Outlook 2010 reading pane not clearing
shoe7400
when I delete a message it deletes from the inbox but stays in the reading pane untill I click drafts and then click inbox running pop3 reading pane to the right windows 7 ultimate
sunriseccsmn
This appears to be an unresolved bug with Outlook 2010. The only work-around I have found is to use conversation mode which I do not want. The other wro-around is to just change folders and return.Seymour
J Outlook 2010 reading pane option - want to permanently adjust the zoom setting. Using Outlook 13
A Outlook 2010 keeps closing and restarting when reading messages Using Outlook 12
