Problem With Tiny Text on Reply & Forward Outlook 2003____
bhansel
When I reply forward email, the recipient gets really tiny unreadable font. I've tried this but didn't work:
Tools> Options> Mail Format tab> under Stationery and Fonts click the Fonts button. Set the Font, color, size, etc. that you want under the Message fonts heading and then tick: Always use my fonts then OK, Apply and OK.
Any suggestions?
E
Ezil Vinoth
What is the font size displayed as in the new email window? If the font size doesn"t display correctly then set the zoom settings correctly as suggested by Brian. To increase the zoom settings try the following steps:
1. Open a new email window in Outlook
2. Click on the body of the message
3. Press and Hold the "Ctrl" key on the keyboard and scroll the mouse wheel forward or backwards to adjust the zoom
4. Restart Outlook to verify the status
DebbieAdams
Thank you so much! I have spent so much time trying to find out how to fix this.
B Problem with import Excel BCM (Business Contact Manager) 1
chupacabra Problem with IMAP .pst file Using Outlook 13
deonholt Address Book problem and created new profile ... Using Outlook 1
X Problem Transferring Subset of Outlook 2013 Contacts to iPad/iPhone Using Outlook 5
K Outlook(hotmail)Yahoo problem Using Outlook 6
