Trouble using SaveAs
K
KenR
I have adapted code found here to try to save the selected e-mail to a
specific location external to Outlook. The code crashes on the SaveAs line,
giving an error message, "The messaging interface has returned an unknown
error. If the problem persists, restart Outlook (-278462338)" The error
number varies.
I am using Outlook 2003.
The code in question is:
On Error GoTo Err_SaveMe
Dim TheEmail As MailItem
Dim Path As String
Dim strSubj As String
Set TheEmail = Application.ActiveExplorer.Selection(1)
'remove illegal characters from subject
strSubj = Replace(TheEmail.Subject, "/", "-")
strSubj = Replace(strSubj, "\", "-")
strSubj = Replace(strSubj, ":", "--")
strSubj = Replace(strSubj, "?", sReplace)
strSubj = Replace(strSubj, Chr(34), sReplace)
strSubj = Replace(strSubj, "<", sReplace)
strSubj = Replace(strSubj, ">", sReplace)
strSubj = Replace(strSubj, "|", sReplace)
Path = "K:\"
TheEmail.SaveAs Path & strSubj, olMSG
Err_SaveMe:
MsgBox Err.Description & " (" & Err.Number & ")"
Any help would certainly be appreciated....
K
Ken Slovak - [MVP - Outlook]
The path actually exists and you can save there using the UI?
What happens if you do so, do you get any errors?
What if you try using another save format other than olMSG?
"KenR" <KenR> wrote in message
news:B0349D6C-0274-4B9C-99E8-7381437EBAAB@microsoft.com...
> line,
> number varies.
> Dim Path As String
> Path = "K:\"
> Exit Sub
> Err_SaveMe:
> End Sub
Sue Mosher [MVP]
Most likely, the problem is with the file name/path. Either the target
folder doesn't exist, the user doesn't have permission to create items
there, or it already has too many items. Or the file name is invalid. I
noticed that you are not adding an msg extension to the file name.
Sue Mosher
> line,
> number varies.
> Dim Path As String
> Path = "K:\"
> Exit Sub
> Err_SaveMe:
> End Sub
K
KenR
Ken -
Thanks very much. I tried changing the format to olMSGUnicode, and that
worked!
G Trouble with Office 365/2016 Using Outlook 3
M Trouble downloading Outlook on an Android phone Using Outlook 4
B Trouble Starting Outlook 2010 after Crash Using Outlook 3
U Trouble migrating Contacts (2002) to People (2013) Using Outlook 3
K New to BCM - trouble importing contacts & accounts BCM (Business Contact Manager) 3
B Trying to get old emails from a not working computer but having trouble. Using Outlook 6
M Trouble Importing folders from Outlook 2007 to Outlook 2013 Using Outlook 12
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
T Outlook 2007 - trouble with alphabetizing when titles are used (ie - Mr.) Using Outlook 0
M Outlook 2010 stuck in Work Offline mode; trouble sending email Using Outlook 1
B Trouble Adding @Outlook.com Email Accounts Using Outlook 3
K Trouble converting the ANSI PST to a Unicode PST Using Outlook 4
U Trouble for sharing Calendar Using Outlook 3
S Trouble setting up Outlook Connector to sync with windows live Using Outlook.com accounts in Outlook 3
N Trouble importing calender information from iPhone into OutLook 2010 Using Outlook 1
J TROUBLE SENDING EMAIL FROM OUTLOOK, NO PROBLEM RECIEVING WHEN WORKING FROM OUT OF TOWN Using Outlook 1
T Trouble with creating database BCM (Business Contact Manager) 1
M having trouble importing excel data into outlook contacts BCM (Business Contact Manager) 1
M trouble connection to remote database BCM (Business Contact Manager) 1
