insert a picture
C
Curt
Am familiar with excel macros not with outlook. Tried to copy and paste a
macro from excel didn't work. Want to have a macro that will insert my
signature with a picture. Can insert the picture with the insert from tool
bar. Is it possible to code a macro to do this instead of the two step
process I now use?
K
Ken Slovak - [MVP - Outlook]
Since they are different applications with different object models Excel
code will obviously will never run as Outlook code.
If this is a fixed signature and a fixed image just create a new signature
in the signature editor and insert it where you want it. There is no object
model for signatures for emails, you'd do it in code in different ways
depending on which version of Outlook you are using and whether or not
WordMail is being used. However, the code gets complicated, so if you have
fixed elements it would be easier just to use the UI.
Go to www.outlookcode.com and search on "signature", you will find quite a
few samples of inserting signatures.
"Curt" <Curt> wrote in message
news:A87448E2-96F8-4E0E-9A19-0A7B492EABA7@microsoft.com...
> process I now use?
> Thanks
R insert picture tab grey Using Outlook 1
S How to insert a picture programatically Outlook VBA and Custom Forms 12
witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
L Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 33
Diane Poremsky Create Task or Appointment and Insert Selected Text New Slipstick.com Articles 0
B Insert Hyperlinks for attachments in Userform Outlook VBA and Custom Forms 5
D Outlook task insert Outlook VBA and Custom Forms 3
K Insert screenshots issue Using Outlook 2
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
L Insert Photo to Contact Using Outlook 23
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
witzker insert Date & Time (HH:mm) no (ss) in userform Using Outlook 6
A insert Date & Time in userform Using Outlook 3
K Macro to insert attachments Using Outlook 1
C Insert a Date Picker for Send Mail Subject Using Outlook 1
C Insert date in Subject through date picker Using Outlook 0
mrje1 Opening a task the Insert Tab Option is not showing up and organizing Tasks Using Outlook 9
H Insert Specific Text before Subject for New mails and reply Using Outlook 3
K Outlook insert clip art, no results found...address book contacts only show up Using Outlook 5
J Form design - how do I insert an automatic date/time field? Using Outlook 2
J How do I view the ruler in an Outlook message and/or insert tabs? Using Outlook 7
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
D Insert Text and Send Outlook VBA and Custom Forms 1
D Re: How do i insert radio buttons in an email Outlook VBA and Custom Forms 1
G How to insert a json array into a calendar events Outlook VBA and Custom Forms 1
K insert text into current position of pointer in mailcompose Outlook VBA and Custom Forms 1
J Insert File Outlook VBA and Custom Forms 2
M Insert a File Outlook VBA and Custom Forms 3
G Task / Insert / Attach Item / Business Contact BCM (Business Contact Manager) 1
M Forward email as insert from button Outlook VBA and Custom Forms 1
B Simple way to insert file text - macro? Outlook VBA and Custom Forms 1
J How do I scan and insert into Outlook 2007? Using Outlook 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
D RE: How do you change the default insert file path in outlook? Using Outlook 11
D Insert Text via Macro in Outlook 2007 Outlook VBA and Custom Forms 2
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
J Command Button to insert Email Signature Outlook VBA and Custom Forms 2
D Macro creation for Outlook insert subject Outlook VBA and Custom Forms 1
F Insert date at cursor location Outlook VBA and Custom Forms 4
T Insert text from file Outlook VBA and Custom Forms 1
S How to create a macro to insert a signature in Outlook 2007 Outlook VBA and Custom Forms 1
T How do i insert a page break in an Outlook e-mail message? Using Outlook 4
