insert text into current position of pointer in mailcompose
K
khoick245
hi all. i built a ribbon xml which has a combobox. i want whenever i
choice a item in combobox, the label will automatically insert into
current position of pointer in mailcompose. what should i do? thanks !
i use c# 2008 and outlook 2007
khoick245
Sue Mosher [MVP]
Use Inspector.WordEditor to return a Word.Document object, then use Word
methods like Range.InsertAfter to insert the text.
Sue Mosher
> > khoick245
Diane Poremsky Create Task or Appointment and Insert Selected Text New Slipstick.com Articles 0
H Insert Specific Text before Subject for New mails and reply Using Outlook 3
D Insert Text and Send Outlook VBA and Custom Forms 1
B Simple way to insert file text - macro? Outlook VBA and Custom Forms 1
D Insert Text via Macro in Outlook 2007 Outlook VBA and Custom Forms 2
T Insert text from file Outlook VBA and Custom Forms 1
witzker Outlook 2010 Insert Date & Time at the button of an OL contactform in red Using Outlook 2
L Automatically Insert Recipient Name from To Field Outlook VBA and Custom Forms 33
B Insert Hyperlinks for attachments in Userform Outlook VBA and Custom Forms 5
D Outlook task insert Outlook VBA and Custom Forms 3
K Insert screenshots issue Using Outlook 2
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
L Insert Photo to Contact Using Outlook 23
K OL2010 Button to Insert First Name Outlook VBA and Custom Forms 6
K OL2010 Button to Insert First Name Using Outlook 1
witzker insert Date & Time (HH:mm) no (ss) in userform Using Outlook 6
A insert Date & Time in userform Using Outlook 3
K Macro to insert attachments Using Outlook 1
C Insert a Date Picker for Send Mail Subject Using Outlook 1
C Insert date in Subject through date picker Using Outlook 0
mrje1 Opening a task the Insert Tab Option is not showing up and organizing Tasks Using Outlook 9
R insert picture tab grey Using Outlook 1
K Outlook insert clip art, no results found...address book contacts only show up Using Outlook 5
J Form design - how do I insert an automatic date/time field? Using Outlook 2
J How do I view the ruler in an Outlook message and/or insert tabs? Using Outlook 7
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
D Re: How do i insert radio buttons in an email Outlook VBA and Custom Forms 1
G How to insert a json array into a calendar events Outlook VBA and Custom Forms 1
J Insert File Outlook VBA and Custom Forms 2
M Insert a File Outlook VBA and Custom Forms 3
G Task / Insert / Attach Item / Business Contact BCM (Business Contact Manager) 1
M Forward email as insert from button Outlook VBA and Custom Forms 1
S How to insert a picture programatically Outlook VBA and Custom Forms 12
C insert a picture Outlook VBA and Custom Forms 1
J How do I scan and insert into Outlook 2007? Using Outlook 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
D RE: How do you change the default insert file path in outlook? Using Outlook 11
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
J Command Button to insert Email Signature Outlook VBA and Custom Forms 2
D Macro creation for Outlook insert subject Outlook VBA and Custom Forms 1
F Insert date at cursor location Outlook VBA and Custom Forms 4
S How to create a macro to insert a signature in Outlook 2007 Outlook VBA and Custom Forms 1
T How do i insert a page break in an Outlook e-mail message? Using Outlook 4
