Dynamic Signatures? ( Hub Transport Rule? )
  • Thread starter Stephan - Swapper
  • Start date
Stephan - Swapper
Hey Everyone!
I can create an eMail signature no problem via a Hub Transport Rule, but what I'm really interested in is what, " Dynamic Signatures" has to offer... Reading this feature from Microsoft Exchange 2010 is a bit confusing, but maybe straight forward and I'm just not getting it, so to the question. Can you create a special Hub Transport Rule that will pull certain AD attributes such as Firstname, Lastname, Phone, Address, etc if these fields are populated in AD and append in an outgoing eMail? I'm playing with a new Hub Transport Rule that I named, " Signatures" , but when choosing the, " Condition" there are only two AD selections:
1) " if the AD Attribute evaluate with value"
2) " if the sender and recipient's AD Attribute are Evaluation"
selecting either of these there are actually some AD variables you can select from a list which has most of the AD attributes I would want in a signature but just can't figure out how to append that information. Maybe this is not the design of Dynamic Signatures?
Help??
Stephan
Brian Day MCITP [MVP]
Hi Stephen,
I can't remember what the case was way back when the beta was released, but I think (hopefully someone that *knows* chimes in) you might need to use a disclaimer rule and then variables like %%surname%% or %%department%% can be used to inject signatures. You can also use HTML coding as well to incorporate standardized colors and fonts.
-brianBrian Day / MCSA / CCNA, Exchange/AD geek.
Stephan - Swapper
Brian!!!
Awesome, this worked without a problem - thanks for the reply on this. I couldn't find the answer anywhere! Looks like Exch2010 actually has Macro's that tie into AD Attribute names becasue I can't just pull any readable attribute by name - just have to figure out if you can add more attributes to a custom macro, never-the-less, you nailed it. Check out my quick demo via a `Disclaimer Text` box:
<html>
<body>
Disclaimer Text via Hub Transport - Pulling AD Attributes
<br><br>
%%Firstname%% %%Lastname%% <br>
%%department%% <br>
Telephone: %%Phone%% <br>
%%Company%% <br>
%%Street%% <br>
%%City%%, %%State%%
</body>
</html>
TNX again -
Stephan
Exxxxxcellent. :)Brian Day / MCSA / CCNA, Exchange/AD geek.
Davidsima
Has anybody been able to figure out how to insert the email address from AD. Thanks
Seattle Mike
Thanks for the post, this is interesting stuff, but i couldn't get past a couple of " limitations" .
1. It appends to the end of the email only, not at the end of the newest comments.
2. It repeats over and over again with each reply.
Any thoughts or suggestions on getting past those issues? working the way it does, I don't find this to be all that slick of a feature, except for when the message is first sent...
MC
Mark Arnold [MVP]
The easy way to do (2) is to put an exception in that does not append the signature/disclaimer/message (whatever) that says " if this (blah) text appears in the message body, don't put the text in again" .
I can't think of a way to put your message in at the bottom of the reply (for example) rather than at the bottom of the message itself.
" Seattle Mike" wrote in message news:a1d61b50-2afd-40c5-a7f4-acb88dd5a7e5...
MCMark Arnold, Exchange MVP.
Brian Day MCITP
This is an old thread, what limitations are you referring to?Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
L
LANC3
I want to add a transport rule signature for certain users but I want it to function as if it were set in a client. Is there a way to do this without appending the signature at the end of the entire message chain?
Brian Day MCITP
Thank you for clarifying. No, there is currently no way to do that.Microsoft Premier Field Engineer, Exchange
Murdock Smith
@Brian
What do you say there is no way to do that? How about using the 3-rd party app suggested above? Will it do this? I mean I need personalized signatures for all users. Eg. I create one template for the entire company, with placeholders. Then no matter who sends a message, it will use only one template but replace placeholders with active directory data. Is this possible then?
cheers
M.D.W
Brian Day MCITP
@Brian
Hi Murdock,
Lance wanted to know if he could do this without the disclaimer being put at the very bottom of the message every time. Picture how Outlook doesit, it puts it at the top of your reply underneath the new text you're adding. With that particular requirement in mind, no it cannot do that.
For what you asked, yes you can use one template that pulls data from AD for all users. The caveat is it'll be placed at the bottom of the message, underneath any quoted data.
Murdock Smith
Hi Brian,
Thanks for clarifying. As far as Lance is concerned, I tested this app from codetwo and it works the way he needed. It can either stamp disclaimer at the very bottom of the message or just below your newest reply. you can set up the program to work that way - i think it can somehow recognize the header of the message you are replying to and insert your footer just above it - which (simultaneously) is just below your new message :)
cheers!
B Emacs Dynamic Abbrev Expansion, Esc-/ Using Outlook 1
Diane Poremsky Using Categories for Dynamic Distribution Lists New Slipstick.com Articles 0
J Dynamic date range for Outlook Search folders Using Outlook 2
N Creating dynamic forms in outlook?? Using Outlook 2
T Max Recipent or maybe bad dynamic dist list Exchange Server Administration 2
R Dynamic DNS update requirement for Exchange 2010 (SP1 RU1) on server 2008 r2 Exchange Server Administration 8
A Dynamic Distribution Groups... Using Department OR Custom attribute... Exchange Server Administration 3
K remove 1 moderator from moderated dynamic DL Exchange Server Administration 2
T Dynamic Distribution Groups Do Not Show UP in GAL Exchange Server Administration 18
R Create addresbook with normal and dynamic distribution groups Exchange Server Administration 1
J Dynamic fields on forms Outlook VBA and Custom Forms 5
A Multiple signatures Using Outlook 2
L Can signatures synch to Office Portal Using Outlook 1
R Outlook signatures depending on domain Using Outlook 2
J Signatures that contain recipient's email address Outlook VBA and Custom Forms 7
Mark Foley Outlook multi-spacing Thunderbird signatures when replying Using Outlook 0
Diane Poremsky Image Quality in Signatures New Slipstick.com Articles 0
C Quick Parts signatures suddenly require more letters Using Outlook 2
C Signatures in HTML emails Using Outlook 5
R 2 email accounts, only 1 gets signatures added on new email. Using Outlook 1
L Oultlook 2007 Signatures Using Outlook 28
P Changing all email signatures (font, color) at once in outlook 2007 Using Outlook 2
V Plain Text Signatures Using Outlook 3
V Signatures in Outlook 2013 Using Outlook 1
J Outlook 2010 - Stationery with signatures Using Outlook 1
J Managing signatures and disclaimers with digitally signed emails Exchange Server Administration 3
B OL2010 - signatures while forwarding tasks or appointments Using Outlook 2
A Signatures problem Using Outlook 1
S Using Multiple Signatures in Outlook 2010 Using Outlook 9
S Email signatures Outlook 2011 Using Outlook 7
G Outlook 2003 cannot set unique email signatures for multiple profiles and accounts. Using Outlook 1
B Outlook 2010 Mail Options - Editor, Spelling, Signatures & Stationery not accessible Using Outlook 1
M Problems with multiple signatures for multiple email accounts Using Outlook 1
P Email signatures in Outlook do not match? Using Outlook 3
K Signatures Using Outlook 1
M Outlook 2010 deletes my email when inserting signatures Using Outlook 2
L Custom OWA Email Signatures Exchange Server Administration 9
L not able to access signatures to modify, add, or edit. Using Outlook 1
S Re: Cannot access signatures in Outlook 2007. Cannot edit existing one or and a new one. Using Outlook 1
B Re: Cannot access signatures in Outlook 2007. Cannot edit existing one or and a new one. Using Outlook 1
I OWA Multiple Signatures on Outlook 2007 or 2010?? Using Outlook 2
A Spelling doesn't work when I edit Signatures within outlook or word, office 2007 Using Outlook 5
G Re: Outlook 2010 - Unable to edit signatures or stationary 7 fonts Using Outlook 1
V Outlook 2010: Options: Mail: Signatures does not work Using Outlook 20
T Outlook Signatures come out blurry on sent messages Using Outlook 9
F Signatures in incoming messages Outlook VBA and Custom Forms 1
W Using signatures with Outlook templates Using Outlook 15
N separate signatures for different accounts Outlook VBA and Custom Forms 6
