CustomTaskPane in PLace of Reading Pane
E
escamoteur
I just added a CustomTaskPane to my Exlorer window (Outlook 2007, COM Addin C#)
It works, but it strechtes ober the whole witdh of Outlook and not only below the Explorer View as the standard preview pane.
Is it possible to make the CustomPane look like a preview pane? Like it's now it just takes too much space.
I just watched a video showing how to use a FormRegion to replace the Preview pane based on the message class in VBA and VSTO. Is
this also possible to do with C# and a com-addin?
Best
Tom
K
Ken Slovak - [MVP - Outlook]
A CTP will be docked at the bottom or sides of the Outlook window. You can't
make it replace only the area the preview pane occupies when preview is
displayed at the bottom.
You can use a form region without using VSTO. Some of my shared addins
written using C# use form regions.
"escamoteur" <mail@burkharts.net> wrote in message
news:711F8469-8FA0-4F49-94D8-EA7B510F819A@microsoft.com...
> Hi,
> Addin C#)
> Preview pane based on the message class in VBA and VSTO. Is this also
> Best
> Tom
E
escamoteur
Do you have any link how to use a form region to replace the preview pane?
Best
Tom
<kenslovak@mvps.org> schrieb im Newsbeitrag news:#Pzsm7NeKHA.5228@TK2MSFTNGP06.phx.gbl...
> > Hi,
> > Addin C#)
>> Best
>> Tom
E
escamoteur
I found out how to do it. But as this Formregion is only displayed when an Item is selected, I think I will go for the Task Panel,
even if it's a bit too big.
Best
Tom
"escamoteur" <mail@burkharts.net> schrieb im Newsbeitrag news:6CFBA85E-6C13-4455-9E95-8F634CEAE706@microsoft.com...
> Best
> Tom
> " - " <kenslovak@mvps.org> schrieb im Newsbeitrag news:#Pzsm7NeKHA.5228@TK2MSFTNGP06.phx.gbl...
> > A CTP will be docked at the bottom or sides of the Outlook window. You can't make it replace only the area the preview pane
> > occupies when preview is displayed at the bottom.
>> You can use a form region without using VSTO. Some of my shared addins written using C# use form regions.
>> "escamoteur" <mail@burkharts.net> wrote in message news:711F8469-8FA0-4F49-94D8-EA7B510F819A@microsoft.com...
> >> Hi,
> >> Is this also possible to do with C# and a com-addin?
>>> Best
>>> Tom
E CustomTaskPane in PLace of Reading Pane Outlook VBA and Custom Forms 3
J Search and In-Place Archiving Using Outlook 0
piusg 2013: Place custom view on the ribbon Using Outlook 3
anoble1 Can you create a rule once an email moves to the Vault Inbox to another place? Using Outlook 0
V Uninstall ONLY Exchange 2010 but leave Exchange 2003 server in place - Public Folders Question Exchange Server Administration 5
R Can not place a .wav file attachment ie a voicemail sent by Vonage as as .wav file Using Outlook 1
E how can i delete automatically mails like 'This request is out of date' and 'Action takes place in the past' Using Outlook 2
B Outlook Calendar in wrong place Using Outlook 2
C duplicat contacts issues__Name does not show in the tasks list but shows everywhere else.__follow up date doe not place contact in task/to do list Using Outlook 5
E Reading Pane has disappeared Using Outlook 1
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
M Outlook 2007: how to narrow the reading pane and the composing pane Using Outlook 0
T Outgoing Messages in the Reading Pane Cannot Be Flagged in Outlook 2013 Using Outlook 6
F Outlook 2007 - Reading Pane Automatically Downloads First/Topmost Message Using Outlook 4
V Reading/Posting in Newsgroups Using Outlook 1
C Contact photos not showing in reading pane in Outlook 2013 Using Outlook 3
T Killing reading pane - "globally" Using Outlook 11
A Received Date None after reading Using Outlook 2
M Viewing Custom Form Fields in the Reading Pane and in Replies Using Outlook 3
P exchange management consoles has stoped working and yes I have read the above article and tried the troubleshooter and spent days reading and trying d Exchange Server Administration 0
M Reading .msg Messages In MS Outlook For Mac 2011 Using Outlook 1
R Reading Pane text appearing all the way to the right... Using Outlook 1
C Change default reading font in Outlook from Times New Roman 12 point to Arial Using Outlook 2
B Reading CompressedRichText field in SQL database BCM (Business Contact Manager) 1
L Windows Instant Search Indexing not working need help reading Event Log Using Outlook 2
D Cursor in reading pane Using Outlook 5
B Huge characters when reading some mails Using Outlook 42
