Office 2010 Quick Steps
I
IMAPW
I am having problems trying to get the new Quick Steps to work in Outlook 2010. I am unable to get it to recognize e-mail addresses. When I try and set-up a " quick step" - for example like " To Manager" and I type in the e-mail address, hit " save" , nothing happens the screen doesn't change and no error message appears telling you what is wrong - you are forced to either " x" out or hit " cancel" and of course my changes are not saved. Other Quick Steps save fine (e.g. flagging) and I can save an e-mail one as long as there are no addresses in the " To" area - but it will save text and subject. Any ideas?
Ben M. Schorr [MVP]
If you type the address in the TO field are you clicking the " Check Names" box on the right-end to force it to validate/resolve the address first?
I
IMAPW
Yes I have clicked the " Check Names" box - and it appears to validate the address o.k.
I
IMAPW
I'm not sure what you mean by " type" of e-mail - it's my work e-mail. When I click the To button I get a " Address Book: Global Address List" - it was empty so I tried adding names to it to see if that would help, but it didn't help.
Roady [MVP]
I assume the Global Address List of your company should not be empty or is it (contact your mail admin if you do not know).
In that case it would appear that your Offline Address Book (OAB) is damaged or even your mail profile.
To force a reset on your OAB, delete all the oab-files when Outlook is closed from;
C:\Documents and Settings\%username%\Local Application Data\Microsoft\Outlook\Offline Address Books\<subfolder>
When you know start Outlook, it should redownload a fresh copy of the OAB again. Once done, try to create the Quick Step again.
If that doesn't work, try it with a new mail profile.
Robert Sparnaaij
I
IMAPW
I don't have an Offline Address Book. I do have more information from further testing. It appears that some e-mail addresses are working. The addresses that are not working are those that when I click the " check address" button the address changes to the name e.g. I type mmouse@disney.com andMickey Mouse comes up when I click the " Check Address" button - I thought that it was just recognizing the address as belonging to the person. The addresses that I'm able to save stay as the e-mail address. Any ideas?
what does your dialog look like?
This is the one for the bug => http://slipstick.me/jing/bug.png you will have this one with a pop account, possibly imap. (i only repro'd it with pop) when you add these addresses to the address list, you can't close the dialog. If you have an address shows in this address book (its windows address book) and type an address then try to resolve, it will change to the name shown in the address book.
this is the correct dialog=> http://slipstick.me/jing/notbug.png
Workaround - remove addresses from the windows address book (yeah, not always a good idea) then type the address in the To field. You can remove the address from the windows contact and paste it in the notes field of the contact until the outlook team fixes the problem.
I
IMAPW
My dialog is like the bug - however, I don't have any addresses in there.
juictifer
I got this to work. The problem seems to be the Global Address book, which you can't modify.
Close Outlook remove your ethernet cable or turn off your wifi. Open outlook and create your quick step. Add the emails addresses by typing or copying and pasting them. click save and plug the ethernet cable back in or turn wifi back on.
H Outlook 2010 & office 365 ...what a mess Using Outlook 1
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
P Outlook 2013 Office 2010 Hybrid Using Outlook 4
J Lost email categories when migrating from Office 2010 to Office 2013 Using Outlook 3
Commodore Office 2013 64-bit over 2010 32-bit Using Outlook 11
R BCM 2010 Problem with remote office (VPN) users cannot connect BCM (Business Contact Manager) 12
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
D Particular Facebook "Hyperlink" Issue In Office 2010 Outlook (32 bit) Using Outlook 5
D Will Outlook 2010 work with Office 2013 H&S that was preinstalled Using Outlook 2
B Trouble Locating Tools Menu since There's No Standard Toolbar in Office 2010 Using Outlook 1
H Reocurring outlook appointment (office 2010) does not update Outlook.com Using Outlook 3
B Outlook 2010 won't preview Office attachments Using Outlook 3
J Office + Outlook 2013 installed, but I need to install Outlook 2010 Using Outlook 2
G Office Profession Plus 2010 is not working for custom forms Using Outlook 3
K CPA - Office 2010 - 64 bit Questions Using Outlook 1
H Two accounts, Junk email filter only works on one account, office 2010, pop3 Using Outlook 5
B MS Office 2010: Word email merge not selecting default Outlook account Using Outlook 1
B Can't install Calendar Printing Assistant - Windows 7 64bit&Office 2010 32bit Using Outlook 2
G Transferring Office 2002 (XP) PST into Win7 (64) Office 2010 Using Outlook 1
C Outllook Migration - Office 200? - 2010 - Shared Mailbox Export-Bulk 500 users Using Outlook 1
D Outlook 2010 won't launch after installin Microsoft office 2010 service pack 1 Using Outlook 1
R MS Office 2010 repair and pst files Using Outlook 2
R Create a network PST file with office customization tool office 2010 Using Outlook 4
M Attempting to delete Exchange account in Office 2010 gives "primary account cannot be deleted" Using Outlook 8
I Pound Symbol in emails show as � (black diamond with white question mark inside) - Office 2010. Using Outlook 11
N Do I need outlook connector for office 2010 as with outlook 2007? Using Outlook.com accounts in Outlook 1
S RE: BCM won't open after installing Office 2010 Beta BCM (Business Contact Manager) 2
J BCM I w2007 and Office 2010 Professional Plus BCM (Business Contact Manager) 5
V Outlook 2021 Microsoft Office Pro Plus 2021 - Inexpensive Lifetime License Using Outlook 0
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
klpconsulting Programmatic Access Office 365 Pro Plus & RDS Using Outlook 1
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
L Ideas for Setup with New Office 365 Family Subscription (Outlook) Using Outlook.com accounts in Outlook 3
S office 2016 pop3 Using Outlook.com accounts in Outlook 3
A Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
A Out of Office Improvement Outlook VBA and Custom Forms 0
M Office 2016 Outlook is forgetting passwords Using Outlook 15
D Sending email from Office 365 alias in Outlook Using Outlook 3
J Office 365 erased all of my task views Using Outlook 3
P Categorize in Calendar not listed under tags in Office 365 (Office 2016) Using Outlook 5
