How to extract outlook calendar data.
Sindhura
I want to extract the calender data (i.e the data of all the shared
calenders)
I am creating an Add-in for Outlook in Vb.net . I need to read the meetings
between a given duration from a shared calendar. I will give the shared
calendar names ( around 20) with time and i need to know which all calendars
and free and which all are busy at that specific time.
I already tried to read the calendars in a loop and its taking a lot of time
to read each calendar.so i wanted to know if there is a faster way of doing
this.
Can anyone let me know where does this data get stored and how to extract
the same.
I am using outlook 2003.
~ Sindhura
Michael Bauer
With the Redemption library (www.dimastr.com) you can read the data very
fast. There's a lot of help and code examples on the website. See the
MapiTable object.
Best regards
Michael Bauer
Am Tue, 19 Jan 2010 21:14:01 -0800 schrieb Sindhura:
> Hi,
> calenders)
meetings
calendars
time
doing
> this.
> the same.
> ~ Sindhura
Sue Mosher [MVP]
In addition to Michael's suggestion, you might want to look at
http://www.outlookcode.com/article.aspx?id=30 for an explanation of the
logic needed to search over a date range. Also, if you need only free/busy
availability information and not the details of appointments, you can use
the Recipient.FreeBusy method.
Sue Mosher
"Sindhura" <Sindhura> wrote in message
news:83D21782-06E7-482B-9A72-A337A7561321@microsoft.com...
> Hi,
> calenders)
> meetings
> calendars
> time
> doing
> this.
> the same.
> ~ Sindhura
Dmitry Streblechenko
You might also want to look into RDOFolder2.GetActivitiesForTimeRange
(http://www.dimastr.com/redemption/rdo/RDOFolder.htm#rdofolder2) and
RDOAddressEntry.FreeBusyList
(http://www.dimastr.com/redemption/rdo/RDOAddressEntry.htm)
Dmitry Streblechenko (MVP)
"Michael Bauer " <mb@mvps.org> wrote in message
news:1l3g8bnvhmas5$.1si7kl65ai1a9.dlg@40tude.net...
> MapiTable object.
> > Best regards
> Michael Bauer
> > Hi,
> > calenders)
> meetings
> calendars
> time
> doing
> > this.
> > the same.
>> ~ Sindhura
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
R Trying to extract information between two symbols from outlook subject Using Outlook 2
E Extract excel files from outlook Outlook VBA and Custom Forms 2
K extract certain text from an Outlook Email Message Outlook VBA and Custom Forms 2
M HELP - Can't open outlook... How can I extract my Emails that I had in folders Using Outlook 3
R Saving Outlook Email As Text File Extract Outlook VBA and Custom Forms 2
? outlook attachment Extract File ??? Outlook VBA and Custom Forms 1
V extract users of a particular department Outlook VBA and Custom Forms 1
S How to extract mail items from multiple folders and shared mailboxes? Outlook VBA and Custom Forms 0
K Extract email to excel from a specific sender Outlook VBA and Custom Forms 3
O VBA to extract email (fields and body) to Excel Outlook VBA and Custom Forms 14
P Recover / Extract Rules from standalone PST file creating RWZ file Using Outlook 2
B Extract Dates for Appointment Item in Body of email Outlook VBA and Custom Forms 10
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
D VBA Script to extract text matching specific criteria Outlook VBA and Custom Forms 1
M Extract text in existing message body for use in newmail items Using Outlook 17
M Extract attachments with a script Using Outlook 0
H Extract emails from Outlokk 2007 email body Using Outlook 0
K Extract Global Address List Using Outlook 1
N Programming to extract automatically extract attachments Outlook VBA and Custom Forms 3
N How to extract date and time stamp from messsages Outlook VBA and Custom Forms 6
V Extract Subject,Sent From, Message from mailbox to Excel Outlook VBA and Custom Forms 5
S Automatically extract attachments? Outlook VBA and Custom Forms 1
I How to extract email addresses from TO or CC line of a particular email Outlook VBA and Custom Forms 2
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
N How do I make Outlook autocomplete addresses from a list of recognised <full_names> only? Using Outlook 2
P Outlook 2019 UI changes after 20H2 update Using Outlook 1
T The Linked Image Cannot Be Displayed in Outlook Using Outlook 5
A OutLook For Mac 16.46 Comes Up In Small Window When Opening Using Outlook 4
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
