Reply to original sender, not to forwarder ?
P
peternn
is it possible to have a macro or something that will do the following:
When I have a forwarded message selected in the Inbox message list and
invoke the macro, to have a reply window where in the TO: field appears the
email of the original sender (and not that of the forwarder).
Ideal would be this to happen automatically when I click Reply, if the
subject starts with FW:
K
Ken Slovak - [MVP - Outlook]
A forward like that doesn't retain any properties for the original sender.
That is only preserved, if at all, as text in the body of the forwarded
message. You'd need to parse the string value grabbed from item.Body or
item.HTMLBody and look for something that looks like an email address and
hope that it's from the original sender.
"peternn" <peter_nn0@yahoo.com> wrote in message
news:eyRGQoKpKHA.1544@TK2MSFTNGP02.phx.gbl...
> Hi,
> the email of the original sender (and not that of the forwarder).
> Thanks
S Outlook 2k/2k3 Reply or Forward: Signature image replaced by original sender Using Outlook 3
H send reminder if no reply received on first or original email using macro Using Outlook 2
S Reply & Forward Date in original message incorrect Using Outlook 2
B Auto reply using macro include original email Using Outlook 4
J Image in original e-mail is hyperlinked when a reply with the image is hyerplinked Exchange Server Administration 1
R Auto Reply with Original Email and any attachments Outlook VBA and Custom Forms 1
P Automatic Greeting "Hello Name," when Reply All is clicked Outlook VBA and Custom Forms 1
W Reply to email Using Outlook 4
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
ThinkToday Calculate reply time of outlook mail Using Outlook 1
J Outlook Reply > From > Other Email Address... > Address Not Showing in Sent Items... From Email Outlook VBA and Custom Forms 0
M Delete headers in Inline reply Outlook VBA and Custom Forms 5
E reply Using Outlook 0
evdbogaard Reply with only last message cited Using Outlook 1
Rupert Dragwater Deleted email address keeps showing up in reply Using Outlook 12
M Reply Inline With a Outlook Template Outlook VBA and Custom Forms 6
J VBA Run When Reply Outlook VBA and Custom Forms 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
T In-line reply style in Outlook Outlook VBA and Custom Forms 20
Vijay Reply all by attachment name Using Outlook 10
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
G Outlook 2016: reply icon not showing when replied from mobile Using Outlook 3
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
