Outlook 2007 BCM will not recognize data files
BobN
Situation: I just converted from XP Pro to Win7 Pro (format HD and clean
install). Before installing I copied the Business Contact Manager and
subfolders (MSSmallBusiness.ldf, MSSmallBusiness.mdf)to an external hard
drive.
I copied those files back to
c:\users\<myname>\AppData\Loca\Microsoft\Business Contact Manager.
But Outlook BCM does not recognize these files and I can't use them.
When I try to change the BCM data file using Account Settings|Data
Files|Settings these files do not show up as available on my computer
when I Select an Existing Database.
When I installed Office Prof. Plus 2007 BCM under Win7 I did get an
error message that SQL Server 2005 had compatibility problems with Win7.
Is the problem related to this? Would it help if I upgraded to SQL
Server 2008?
How can I solve this? This BCM database is mission-critical for my business.
BobN
> drive.
> Server 2008?
> business.
> Thanks.
By serendipity I found a solution. I copied the data files into the
correct folder as described above, then installed Office Pro 2007. Upon
starting Outlook asked me to select the existing database and voila, it
loaded.
I can't imagine why MS hasn't posted this problem on the Solutions
website as I've seen many other people with similar problems.
M Adding BCM to Outlook 2007 BCM (Business Contact Manager) 1
F Outlook 2007 BCM Exporting Files BCM (Business Contact Manager) 2
L How do you Recover from An Outlook 2007 & BCM Crash BCM (Business Contact Manager) 1
A Add BCM to outlook 2007 BCM (Business Contact Manager) 1
C Error when installing BCM for outlook 2007 from disk 2 BCM (Business Contact Manager) 3
J BCM 2007 Shutting Down Outlook BCM (Business Contact Manager) 2
P Windows 7 / Outlook BCM 2007 Stability BCM (Business Contact Manager) 1
N Outlook 2007 w/BCM - Email issues BCM (Business Contact Manager) 5
N Email issues since installing BCM with Outlook 2007 BCM (Business Contact Manager) 1
M Outlook 2007 with BCM - Tasks being created automatically BCM (Business Contact Manager) 1
D Outlook 2007 BCM - Win 7 BCM (Business Contact Manager) 1
E Re:BCM failed to install in outlook 2007 due to SQL Server Express 20 BCM (Business Contact Manager) 1
A Outlook 2007 ca+n't find bcm BCM (Business Contact Manager) 1
J Outlook 2007 with BCM - Out of Memory after MSO12 SP2 installation BCM (Business Contact Manager) 4
H How to get BCM in OUtlook 2007 on Vista to detect my MDF file? BCM (Business Contact Manager) 1
D Outlook 2007 BCM SQL server problem BCM (Business Contact Manager) 1
D Outlook 2007 + BCM & SP2 - windows7 ? BCM (Business Contact Manager) 6
K Is it possible to use BCM 2003 with Outlook 2007? BCM (Business Contact Manager) 4
R BCM 2007 no longer showing up within Outlook 2007 BCM (Business Contact Manager) 3
P Outlook 2007 with BCM - Out of Memory BCM (Business Contact Manager) 13
M Outlook 2007 crashes with BCM BCM (Business Contact Manager) 1
K Moving data from Outlook 2007 to Outlook 2007 with BCM BCM (Business Contact Manager) 3
B BCM freezes Outlook 2007 BCM (Business Contact Manager) 3
T Problems re-installing BCM for Outlook 2007 BCM (Business Contact Manager) 2
L Outloook 2007 Ultimate BCM and Outlook Contacts? BCM (Business Contact Manager) 6
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 0
