Forward Email and Insert Sender's Email address in body
L
LDMueller
With the help of this awesome site, I've created the following code. The
only part which I can't figure out is how to insert the email address of the
sender in the
"Senders Email Address Here" area.
Sub Whitelist()
Set ThisItem = Application.ActiveInspector.CurrentItem
Set fwdItem = ThisItem.Forward
fwdItem.To = "lmueller@company.com"
fwdItem.subject = "Whitelist"
fwdItem.HTMLBody = "<p>Please whitelist the following:</p><p></p>" &
vbCrLf & _
"Senders Email Address Here" & _
vbCrLf & fwdItem.HTMLBody
fwdItem.Send
Can anyone help me?
Thanks so much in advance!
LDMueller
K
Ken Slovak - [MVP - Outlook]
One post would have been enough.
You want the sender's email address from the ThisItem object?
Use ThisItem.SenderEmailAddress for that. Be aware though that if your
sender is an Exchange user in the same domain you are in (if you use
Exchange) that the result will be an Exchange DN and not an SMTP address.
"LDMueller" <LDMueller> wrote in message
news:EA7810DE-262B-44F1-851A-E17CD771CA75@microsoft.com...
> the
> sender in the
> Sub Whitelist()
> On Error Resume Next
> vbCrLf & _
> fwdItem.Send
> End Sub
> Can anyone help me?
> LDMueller
L
LDMueller
Sorry about the duplicate post. When I went back to check the status and
didn't see the orginal one, I thought perhaps I didn't post it properly.
I tried your suggestion and it worked except my sender is an Exchange user.
Is there any way around this?
Also, the way I have it written, I have to have the email open for the macro
to work. Is there a way to have it work when the email is currently selected?
Thanks so much for your help. I really appreciate it!
> > the
> > sender in the
> > Sub Whitelist()
> > vbCrLf & _
> > fwdItem.Send
> > End Sub
> > Can anyone help me?
> > LDMueller
K
Assuming only 1 item is selected:
Application.ActiveExplorer.Selection.Item(1) instead of the
Inspector.CurrentItem.
What Outlook version are you using? If you are using Outlook 2007 or later
you can get the SMTP address, if you are using an earlier version of Outlook
you'd need to use a different, lower level API to get that property, which
isn't exposed in Outlook 2003 or earlier.
news:94A42E33-AF69-47AC-BC7B-3B9B82ED40F1@microsoft.com...
> user.
> macro
> selected?
M Forward email as insert from button Outlook VBA and Custom Forms 1
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
D How to forward each email x minutes after it arrives in inbox and hasn't been moved or deleted? Using Outlook 1
W Macro to forward email Outlook VBA and Custom Forms 2
mikecox Forward email to another address; not with Rules Using Outlook 3
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
D forward email with attachment using .oft Using Outlook 3
R Auto-create receipt from email and forward to payer Using Outlook 3
C Unable to forward email with URL Using Outlook 2
M rule to change subject, pull email addresses from body, and forward with templ Using Outlook 14
A Outlook 2010 - Want to Have All Email Reply Forward as Rich Test Using Outlook 7
P email arrows - respond and forward Using Outlook 1
J Rule to Forward email but delay delivery 10 minutes Outlook VBA and Custom Forms 2
S forward email Outlook VBA and Custom Forms 1
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
D Forward message to address from subject Outlook VBA and Custom Forms 1
J How to change From then forward message Outlook VBA and Custom Forms 1
S Reply & Forward Date in original message incorrect Using Outlook 2
Diane Poremsky Forward Messages that were not Replied To New Slipstick.com Articles 0
