not able to change password by EX2010 OWA for few user's
Anand Sunka
Hi All,
Facing some strange issues with password change in OWA for few user's. I can login into the OWA successfully but when I click on option link, it will throw me out of OWA.
Any help really appreciated
Regards
Anand S
MMHussain
Have you checked the Internet Explorer Security Settings ?
Is there any error message you are getting ?
Mhussain
Thanks Mhussain
Thiyagu14
Hi Anand,
Did you recreate the OWA & ECP directories?
What type of authentication is set on those virtual directories, ECP uses integrated & forms based?
. This posting is provided " AS IS" with no warranties, and confers no rights.
Anand Sunka
Hi Thanks 4r reply. Error message is " The password you entered doesn't meet the minimum security requirements."
I have 1 remote location they used to access thier mails by OA & POP, If any one wants to change their password how they change?
Regards
Anand S
Anand Sunka
Hi Thanks 4r reply.
Authentication is Forms-Based on OWA & for POP/IMAP4 is Plain text logon.
Regards
Anand S
Thiyagu14
Hi Anand,
Error looks like the password did not a meet a the required complexity.
Please try a complex password like alphanumeric characters with both upper and lower cases and 10 or 12 characters length.
Give that a try?
F
Frank.Wang
Hi Anand,
How about your question? Any updates?
Do you mean the user in the romote location cannot change password?
If their computers are logging on to domain, can they change windows password?
Frank Wang
JimRobinson
I am having the same issues with OWA 2010. Cannot change users passwords through OWA interface - error " password does not meet complexity requirements"
I have tried several dozen strong passwords through OWA and get error every time. Recently installed Ex2010 RU4 - no change.
If i use the same password through AD snap in - it works, but cannot set pass in OWA.
Our users do not have domain member machines, and access OWA from remote locations. It is not possible to have them ctr-alt-del to change passwords.
Please advise if there is a fix for this bug. This is a major issue for our users.
MoRdAcK
have you tried to change password complexity in GPO (user security settings)?
JimRobinson
My GPO settings for the domain are;
Account Policies/Password Policy
Policy Setting Enforce password history 24 passwords remembered Maximum password age 90 days Minimum password age 1 days Minimum password length 7 characters Password must meet complexity requirements Enabled Store passwords using reversible encryption Disabled
I believe this is supposed to work through OWA. Disabling password complexity is not an option either. Any idea how to fix this?
F
Frank.Wang
Hi Anand,
Any updates?
Jim,
Could you please check the Local Security Policy on which you installed Exchange 2010?
Frank Wang
JimRobinson
Frank,
It's a single Ex2010 box (mbx,cas,ht), in a 2008 domain. Local security settings on the Ex2010 box are (effective);
Policy Security Setting
I have actually relaxed the default 2008 domain/server posture which sets 42 day expiration.
Jim
Anand Sunka
Hi Frank,
Sorry 4r delayed in reply due to some IT issues. I tried changing the password within the network, it works fine but when my remote location people tried to change the password through OWA it never works untill unless I change the option in account properties to " user must change the password in next logon"
Its a very strange issue I am facing whenever my remote location people wants to change the password then I need to set option in account properties to " user must change the password in next logon"
Regards
Anand S
JimRobinson
Frank,
I am not setting 'user must change password at next login' option. If i set 'user must change password at next login', the users cannot login to OWA at all.
Once the user is logged into OWA, if they try to change thir passwords, it is stil reporting 'does not meet complexity requirements'.
Jim
Anand Sunka
Hi Jim,
Even I also faced same issue, b4r u login into OWA just uncheck the option of 'user must change password at next login', then u can login into OWA. Once u login u check the option of 'user must change password at next login' for that user. U log off then u login into OWA & now u can change the pasword. In this period of time your microsoft outlook shud be closed, if u access ur emails by Outlook Anywhere.
By doing above steps my issue has been resolved for time being but this is not a proper way which i think.
Hello Frank I hope u got it my issue.
Regards
Anand S
P
Patrick Hoban
I'm seeing this behavior as well. The trick with logging in then logging out then checking the box then logging in does work. Seems like a bug though.
Brian Day MCITP
In SP1 this should not be necessary if you enable the new PW feature (the same on Exchange 2007 SP3 has).
To enable the password reset feature;
1. Log on to the Exchange server(s) running the CAS role by using an account that has local administrator rights.
2. Start Registry Editor, and then locate the following registry subkey:
HLKM\SYSTEM\CurrentControlSet\Services\MSExchange OWA
3. Create the following DWORD value if it does not already exist:
Value name: ChangeExpiredPasswordEnabled
Value type: REG_DWORD
Value data: 1
4. Exit Registry Editor.
Here is the 2007 SP3 page, but the same intructions apply to 2010 SP1.
http://technet.microsoft.com/en-us/library/ff607232(EXCHG.80).aspx
Microsoft Premier Field Engineer, Exchange
MCSA 2000/2003, CCNA
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
Fozzie Bear Wishlist To be able to add a local folder or network share location in foldern view Outlook Wishlist 1
L Outlook 2010- Be able to move default Mail folders (Outbox, Draft, etc) Outlook Wishlist 1
P Not able to receive meeting request Using Outlook 2
G Not able to send ANY emails due to a blocked list Using Outlook 2
D No longer able to Archive Outlook 2007 Using Outlook 1
N Not able to receive daily emails. Using Outlook 3
S I'm not able to copy and paste on outlook. Using Outlook 1
T Have to type in login to OWA twice before able to login Using Outlook 17
M Outlook Anywhere is not showing freebusy informayion and User not able to open shared calender while Using Outlook 1
R No problems for about three months and the, about two weeks ago I was no longer able to receive emails in Outlook. Using Outlook 4
D Not able to retrieve my emails or get to my contacts using outlook. Using Outlook 3
K Sending email in Outlook - being able to choose... Using Outlook 1
S Suddenly I am not able to send e-mail but can receive. We use Windows7 and Outlook has been working for about a year. Using Outlook 2
E 554 message not allowed [320] I am able to receive emails from these contacts but when i reply i get this error code. It is from contacts that i have Using Outlook 1
G Not able to accept meeting with outlook 2010 Using Outlook 0
J DAG problem - I´m not able to recover database Exchange Server Administration 9
G Not able to accept meeting with outlook 2010 Using Outlook 1
A error 2147504141 -I am not able to fix this error even after attepmting all IPv6 related sloution. Exchange Server Administration 3
D I am able to send emails on Outlook, but unable to retrieve emails trying to come in. Using Outlook 1
A Not able to search by last name in GAL Exchange Server Administration 3
D Not able to send mails through MS Outlook 2007 Using Outlook 3
S Not able to establish Outlook on Windows server, office email, yahoo account Using Outlook 1
D I would like to be able to Forward a Template to a specified email address on receiving an email in the Inbox. Using Outlook 1
H Not able to get messages forwarded from my road runner account. Using Outlook 2
B Switching Access from version 2010 to 2007 or 2003 causes Outlook to no longer be able to send or receive email. Using Outlook 2
S How do I set up more than 1 email account for Outlook 2007. Have recently purchased a laptop and want to be able to check all emails that come into t Using Outlook 2
M Not able to select my contacts list for my address book Using Outlook 7
M Need to copy old PST file from CD into Outlook so as to be able to open and view the old documents. Using Outlook 7
A SCOM 2007 R2 not able to see Exchange 2010 mailbox server Exchange Server Administration 4
S Not able to open webmail inbox. Using Outlook 2
S Me and my big mouth...I said to my customer a district nursing organization down here in New Zealand, that 2 ipaqs should be able to share the same Co Using Outlook 1
T Need to be able to check my microsoft outlook emails via my blackberry Using Outlook 1
O owa was not able to process this request Using Outlook 3
M not able to recieve Internal and external email on a 2010 mailbox... attempting exch 2003 transition Exchange Server Administration 2
S Unable to send emails through outlook, but able to recieve emails Using Outlook 2
L I was able to password protect attachments in my earlier version of Outlook, but can't figure out ho Using Outlook 1
A not able to find Contacts when writing new email, even clicked the Searh Name button.__Try to set the address list or book, but nothing listed in the Using Outlook 1
L not able to access signatures to modify, add, or edit. Using Outlook 1
D I am not able to send emails from outlook 2003 Using Outlook 2
N Not able to select the details of a head office synced contact Exchange Server Administration 4
J Add a meeting / appointment to my Calendar without emailing the other person (like I was able to do Using Outlook 3
G SP1 upgrade fails in Install-MailboxRole due to not being able to resolve Discovery Management group Exchange Server Administration 28
A Not able to load an add-in for outlook 2007 developed in VSTO 2005 Outlook VBA and Custom Forms 2
M Unable able to initialize Exchange management (EMC and EMS don't work) - Access Denied Exchange Server Administration 16
Z Exchange 2010 OWA and outlook 2003 not able to access from terminal server after redoing the database. Exchange Server Administration 6
A When I log out of Outlook. The icon on the taskbar is greyed out and I am not able to activate/launch Outlook unless I reboot my PC. I have XP and am Using Outlook 2
