Exchange 2010 CAS high availibility cross datacenters
Ruben van Gogh
Hiya,
a collegue of mine asked a question about the 'new' high availibility functions in Exchange 2010 cross datacenters.
As we talked about the flexibility of DAG, which is a great aprovement for cross-datacenter availibility since Exchange 2007 because its nolonger restricted to a single Active Directory site, we started wondering about the availibility options for the CAS server roles.
Ofcourse, CAS can be deployed in a NLB configuration, but this will function IN a single site only.
For the sake of argument lets say I have datacenter A and B, where A is the active datacenter. For this sample, lets state that I _wont_ use NLB for the CAS roles in each site.
I deploy Mailbox Role A (MBX_A) in datacenter A and Mailbox Role B (MBX_B) in Datacenter B.
Then I deploy CAS role A (CAS_A) in datacenter A and CAS role B (CAS_B) in Datacenter B.
In case of a failure of MBX_A it fails over to MBX_B and CAS_A will point to MBX_B.
But what happends if CAS_A fails? How will the clients get to CAS_B in the other datacenter?
Regards,
Ruben
L
Lee c y
I am not entirely sure of the official solution, but this is based on my own understanding.
Create a CAS array in Exchange, for eg. Cassarray1. This should usually point to the NLB cluster host name, but since there is no "real" NLBed CAS, just manually enter the A record of the Casarray1 and configure it with the IP of CAS_A. Set the TTL of this record to 5 mins.
Configure all DB in Datacenter A to have RPCclientaccessserver set to Casarry1.
If there is a failover to Datacenter B. Manually modify the A record of Casarry1 and configure it to point to the IP of CAS_B.
If assuming the all the databases failover sucessfully to MBX_B. The client should get re-connected automatically, but there is a longer delay and the process is triggered manually.
Ruben van Gogh
thanks for your reply, but I already figured that one out..  itis not an automatic failover like DAG does.. So in my opinion its not only the nonofficial solution, but its not even a solution :)
Regards,
Ruben
L
Lee c y
Regards,
Ruben
In almost all cases, customers do not want automatic failover across datacenter. It is too risky.
The SLA for datacenter failure is usually higher than in site ones.
I suspect when MS releases the official guidance for cross site failover, it would also recommend a manual process.
From this link http://technet.microsoft.com/en-us/library/dd351049(EXCHG.140).aspx
"A datacenter or site failure is managed differently from the typical failures that cause server or database failover. In a high availability configuration, automatic recovery is initiated by the system, and the failure typically leaves the messaging system in a fully functional state. By contrast, a datacenter failure is considered to be a disaster recovery event, and as such, recovery must be manually performed and completed in order for the client service to be restored, and for the outage to end. As with many disaster recovery scenarios, prior planning and preparation can simplify the recovery process and reduce the duration of the outage.
By combining the built-in site failover support in Microsoft Exchange Server 2010 with your proper planning, a second datacenter can be rapidly activated to serve the failed datacenter's clients. The proper planning and preparation involves not only the deployment of the second datacenter resources, but also pre-configuration of those resources to minimize the changes required at datacenter failover time."
Cheers
Ruben van Gogh
I dont agree with you on that one.
Especially when I look at the DAC functions MS has built for DAG to prevent split-brain scenario's - which tend to happen in automatic fail-overs.
I'm surprised to see that noone from MSFT has responded to this thread yet.
Regards,
Ruben
L
Lee c y
Sorry all the acronyms are getting to me, I know what is the split-brain senario, but what is "DAC functions"?
Ruben van Gogh
oops, typo. its "function", not "functions".
DAC stands for datacenter activation coordination. This was developped to prevent split brain scenario's in datacenter failovers. Which is an automated proces. Therefor, I dont believe that MSFT's statement in datacenter failovers is: automatic is too risky.
L
Lee c y
Ok now I remember what is DAC. Even with DAC, the whole Datacenter switchover is a manual process.
First DAC needs to be manually enabled if your DAG contain 3 or more servers.
Let's say the senario is datacenter A has 2 DAG servers and datacenter B has a single DAG server, if there is a power outage in datacenter A, by default datacenter B server will not mount the database until a majority of member in the DAG is online. This is to prevent a split brain senario, since there is a possiblity that an admin has triggered a recovery on datacenter B and suddenly datacenter A power resume, both side will "think" that they own the acitive copy of the databse.
By turning on DAC, you can mount a database even if there is no majority number of DAG members online. So in the above example, an admin can initiate a recovery in datacenter B. If however datacenter A power resumes, the servers in datacenter A will not mount the database even if it has majority. The PAM will corordinate with the SAM check if current state of the DAG before monnting any databases, so that split brain senarios can be prevented.
In summary, the presence of DAC does not imply that automatic failover across datacenter is possible, but it is a mechanisim to prevent split brain in certain datacetner switchover (manual) senarios.
Cheers
Brian Day MCITP [MVP]
You're forgetting about Autodiscover.
If you have a cross-datacenter failure then you can do a couple things that I know of.
1. Leave the RPCCLientAcessServer attribute alone on the databases and repoint the CASArray A-record to the IP of the CAS-B. As long as the TTL is low this should get things going soon.
2. Modify the RPCClientAccessServer attribute on the DB to point to CAS-B and Autodiscover capable clients will learn the new endpoint.
Datacenter failovers as mentioned in other replies are typically *not* a great thing to have done automatically and as long as you have an HA solution for CAS in place in Site-A then you'll be ok. :)
-bBrian Day / MCSA / CCNA, Exchange/AD geek.
N
Nadim J
Sorry if I'm being dense here but am I the only one who thinks that Ruben van Gough's original question was never answered fully?
I have to design a solution for a 2,000 user company that absolutely cannot have any Single Point of Failures (SPoF). The marketing around DAG is great until you realise you have the slight problem of making your CAS servers reslilient, ordinarility taken care of by using a CAS Array and NLB. However correct me if I'm wrong, a CAS array can only encompass CAS servers from the same AD site. This leaves me with a bit of a problem....(Our setup is the end goal of most organisations I have dealt with over the last 5 years. That is to move to a dual datacentre setup with no SPoF)
The environment:
-12 AD sites with 2,000 users spread across all (10 user sites, 2 datacentres)
-Datacentres (DC1 and DC2) will hold 1 mailbox server each (MBX1 and MBX2). Each mailbox server to handle 50% of the total AD (user) sites
-A third mailbox server held at Site1 (specifically to avoid using a FSW (another SPoF), a 3 node DAG enables you to use node majority only)
If I take users from Site1, who are ordinarility connected to a CAS server at their local site inturn connected to MBX1 (no point in putting CAS servers in DC1 as a failure of comms between SiteA and DC1 will result in users not being automatically redirected to MBX2), the only way I can get their Outlook clients to resume connectivity to DC1 in the event of the local CAS going down is to create more than one CAS in an array. Due to the CAS Array limitation (inter-site only), I need to have a total of 10 CAS arrays across all user sites containing a minimum of 2 CAS servers each just to address my problem. If I could create a CAS Array encompassing CAS servers from multiple sites I'd be sorted. Another reason why this limitation is awkward to work with is that like most orgs we are heavily reliant on VMWare/Hyper-V. Two CAS servers in an array on the same VMWare platform doesn't give us the best resiliency either, due to dependency on the same single SAN!
Clearly it's impractical and costly to have 20 CAS servers for a 2,000 user org. My question therefore is, is there anyway to configure CAS Arrays to achieve cross-site failover for Client Access as well as for mailbox servers?
D Exchange 2010 CAS at 2 different Sites Exchange Server Administration 2
S Any system impact if change exchange 2010 CAS/HUB and Mailbox server IP address Exchange Server Administration 1
B Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 15
M Re: Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 2
I Exchange 2007 and CAS from Exchange 2010 problem Exchange Server Administration 4
Diane Poremsky Organizational Forms Library in Exchange 2010 New Slipstick.com Articles 0
V Recover exchange 2010 edb Exchange Server Administration 2
T Renaming an Resource in Exchange 2010 Exchange Server Administration 1
P Outlook 2010 MS Exchange Calendar to Android- ical or webdav? Using Outlook 1
Fozzie Bear Outlook 2010 or 2013 Dual Configuration Exchange + IMAP Exchange Server Administration 6
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
N Outlook 2010 exchange - auto-move emails from @domain Exchange Server Administration 1
V Outlook 2013 cant stay connected to exchange 2010 Exchange Server Administration 5
R Exchange 2013/Outlook 2010 Slow Startups Exchange Server Administration 8
Z Outlook 2010 client to Exchange ,,,,search not working proparly Exchange Server Administration 0
M First post -help with managing two calendars Outlook 2010 /Exchange 2010 Using Outlook 0
T Outlook INBOX emails gone back 2-3 weeks after Exchange Server 2010 Restart Using Outlook 0
C Outlook 2010, two exchange mailboxes configured.Unable to see 2ndrymeeting req Using Outlook 2
C Exchange 2010 / Emails received show with display name and not email address Using Outlook 2
S Unable to send or reeceive email in new Exchange 2010 Exchange Server Administration 0
B Sharing Multiple Outlook 2010 Calendars (Exchange) Exchange Server Administration 4
P can't set IRM configuration in Exchange 2010 Exchange Server Administration 2
B Using hosted exchange to sync outlook 2010 calendars and contacts to BB Z10 Using Outlook 4
S Outlook 2010/Exchange 2010 Multi Mailboxes (Server unavailable) Using Outlook 6
D why do exchange contacts not sync properly from outlook 2011 to outlook 2010 Exchange Server Administration 2
J Exchange 2010 free/busy shows hashmarks in scheduling tab when not organizer Exchange Server Administration 6
C Exchange 2010 - Outlook 2010 - Exchange Server Administration 4
Fozzie Bear Outlook 2010 wont remember Exchange Credentials on log off /shutdown of Win7 Exchange Server Administration 2
T Exchange 2010: 'could not save item' and 'Unknown error' when edit calendars Exchange Server Administration 1
I Shared Contacts in Outlook 2010 and Exchange Server 2010 Using Outlook 4
J OL2003 Public Folder Sync Errors w/ Exchange 2010 Exchange Server Administration 11
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R Thousand of sync issues on Outlook clients with Exchange 2010 Exchange Server Administration 5
