Mark as read
Joanne Buss
I am using outlook 2003 on winxp pro machine
I have some vba coding that I use to strip the attachments off my email and
place them into a specific folder. This is running fine, but I would like to
fine-tune it a bit. Not sure how to do it and cannot find anything in my
2003 outlook vba book or when I google it, so here I am again.
Here is my question
Can I mark these emails as having been read during/after I have stripped the
attachment off of them. They have never been clicked on so they never get
marked as having been read which can become a bit confusing when the number
of emails is rather high and there are several days' worth.
If anyone has any ideas or can point me in the right direction, I would sure
appreciate the help.
Joanne
Michael Bauer
See the Unread property of the item.
For learning what properties are available the object browser (f2) is very
good: Switch from <All Librares> to Outlook, then left hand select the
object you're interested in.
Best regards
Michael Bauer
Am Mon, 16 Nov 2009 21:24:22 -0600 schrieb Joanne Buss:
and
to
> Here is my question
the
number
sure
> Thanks
> Joanne
Joanne
Thanks for the pointers
> > Best regards
> Michael Bauer
> and
> to
> > Here is my question
> the
> number
> sure
> > Thanks
> > Joanne
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
M How do I mark emails already received as read when I get a second, different email based on subject? Outlook VBA and Custom Forms 3
Z Mark moved copies as "Read" Using Outlook 19
Z "Mark All as Read" in Outlook 2007 extremely slow Using Outlook 1
H mark as read per folder options Using Outlook 1
A Mark all as read for public folders Using Outlook 14
N Changing the 'Mark item as read when selection changes' at runtime Outlook VBA and Custom Forms 1
B Move Sent Email to archival pst folder and mark as read - HOW TO Outlook VBA and Custom Forms 2
B Mark copy of sent email as read - VBA? Outlook VBA and Custom Forms 3
M Mark as read Outlook VBA and Custom Forms 5
T Setting a delegate to not mark items as read Using Outlook 9
O Office 365 Outlook - mark to download Using Outlook 0
S Codes for "Mark Complete" the task Outlook VBA and Custom Forms 2
S Mark as Unread unless Categorized by Color Using Outlook 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
F Automatically close email after selecting mark unread Using Outlook 1
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
7 Macro to mark message as junk and delete Outlook VBA and Custom Forms 3
V Mark BCC when emails is sent from specific account Outlook VBA and Custom Forms 2
B Outlook 2010: how to mark messages without opening? Eg for deletion Using Outlook 2
N Mark or follow up emails in shared mailbox Using Outlook 2
C Outlook 2010 search for question mark in calendar Using Outlook 7
M Can't mark appointments as private for other user Using Outlook 1
I Pound Symbol in emails show as � (black diamond with white question mark inside) - Office 2010. Using Outlook 11
J Pasting into Outlook 2003 produces blue question mark Using Outlook 2
R Macro to mark item unread Outlook VBA and Custom Forms 2
L Email Read and Delete Outlook VBA and Custom Forms 4
Diane Poremsky Edit and Save Outlook's Read-Only Attachments New Slipstick.com Articles 0
Rupert Dragwater Some mailboxes show deleted items as not read Using Outlook 5
Mary B Outlook 2013: Rule for copying new email to folder & marking that copy as read Using Outlook 1
