Using Group Policy to control Outlook security/attachments behaviour
John
Are there any easy instructions on how to set Outlook 2007 security via
group policy settings?
Many Thanks
Regards
Brian Tillman
"John" <info@nospam.infovis.co.uk> wrote in message
news:O8disCWvKHA.6140@TK2MSFTNGP05.phx.gbl...
This question isn't clear enough. There are multiple security features in
Outlook. Which one(s) are you trying to control? What happens now and what
would you like to happen? Exchange account?
O How to paste website content using a specific font and removing URLs Using Outlook 2
