contact Manager) 1
C Business Contact Manager BCM (Business Contact Manager) 2
C Business Contact Manager 2007 - Windows 7 BCM (Business Contact Manager) 1
T sequential project numbers in Business Contact Manager BCM (Business Contact Manager) 2
M Is Business Contact Manager gone in Outlook 2010? Outlook VBA and Custom Forms 2
J how do i rename the default fields in MS Business Contact manager BCM (Business Contact Manager) 1
P How Do I Download Business Contact Manager BCM (Business Contact Manager) 1
N Outlook categories for Business contact manager BCM (Business Contact Manager) 2
S My business contact manager base cannot contact my database. BCM (Business Contact Manager) 1
L cant view the history section in business contact manager BCM (Business Contact Manager) 1
S Business Contact Manager 2007 won't install with Windows 7 BCM (Business Contact Manager) 3
R Outlook 2007 w/ Business Contact Manager compatible w/ Cardscan? BCM (Business Contact Manager) 1
D Can not restore database in business contact manager BCM (Business Contact Manager) 1
T History Reports in Business Contact Manager 2007 BCM (Business Contact Manager) 1
C Missing Business Contact Manager BCM (Business Contact Manager) 2
E Where is Business Contact Manager?? BCM (Business Contact Manager) 2
B How to remove user from business contact manager for outlook 2007database tool(BCM) BCM (Business Contact Manager) 2
