Not able to load an add-in for outlook 2007 developed in VSTO 2005
Amrish Shah
I have created the setup for the outlook adddin. The setup works fine , but
when open the outlook the addin doest not get loaded.
Following thing i have Installed for outlook addin setup
1. .Net Framework 2.0
2. CAS
3. VSTOR.exe
4. primary interop Assemblies (office2007)
Amrish Shah
This Outlook Add-in when i try to load it from the Development Environment
(i.e. by Pressing F5) it is working perfectly as desired.
When i try to Install the same in End User Machine with all pre-requisites
mentioned below it gives No Error.
But when i launch the OUTLOOK the Addin does not launch. It is displayed in
the List of Addins in the Trust Center. But it does not launch (neither
automatically or manually).
Would appreciate for a response to this solution asap
Regards
Amrish
"Amrish Shah" wrote:
> Hi,
> 2. CAS
> 3. VSTOR.exe
K
Ken Slovak - [MVP - Outlook]
If you actually are deploying all dependencies and everything is registered
correctly you are going to have to do some detective work. See the
troubleshooting information at
http://blogs.msdn.com/vsod/archive/2008/04/22/Troubleshooting-com-add-in-load-failures.aspx
to get you started.
"Amrish Shah" <AmrishShah> wrote in message
news:EA74C333-B4EB-41DB-AD43-2ADB1F0A1619@microsoft.com...
> Hi
> in
> Regards
> Amrish
> > Hi,
> > but
> > 2. CAS
> > 3. VSTOR.exe
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
Fozzie Bear Wishlist To be able to add a local folder or network share location in foldern view Outlook Wishlist 1
L Outlook 2010- Be able to move default Mail folders (Outbox, Draft, etc) Outlook Wishlist 1
P Not able to receive meeting request Using Outlook 2
G Not able to send ANY emails due to a blocked list Using Outlook 2
D No longer able to Archive Outlook 2007 Using Outlook 1
N Not able to receive daily emails. Using Outlook 3
S I'm not able to copy and paste on outlook. Using Outlook 1
T Have to type in login to OWA twice before able to login Using Outlook 17
M Outlook Anywhere is not showing freebusy informayion and User not able to open shared calender while Using Outlook 1
R No problems for about three months and the, about two weeks ago I was no longer able to receive emails in Outlook. Using Outlook 4
D Not able to retrieve my emails or get to my contacts using outlook. Using Outlook 3
K Sending email in Outlook - being able to choose... Using Outlook 1
S Suddenly I am not able to send e-mail but can receive. We use Windows7 and Outlook has been working for about a year. Using Outlook 2
E 554 message not allowed [320] I am able to receive emails from these contacts but when i reply i get this error code. It is from contacts that i have Using Outlook 1
G Not able to accept meeting with outlook 2010 Using Outlook 0
J DAG problem - I´m not able to recover database Exchange Server Administration 9
G Not able to accept meeting with outlook 2010 Using Outlook 1
A error 2147504141 -I am not able to fix this error even after attepmting all IPv6 related sloution. Exchange Server Administration 3
D I am able to send emails on Outlook, but unable to retrieve emails trying to come in. Using Outlook 1
A Not able to search by last name in GAL Exchange Server Administration 3
D Not able to send mails through MS Outlook 2007 Using Outlook 3
S Not able to establish Outlook on Windows server, office email, yahoo account Using Outlook 1
D I would like to be able to Forward a Template to a specified email address on receiving an email in the Inbox. Using Outlook 1
H Not able to get messages forwarded from my road runner account. Using Outlook 2
B Switching Access from version 2010 to 2007 or 2003 causes Outlook to no longer be able to send or receive email. Using Outlook 2
S How do I set up more than 1 email account for Outlook 2007. Have recently purchased a laptop and want to be able to check all emails that come into t Using Outlook 2
M Not able to select my contacts list for my address book Using Outlook 7
M Need to copy old PST file from CD into Outlook so as to be able to open and view the old documents. Using Outlook 7
A SCOM 2007 R2 not able to see Exchange 2010 mailbox server Exchange Server Administration 4
S Not able to open webmail inbox. Using Outlook 2
S Me and my big mouth...I said to my customer a district nursing organization down here in New Zealand, that 2 ipaqs should be able to share the same Co Using Outlook 1
T Need to be able to check my microsoft outlook emails via my blackberry Using Outlook 1
O owa was not able to process this request Using Outlook 3
A not able to change password by EX2010 OWA for few user's Exchange Server Administration 26
M Unable able to initialize Exchange management (EMC and EMS don't work) - Access Denied Exchange Server Administration 16
Z Exchange 2010 OWA and outlook 2003 not able to access from terminal server after redoing the database. Exchange Server Administration 6
A When I log out of Outlook. The icon on the taskbar is greyed out and I am not able to activate/launch Outlook unless I reboot my PC. I have XP and am Using Outlook 2
I RBAC Authentication error - Remote EMC not able to access Exchange Organization Exchange Server Administration 13
S BCM Not Able to Complete Task - Window won't Clear BCM (Business Contact Manager) 1
C Not able to send emails with Outlook 2007 using Vista BCM (Business Contact Manager) 1
U Not able to delete Add-in button from multiple Outlook Explorer Outlook VBA and Custom Forms 1
B I want to be able to associate or attach e-mails to an account BCM (Business Contact Manager) 1
J VB6 Add-in fails to load in Outlook 16 - message useless Outlook VBA and Custom Forms 4
Diane Poremsky Always Load an Outlook Addin New Slipstick.com Articles 1
William getting custom form to load category colors Outlook VBA and Custom Forms 4
