How to prevent that Outlook is sending before my add-in is finished?
K
Kukulkan
I made an Outlook AddIn (OL2003 and OL2007) by using VB6 and
Redemption Objects. I need to manipulate the message before sending
(change Body, remove and add attachments). In most cases this works
fine, but in some rare cases there seem to occur problems. It looks
like OL is sending the message before my add-in is finished. This is
mainly observed on OL that is connected to an Exchange server.
In my code I need to call Mailitem.Save a few times. For example,
after removing attachments and before adding a new one (without this,
adding attachments will fail). I suppose that OL uses exactly this
moment to send the message. This results in messages that do not
contain the attachment that I like to add later.
Is there a way to prevent sending messages for a while? I want to be
shure that the message will get only sent after I finished my job? Any
idea?
Kukulkan
K
Ken Slovak - [MVP - Outlook]
What event are you using? I've never had any sends go out without my
allowing it when I've handled either the Send() event for an item or the
Application.ItemSend() event. It doesn't matter if Exchange is involved, the
first thing that will happen after an item is sent is the firing of the
Send() event for that item.
"Kukulkan" <regify@googlemail.com> wrote in message
news:f696cb7f-dd1a-4a54-82af-eaee7473f39d@c16g2000yqd.googlegroups.com...
> Hi,
> idea?
> Thanks,
> Kukulkan
K
Kukulkan
Re: How to prevent that Outlook is sending before my add-in isfinished?
Hi Ken,
I capture the send-event of the mailitem. Inside, I call my function
to reconvert the e-mail before sending. I think, the mailitem is
already marked for delivery in this moment. And outlook does not wait
until the Sent() event returns and try's to send in the meanwhile
(possibly in the moment I call Item.save).
While processing, I call an external compression utility using Shell()
command. To wait for the end of this tool, I use
OpenProcess(PROCESS_QUERY_INFORMATION + SYNCHRONIZE, 0, TaskID) and
GetExitCodeProcess() in a loop with many DoEvents calls. May this be
part of the problem?
I wrapped the send-item event to capture it. The Cancel-Property is
wrapped, too. Only some customers are affected. On others it runs
perfectly. Is there a way to prevent outlook from sending/receiving
while I'm processing the mail?
Regards,
Kukulkan
K
Kukulkan
Hi Ken,
Thank you for your help.
> My guess is that your code is hitting an unexpected error in those cases
> where you have problems and is aborting your event handler or bypassing
> parts of it.
I used the debugger to step through all parts. Every involved routine
has an on error goto statement with an error-dialog. The complete
problem is, that I sometimes having different weird behaviours in
exchange environment (only by my customers, but never here):
Sometimes, the e-mail gets received multiple times by the recipients.
They are all identical. In my routines, I manipulate one(!) e-mail,
and in rare cases the recipient receives up to 5 copies (sometimes
only 3 or 2. That changes random). I do not change any recipients in
the e-mail. In the sent-items folder of the sender, there is only one
item! In my inbox, there are sometimes three absolute identical mails.
Sometimes, the e-mail comes without attachment. I definitely add an
attachment to the mail! In the sent-items folder of the sender, the e-
mail has the attachment. In my inbox, there is no attachment.
Something really strage is going on here...
I will try to find out more. Maybe one of my customers is willing to
let me do some debugging...
Kukulkan
K
Kukulkan
I have additional information:
I checked the behaviour with one of my customers. This is what we
found:
An e-mail, TO: Recipient1 CC: Recipient2 should be processed.
- processing occured with no error-message (changed Body and
Attachments)
- Recipient1 received the e-mail two times incl. attachment
- Recipient2 received the e-mail without attachment (one times)
- in sent-items folder of the sender, the e-mail is found one times
without(!) attachment
This is strange. The same mail arrived two times at Recipient1 -
including the attachment!
In sent-items folder, the attachment is missing!
Any idea? On most customers, no problems occur. Maybe a problem with
CC:? Is there something to take care about? Any idea?
Thank you,
Kukulkan
K
This is only a guess, and you need to find what's different about systems
where the problem occurs and where it doesn't, but my guess is an anti-virus
addin that scans outgoing and incoming emails. That's almost always a bad
idea and can cause problems like the ones you're seeing. Multiple sends,
sometimes hundreds of them, items lost in space or a black hole and various
other problems are all common when incoming/outgoing emails are scanned. See
if that's the possible cause of the problem.
news:49cc75fb-baf1-4159-b8ce-f7b4c7599d3a@b30g2000yqd.googlegroups.com...
> found:
> Attachments)
> Thank you,
> Kukulkan
I How to prevent exchange email account from sending emails in Outlook Using Outlook 4
C Prevent Outlook from sending an email with a blank Subject Line Outlook VBA and Custom Forms 3
oj43085 Prevent Outlook from blocking image from a single source Using Outlook 4
D Prevent Outlook from resolving incomplete contact when clicking send Using Outlook 2
O How to prevent image resize when pasting Using Outlook 2
O How to prevent CC from showing when creating a new mail? Using Outlook 1
L OL 2016 contact: is there a way to prevent an admin from mistakenly deleting a contact? Using Outlook 1
D Multiple mailboxes, 1 certificate. How to prevent message "Invalid Certificate" Using Outlook 0
S How to prevent addins Using Outlook 0
Diane Poremsky Prevent Users From Choosing Stationery Using Outlook 0
evdbogaard How to prevent extra line feeds in replies Using Outlook 3
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
K Prevent meeting requests being sent from a shared calendar in a group mailbox Using Outlook 1
N Prevent reminder dismisal in shared calendar Using Outlook 1
C Security Question - How to prevent users exporting .iaf files Using Outlook 5
B Item_Write = False don't prevent custom form from closing Using Outlook 1
N Allow Another User to Send on Behalf of But Prevent Access to Inbox Using Outlook 4
R Exchange 2010 archive-prevent users moving items direct to archive Exchange Server Administration 1
M Links prevent sending email Using Outlook 3
K Prevent sending Excel files as attachements Outlook VBA and Custom Forms 1
A Script to either modify "from" address or prevent a reply being se Outlook VBA and Custom Forms 2
J prevent user from installing wrong version of add-in Outlook VBA and Custom Forms 2
Z Prevent Changes to Custom Form Outlook VBA and Custom Forms 1
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 9
@ Outlook Using Outlook 2
