Word macro running from OL VBA throwing error on Word SaveAs??
E
Ed from AZ
I have a macro in Word that iterates through my Favorites folder and
saves everything out as hyperlinks in a Word doc. I then SaveAs using
doc.SaveAs FileName:= _
"C:\Documents and Settings\edward.millis\Documents\MyFaves.htm",
_
FileFormat:=wdFormatHTML
This macro was written in Word XP, which has now been upgraded to
2007. The OS has also been updated from WinXP Pro to Vista Pro.
When I run the macro in Word only, it runs fine - the file is
generated and saved to the correct folder in the correct format.
I want to email the file out, so I am trying to run it from within an
Outlook 2007 macro. (Security settings prevent Word VBA from
accessing OL VBA, or I would do it all from within Word.)
The OL macro creates the Word instance just fine and runs the macro
just fine - until it hits the SaveAs. I put a STOP in the Word code
just before the SaveAs to verify this - as soon aas I F8 to the
SaveAs, my error handler tells me that Outlook VBA has the following
error:
-2147417851
Method "Run" of object "Application" failed
Any suggestions on getting this macro to run when accessed from OL
VBA?
Ed
K
Ken Slovak - [MVP - Outlook]
That file path shouldn't exist at all on a Vista system. Does the exact same
code really run in Word on Vista without errors? In any case, if there's a
Word error going on the problem isn't an Outlook problem but a Word problem.
"Ed from AZ" <prof_ofwhat@yahoo.com> wrote in message
news:6a026697-8927-4b89-a9c0-7d10588a014a@g28g2000yqh.googlegroups.com...
> _
> error:
> -2147417851
> VBA?
> Ed
E
Ed from AZ
Wow! I copied it straight off the folder address bar - I thought.
The address bar shows the heirarchy separated by >, but when you click
in it it turns to /. I'll have to look at that again. But yes, when
run from Word, there are no problems. Well, maybe not - it's
overwriting a file that's already there, so maybe the newly save file
is disappearing into the system somewhere and I'm actually still
seeing the previous version.
Gotta look at that again! Thanks, Ken. At least I have a good point
to start looking.
Ed
On Mar 2, 1:54 pm, " - " <kenslo...@mvps.org
> http://www.slovaktech.com
> "Ed from AZ" <prof_ofw...@yahoo.com> wrote in messagenews:6a026697-8927-4b89-a9c0-7d10588a014a@g28g2000yqh.googlegroups.com...
> > _
> > error:
> >  -2147417851
> > VBA?
> > Ed-
K
I don't know, your setup may be different, but here on one of my Vista
setups a document in my Documents folder has a path that looks like this:
C:\Users\.000\Documents\9096xcc.doc.
news:3ec2eba3-fe84-41f1-80e1-8c9bd5898755@f17g2000prh.googlegroups.com...
to start looking.
Ed
Tony Jollans
Vista will allow you to use that name as an alternative to the
Users\(userid)\Documents name.
Are you using Application.Run (as per the message)? Or is the code exactly
as posted - which ought to work (assuming doc is a valid reference)?
Enjoy,
Tony
www.WordArticles.com
news:%23O0vKqkuKHA.6140@TK2MSFTNGP05.phx.gbl...
> same code really run in Word on Vista without errors? In any case, if
> there's a Word error going on the problem isn't an Outlook problem but a
> Word problem.
> > _
> > error:
> > -2147417851
> > VBA?
> > Ed
E
Ed from AZ
Hi, Tony.
The Outlook macro has
'Set Word application to running instance or new instance
Set appWord = GetObject(, "Word.Application")
If Err Then
Set appWord = New Word.Application
WordWasNotRunning = True
Err.Clear
On Error GoTo BadBoy
'Run Word macro
appWord.Visible = True
appWord.Run "Normal.Module11.GetMyFaves"
The Word macro does run. I put a Stop right before the SaveAs command
in the Word macro and fixed the file path for Vista. The macro breaks
at the Stop, and as soon as I F8 to the SaveAs line it throws the
error - not in the Word app, but in the OL app as described in my
first post.
I'm thinking the next step may be to put everything in OL VBA and just
access Word from there to create and save the doc. Just haven't had
time to play with that yet.
Ed
On Mar 8, 12:51 pm, "Tony Jollans" <My forename at my surname dot com
> > Enjoy,
> Tony
> " - " <kenslo...@mvps.org> wrote in messagenews:%23O0vKqkuKHA.6140@TK2MSFTNGP05.phx.gbl...
> > Word problem.
> >news:6a026697-8927-4b89-a9c0-7d10588a014a@g28g2000yqh.googlegroups.com....
> >> _
> >> error:
> >>  -2147417851
> >> VBA?
> >> Ed-
Tony Jollans
The error is in Outlook because .. you don't have any active error trapping,
and the error bubbles up to the top and is trapped, ultimately, by the top
level VBA in Outlook. If you add an On Error to your Word macro, it should
trap the error there.
That, however, doesn't help with the actual issue - error code -2147417851
is a rather generic 'server exception' - these can be symptomatic of object
errors - lost pointers, or implicit instantiation, for example - that can
happen in Automation. Can you post the full Word code as well?
Enjoy,
Tony
news:6d689010-df81-4c34-8d78-76d6aa87c20d@g26g2000yqn.googlegroups.com...
Hi, Tony.
If Err Then
Err.Clear
'Run Word macro
first post.
Ed
> > Enjoy,
> Tony
> > Word problem.
> >> _
> >> error:
> >> -2147417851
> >> VBA?
> >> Ed-
E
Ed from AZ
Here's the full code in Word. It's all in one module, most variables
declared at the top, and a Sub that calls to a Function.
When I run this just in Word, it goes great, saves and closes the
doc. When I try to call this from the OL macro, it always errors out
at the SaveAs. The doc is there with all the info in it, just not
saved.
Ed
Dim fsoSysObj As FileSystemObject
Dim fdrFolder As Folder
Dim fdrSubFolder As Folder
Dim filFile As file
Dim objShell As Shell
Dim objFolder As Object
Dim objItem As Object
Dim objLink As Object
Dim doc As Document
Dim rng As Range
Dim strFldName As String
Dim myanchor, strLnkText, strLnkPath
Dim ary() As String
Dim cntAry As Integer
Dim x As Integer
Function GetFiles(strPath As String, _
Optional blnRecursive As Boolean) As Boolean
' This procedure returns all the files in a directory into
' an array. If called recursively, it also returns
' all files in subfolders.
' Get folder.
Set fdrFolder = fsoSysObj.GetFolder(strPath)
' Skip this folder
If fdrFolder.Name = "~Work" Then GoTo GetFiles_End
strFldName = fdrFolder.Name
If Err <> 0 Then
' Incorrect path.
GetFiles = False
GoTo GetFiles_End
On Error GoTo 0
Set objFolder = objShell.Namespace(strPath)
' Loop through Files collection, adding to array.
For Each filFile In fdrFolder.Files
If filFile.Type = "Internet Shortcut" Then
Set objItem = objFolder.ParseName(filFile.Name)
Set objLink = objItem.GetLink
' Set info in array
cntAry = cntAry + 1
ReDim Preserve ary(3, cntAry) As String
ary(1, cntAry) = strFldName
ary(2, cntAry) = objItem.Name
ary(3, cntAry) = objLink.Target.Path
Next filFile
' If Recursive flag is true, call recursively.
If blnRecursive Then
For Each fdrSubFolder In fdrFolder.SubFolders
GetFiles fdrSubFolder.Path, True
Next fdrSubFolder
' Return True if no error occurred.
GetFiles = True
GetFiles_End:
Exit Function
End Function
Sub GetMyFaves()
' Calls GetFiles function to retrieve Favorites URLs.
If Application.Documents.Count < 1 Then Application.Documents.Add
Set doc = ActiveDocument
cntAry = 0
' Return new FileSystemObject.
Set fsoSysObj = New FileSystemObject
' Shell object provides objects with link properties
Set objShell = CreateObject("Shell.Application")
' Call recursively, return info into array.
If GetFiles("C:\Users\edward.millis\Favorites", True) Then
For x = 1 To cntAry
Set rng = doc.Paragraphs(doc.Paragraphs.Count).Range
If ary(1, x) <> strFldName Then
rng.Text = "\" & ary(1, x) & vbCrLf
strFldName = ary(1, x)
Set myanchor = rng
strLnkText = ary(2, x)
strLnkPath = ary(3, x)
doc.Hyperlinks.Add Anchor:=myanchor, Address:= _
strLnkPath, SubAddress:="", ScreenTip:="", TextToDisplay:= _
strLnkText
doc.Content.InsertAfter vbCrLf
Next x
Stop
"C:\Users\edward.millis\Documents\MyFaves.htm", _
doc.Close
If Err.Number <> 0 Then _
MsgBox Err.Number & ": " & Err.Description
On Error GoTo 0
On Mar 9, 12:33 pm, "Tony Jollans" <My forename at my surname dot com
> > Enjoy,
> Tony
Tony Jollans
Thank you for that, and sorry for the long delay in replying.
I can't see any obvious cause of your problem. I did, however, cut and paste
both your Outlook and Word codes into 2007 and I had to mess about a bit to
get it to work (some of the problems were my environment, but I did need to
add a trailing backslash on the Set objFolder line) and when I finally did I
got your error - but only once. After that I couldn't repeat the error and,
I'm sorry to say, I don't know what may be causing it.
Enjoy,
Tony
news:ce315ea8-7f3f-406a-9bb3-a98465255c6d@w27g2000pre.googlegroups.com...
saved.
Ed
Dim filFile As file
Dim doc As Document
Dim rng As Range
Dim ary() As String
Dim x As Integer
' Get folder.
' Skip this folder
If Err <> 0 Then
' Incorrect path.
GetFiles = False
GoTo GetFiles_End
On Error GoTo 0
' Set info in array
cntAry = cntAry + 1
Next filFile
Next fdrSubFolder
GetFiles = True
GetFiles_End:
Exit Function
End Function
Sub GetMyFaves()
cntAry = 0
For x = 1 To cntAry
Set myanchor = rng
strLnkText
Next x
Stop
doc.Close
On Error GoTo 0
> trapping,
> object
> > Enjoy,
> Tony
Diane Poremsky Use Word Macro to Apply Formatting to Email New Slipstick.com Articles 0
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
W Macro to add a word in Subject Line Using Outlook 1
L Macro to Open a Specific Word Document - Outlook 2007 Using Outlook 17
J Can't run macro Outlook 2007 that was created in Word 2007 Outlook VBA and Custom Forms 1
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
C blocking two or more word domains separated by period/dot Using Outlook 3
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
C replace subject line generated by converting a word document to PDF and sending it to an email Using Outlook 8
iwshim word shortcut to search outlook Using Outlook 3
C Outlook 2016 - converting Word VBA to default Outlook message Outlook VBA and Custom Forms 0
C Merging Word and Access into Outlook Using Outlook 4
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
Mark Foley Emailing attachment from Word/Excel sends attachment but no message body Using Outlook 0
Diane Poremsky Disable Live Preview in Outlook and Word New Slipstick.com Articles 0
D Need to extract a line from a word attachment, and add it to the subject line Outlook VBA and Custom Forms 3
M Unable to email from Word or Excel Using Outlook 11
P Macros in Word 2003 - how to transfer to another Word 2003? Using Outlook 1
B Outlook to Word Template error Using Outlook 4
J Outlook body to word document Outlook VBA and Custom Forms 11
A Application_ItemSend not accessed when sending email outside outlook (i.e. word or send to mail from Using Outlook 7
O Copy email content and paste into new Word Document using a different font Using Outlook 1
K Import 2013 Outlook Contact Address into Word Using Outlook 36
J "Specific word in body" question Using Outlook 1
D opening Word Document in a business contact? BCM (Business Contact Manager) 3
Z Send mail and contents of body from ms word document Using Outlook 1
O Choosing Sending Email Address from Word Using Outlook 5
C Printing Outlook Form Controls via Word Using Outlook 11
S Highlighter colors limited in Outlook 2007 and Word 2007 Using Outlook 1
O Outlook 2010 does not open MS Word attachments Using Outlook 1
R Using Word/OL 2010 to generate personalized email messages Using Outlook 1
S send email attachment from word, message stripped out Using Outlook 1
M Opening Word Doc's in Adobe Acrobat Pro Using Outlook 9
D Word Wrap Subject Using Outlook 1
C Outlook editing won't select just one word Using Outlook 1
B MS Office 2010: Word email merge not selecting default Outlook account Using Outlook 1
T Word attached files open Word. Excel files open Picture Manager!! Using Outlook 2
C Outlook 2010 some messages received have no word wrap Using Outlook 1
G No word wrap in HTML email. Using Outlook 8
M Flag outgoing mail by word in body Outlook Wishlist 1
P Word experienced and error trying to open the file Using Outlook 2
T New Inspector word editor crash Outlook 2003 Outlook VBA and Custom Forms 3
T Word 2007 add-in ribbon icons greyed out Outlook VBA and Custom Forms 1
G BCM Word Add-In BCM (Business Contact Manager) 1
