Table does not display
Mike
We have a form that we use as a standard form in one of our company
calendars. It contains a table with areas to fill out with visitor
information, which then creates an appointment and emails our receptionist.
For som ereason, if you double click a day in the calendar, the form opens
just fine. However, if you right click and say "new appoinment" it opens the
appointment with only text, the "table" is gone, as is all the formatting of
the fonts.
We use Exchange 2007 and Outlook 2007 and 2003 clients. I am editing the
form with Outlook 2007.
Mike
Mike
aarrrg...I meant to post this in the "Forms" group...sorry.
Mike
> the fonts.
> > Mike
P Table AutoFit > AutoFit to Contents Outlook VBA and Custom Forms 0
D Paste Excel table into Outlook message Outlook VBA and Custom Forms 6
A Pivot Table to CSV File - VBA Outlook VBA and Custom Forms 1
T "From" field font size in table list of emails Using Outlook 0
M Extracting cell data from table Outlook VBA and Custom Forms 2
A Synchronize Access Table with Outlook Calendar Appointments Outlook VBA and Custom Forms 3
R Convert Access table to pst Using Outlook 1
T Populating listbox with MS Access table Using Outlook 2
Hudas Hyperlink Saved Outlook Email to MS Access Table Using Outlook 4
L Excel table format lost in Outlook Using Outlook 6
D outlook 2010 table format lost on send Using Outlook 1
L Cannot sync Calendar to iphone. Cannot export to CSV. Cannot view as Table. Using Outlook 3
M 2010 Excell Pivot Table Group Using Outlook 1
M Tables lost in Sent Email and Can't see Table in Viewed Inbox email. Using Outlook 2
R Print full text of multiple e-mails in table format Using Outlook 1
K Print Contacts - Table Style in Outlook 2010 - no gridlines? Using Outlook 4
L How to extract table format of Task Item if its body contains formatted table. Exchange Server Administration 1
M Download Outlook Meeting Attendees into Excel or other table/database Using Outlook 3
O Outlook is the default program but it is not showing up in the default table Using Outlook 1
L [Outlook 2003] Add Table to form Outlook VBA and Custom Forms 2
T Copy/export dates/times from Inbox table view Outlook Wishlist 1
J Lookup from an Access table Outlook VBA and Custom Forms 1
S Create Auto eMail with Web table Content Outlook VBA and Custom Forms 1
N Free/busy publish at http location does not work Using Outlook 1
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
