Pasting from Clipboard does not create attachment in Outlook 2007
MetalBender
I have a need to 'cut' to the clipboard an attachment created by a program and sent to an Outlook mail dialog, then close the diaglog box and 'paste' the attachment into another outbout mail dialog (cannot drag and drop because the first dialog box must be closed before you can access the second). In OUtlook 2003 I could do this and in the second dialog box it would automatically add the 'attachment' line andinsert the item from the clipboard.
In Outlook 2007 the item appears in the Office clipboard but cannot be pasted UNLESS I have first added another attachment using the insert file command (if another attachment already is in the mail dialog box, the cut and paste works fine). Cannot use cntl-V or the paste command from the clipboard. Am I missing a setting somewhere?
This appears to be unique to items that are 'temp' files (not saved). I can cut and paste a saved file and it works normally. However cannot cut and paste this 'temp' file without the intermediate step of having to save it. This worked in Outlook 2003/XP SP3 with no problem. Now using Outlook 2007/Win 7 64bit.
Is this a bug, intentional, a setting I need to change, or one of life's little mysteries?
N
Niyamath Khan
You can try steps to clear the tempaorary folder.
Click on Start>type %temp% and hit Enter.
Once the tempaorary folder is open delete all the temp files.
MetalBender
You cannot drag to a mail dialog box when another is opened through the 'send file' options. And SP2 is installed. In Office 2003 there was a prompt that asked if you wanted to save the clipboard contents for use elsewhere-just seems like I must be missing a setting in 2007 that will do the same prompt.
MetalBender
Did this. Did not make a difference.
In Outlook 2003 if you put stuff on the clipboard and then closed the email dialog, you would get a prompt that asked if you wanted to keep the clipboard contents. You do not get this message in 2007. Seems like perhaps there is a setting I am missing somewhere???
binkley13
MetalBender - Did you ever find a way to make this process work? I do (or did) this all the time - quite annoying that it's not working. Thanks.
N
Niraj Patel
I am having this issue as well. Is there a resolution to this or can someone from Microsoft chime in and confirm this is " known" functionality in Outlook 2007? (I am running 'SP2)
Brightner
Bumping this thread...
I would suggest you to post an new thread instead!
Diane Poremsky Pasting VBA code (and other editing) Outlook VBA and Custom Forms 4
O pasting text in body of calendar events Using Outlook 5
P Printing, pasting & deleting issues Using Outlook 4
B Font for rows and columns is changing in Outlook message when pasting data from Excel Using Outlook 1
B Font is changing in Outlook message when pasting rows and columns from Excel Using Outlook 2
M MS Outlook 2010, 2 questions, 1 about pasting and 1 about sending Using Outlook 1
W how do I control the font used when pasting text into an Outlook 2007 email message Using Outlook 3
J pasting in an email message Using Outlook 2
J Pasting into Outlook 2003 produces blue question mark Using Outlook 2
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
Diane Poremsky Paste clipboard contents using VBA New Slipstick.com Articles 0
F How can i copy the mail subject and the link to the mail to th clipboard? Outlook VBA and Custom Forms 3
R Outlook 2013 VBA I want to put the entire message to clipboard Using Outlook 5
V Screenshots / Clipboard images disappear after sending Using Outlook 3
M Clipboard Manager Not showing in Outlook 2010 on Start Using Outlook 8
I Clipboard paste in macro Using Outlook 14
D Problem with Microsoft Office 2010 Clipboard (Copy and Paste) Using Outlook 1
T Cut and paste problems - I copy from internet / word but info does not appear on clipboard, so I can Using Outlook 4
S ClipMate clipboard connection Outlook Wishlist 1
K How to copy Contact Item to Clipboard and Paste as "VCF Link? Outlook VBA and Custom Forms 4
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
D Outlook 2016: /altvba startup switch does not work Using Outlook 2
N Does a Shared Folder Policy override a Digital Signature Setting for macros? Outlook VBA and Custom Forms 6
E What does mean this icon at the picture attached? Using Outlook 2
LarryS change day template as cpao does not see .catx files Outlook VBA and Custom Forms 4
C Discovery search does not show autoforwarded messages Exchange Server Administration 1
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
