transfer BCM SQL data without backup
O
OlafR
my old notebook crashed but I sill have the HD (as external). Installed
Outlook 2007 with BCM on the new notebook. Unfo I never made a backup of the
BCM data. How can I transfer the old SQL data into the actual BCM ?
asdfgyh
hi, depending whether this was installed on XP OR VISTA, but in either case
there will be a shadow/backip in the directory. i .e for VISTA, you would
have to enable the "show all hidden files" in the folder option icon in the
view tab, in control panel.
then under OS drive, in the iser directory there an faded folder "appdata"
the under there -- will be 3 more folders, most likely it would be under
first folw "local" -- the look for "microsoft folder" and then BCM, or SLQ
SERVER data... for XP WOULD BE FAIRLY SIMILAR,
HOPE this help,
J WINDOWS EASY TRANSFER does not allow for BCM BCM (Business Contact Manager) 1
M Transfer To New Computer - Lost Some Outlook Functionality Using Outlook 0
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
V Outlook 2013 - transfer autocomplete data Using Outlook 4
Diane Poremsky Transfer POP3 Mail on an iPhone to Outlook New Slipstick.com Articles 7
P Macros in Word 2003 - how to transfer to another Word 2003? Using Outlook 1
E Some Calendars Not Visible After Transfer Using Outlook 2
A Creating rule to create week folder and transfer mail using alert Using Outlook 3
S Anyone know how to transfer Outlook Express "Identities" to Outlook 2010 ... Using Outlook 1
D Unable to transfer rules from one Outlook computer to another Using Outlook 5
S transfer email account settings from Outlook 2007 to 2010 Using Outlook 5
L How do I set up or transfer a distribution list into Global contac BCM (Business Contact Manager) 1
K transfer iphone contacts to microsoft outlook on computer Using Outlook 4
K Outlook 2003 to 2007 data transfer Using Outlook 3
T Transfer Form to other pc's Outlook VBA and Custom Forms 1
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
