Appointment Body on Custom Page 2- Hide Default Page
N
nuberbc
I need the formatting of the notes/message field but have some other drop
downs that will directly relate to that field. Puttling them on two
different pages makes the custom form much harder to understand. Can the
appointment message/notes field be moved to the custom page so all the
related info is together and I don't have to display the default appointment
page? All the other fields are available from the field chooser.
Seems like I should just be able to drag it from the filed chooser but it is
not available. If I could design the default page with custom fields that
would work too but it doesn't appear you can edit the default P.1.
Sue Mosher [MVP]
In the Field Chooser, that field is called Message or Notes, depending on
the type of item.
Since Outlook doesn't provide any date picker controls, you may find that
designing a custom page with the functionality of the main page is difficult
if not impossible.
Sue Mosher
"nuberbc" <nuberbc> wrote in message
news:DDDF3AF3-384B-428B-A4D9-588E43B8EB99@microsoft.com...
> appointment
> is
> Thanks.
N
nuberbc
Oh, thanks. I had been looking for that all day. It was called Message
under the Frequently Used Fields section. I was looking under the
Appointments sectino for Notes or Body.
I figure the dates can either be typed into the Start and End fields or
modifed by the GUI section of the calendar by dragging. I know I want to
avoid VBA as much as possible. I feel comfortable with it in Excel but not
Outlook.
Whatver I create I have to maintain so I really want to keep it simple.
Thank you for your help; it is greatly appreciated.
> the type of item.
> if not impossible.
> > Sue Mosher
> > appointment
> > is
> > Thanks.
T Custom Appointment Form Message Body Deleted upon reply. Outlook VBA and Custom Forms 3
K Importing appointment body from excel in outlook 2010 Using Outlook 1
B Extract Dates for Appointment Item in Body of email Outlook VBA and Custom Forms 10
R How to format text within appointment/meeting body? Using Outlook 6
O Calendar - appointment templates and categories Using Outlook 1
W Appointment userproperties disappear Outlook VBA and Custom Forms 4
F Appointment Show All Fields Using Outlook 1
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
W Appointment occurrences change the location property Using Outlook 0
K Update Appointment category when changed in Excel Using Outlook 3
A Day view - print appointment details Calendar Printing Assistant 1
R Recover Deleted Appointment in Calendar Using Outlook 0
N Select Appointment subject line from combobox or list Outlook VBA and Custom Forms 1
S Appointment colour categories disappear Using Outlook 4
A Add attachments to appointment based on field values Outlook VBA and Custom Forms 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
G Create an Appointment at the Contact's Address From Email Outlook VBA and Custom Forms 0
Diane Poremsky Create Task or Appointment and Insert Selected Text New Slipstick.com Articles 0
Pierce007 Maps/location in making an appointment Using Outlook 2
A Get shared calendar name or id in custom appointment form Using Outlook 0
Diane Poremsky Create Appointment From Email Automatically New Slipstick.com Articles 0
P Appointment times are off by one minute Using Outlook 1
M receive mail when appointment category changes and create task from appointment Outlook VBA and Custom Forms 0
Diane Poremsky Create an Outlook appointment from an email message New Slipstick.com Articles 4
Diane Poremsky Create an Appointment Diary New Slipstick.com Articles 0
Diane Poremsky Send an Email When You Add an Appointment to Your Calendar New Slipstick.com Articles 0
J Outlook calendar...How to add an event or appointment without a border around it? Using Outlook 9
F Outlook 2010 Search Appointment Notes Using Outlook 0
