Outlook custom form - VBS call VBA macro
JMat45
I have created a custom OL form based on the Contact form. I want to save
data from some of the fields to a text file. I want to initiate the save
using the WRITE event. I have written the SUB in VBA to save the data, but
can't call the SUB from the form VBS. What is the solution or workaround?
I ask, therefore I am.
Sue Mosher [MVP]
If the Sub is a public Sub in the built-in ThisOutlookSession module, it
should be possible to call it as Application.MySub or whatever its name
is.
Sue Mosher
"JMat45" <JMat45> wrote in message
news:D0325B32-3A15-4E5B-AABC-6684950F67DF@microsoft.com...
JMat45
Ok, I will give that a try. Thanks for the advice.
> is. > Sue Mosher
JMat45
Sue, worked great. I'm back in business. Thanks very much.
> > is. > > Sue Mosher
L Outlook Custom Form Using Outlook 2
Diane Poremsky The custom form cannot be opened. Outlook will use an Outlook form instead. New Slipstick.com Articles 0
L Outlook 2007 Custom Form and Toolbar Not Working Using Outlook 5
C Outlook Custom Contact Form Attach Files in new notes fields Outlook VBA and Custom Forms 3
J Outlook 2010: can't forward appointment on custom form Using Outlook 1
S Custom Outlook Form 2013 Displaying fields incorrectly Outlook VBA and Custom Forms 1
E Create a URL hyperlink in an Outlook custom form? Outlook VBA and Custom Forms 2
R Outlook Custom form check if there an attachment Outlook VBA and Custom Forms 2
G Custom Form code not working - Outlook 2010 Outlook VBA and Custom Forms 2
P Outlook 2010 custom form olk control font size increases everytime form is published Outlook VBA and Custom Forms 1
Z outlook 2007 - opening a contact from the search results doesn't use the custom form Using Outlook 10
R Static Resources in Custom Outlook Appointment Form Using Outlook 2
H Custom Outlook Contact form Using Outlook 1
C Set reminder time in custom form (Outlook 2010) Using Outlook 1
N Custom Outlook Form Using Outlook 1
S Desperate for Help with Outlook custom form Using Outlook 0
C Custom Form Outlook 2010 Contacts Using Outlook 3
H How can you add a URL field in a Outlook Custom Contact form? Using Outlook 6
C Outlook 2010 Custom Form Issues Using Outlook 2
D Outlook 2007 Custom Form - Dual Addresses and Mailing Address Using Outlook 6
M Outlook custom form question Using Outlook 4
B Can't locate in Outlook custom form where is message from Using Outlook 4
M Outlook 2010 Custom Form Problem Using Outlook 1
B Date validation in Outlook Custom Form Using Outlook 2
A Custom form - hitting 'next item' button hangs Outlook Outlook VBA and Custom Forms 2
L Macros disabled in custom Outlook form Outlook VBA and Custom Forms 1
J populate word template from Outlook custom form Outlook VBA and Custom Forms 2
K Can't use links in Outlook custom form text field Outlook VBA and Custom Forms 1
D Outlook 2003 custom form not viewable by receiver Outlook VBA and Custom Forms 11
L Custom Form (Outlook 2003 and Exchange 2003) Outlook VBA and Custom Forms 6
N Custom Contact Form in Outlook 2003 Outlook VBA and Custom Forms 1
B Importing Contacts Does Not Use Defined Custom Form in Outlook 2007 Outlook VBA and Custom Forms 1
L wrong icon displayed for outlook custom form Outlook VBA and Custom Forms 8
P replace default outlook form with custom form Outlook VBA and Custom Forms 1
J Extra text on an Outlook 2007 custom form Outlook VBA and Custom Forms 2
U Is it posible to Invoke a custom Form in my Outlook Add-in tool ba Outlook VBA and Custom Forms 1
K Accessing contact's custom properties in a Outlook 2007 form region Outlook VBA and Custom Forms 1
