Prevent clients outlook anywhere URL from being changed by autodiscover?
C
Corey Riley
We host several different domains with connection points at different data centers. Our corporate office contains a majority of the Outlook Anywhere users and are set to use a specific URL for Outlook Anywhere. This part works fine. I have smaller groups of users that I need to configure to connect through a different external URL. They can connect fine, then the autodiscover service changes the URL to the one for the corporate office. I found this blog post about removing the EXPR Outlook Provider. http://ilantz.wordpress.com/2009/06/18/prevent-outlook-anywhere-aka-rpc-over-http-from-being-automaticly-configured-in-exchange-2007-with-autodiscover/
Is this the only way to achieve this? I'm not worried about the Outlook Anywhere settings being automatically configured on clients. I'd actually rather have it not configured on a client by default and make it a manual process to enable it.
E
Ed Crowley [MVP]
You can override settings made by Autodiscover. The way I understand it, the only time Autodiscover comes into the picture is when a user creates a new profile. The user can choose to enter everything manually.
Ed Crowley MVP
" There are seldom good technological solutions to behavioral problems."
" Corey Riley" wrote in message news:b282dbdd-9a6c-47d2-a5cf-2c2bc14308cf...
Ed Crowley MVP " There are seldom good technological solutions to behavioral problems."
I
Ilantz
The " outlook provider" settings should be overwritten once the TTL of it respective provider ends... that's why the settings keeps " coming back" ..
Glad my post helped ya out :)
Ilantz
C
Corey Riley
Yes I'm seeing that behavior. Once the settings are changed, the user changes them back. Everything is great and then all of a sudden, the URL changes back again. It's quite annoying. I guess I'll go through and make the changes to the provider since there doesn't seem to be any other way to acomplish this. Thanks for the article Ilantz!
Brian-Z
Corey,
I am having the same problem as you.
Did you try to Ilantz's solution? Does it work for you?
What is the best way to do a backup for current EXPR?
O How to prevent CC from showing when creating a new mail? Using Outlook 1
L OL 2016 contact: is there a way to prevent an admin from mistakenly deleting a contact? Using Outlook 1
D Multiple mailboxes, 1 certificate. How to prevent message "Invalid Certificate" Using Outlook 0
S How to prevent addins Using Outlook 0
Diane Poremsky Prevent Users From Choosing Stationery New Slipstick.com Articles 0
evdbogaard How to prevent extra line feeds in replies Using Outlook 3
oliv- Prevent copying shared contacts Outlook VBA and Custom Forms 5
oj43085 Prevent Outlook from blocking image from a single source Using Outlook 4
I How to prevent exchange email account from sending emails in Outlook Using Outlook 4
D Prevent Outlook from resolving incomplete contact when clicking send Using Outlook 2
K Prevent meeting requests being sent from a shared calendar in a group mailbox Using Outlook 1
N Prevent reminder dismisal in shared calendar Using Outlook 1
C Security Question - How to prevent users exporting .iaf files Using Outlook 5
B Item_Write = False don't prevent custom form from closing Using Outlook 1
N Allow Another User to Send on Behalf of But Prevent Access to Inbox Using Outlook 4
R Exchange 2010 archive-prevent users moving items direct to archive Exchange Server Administration 1
M Links prevent sending email Using Outlook 3
S How to Prevent of using CC field Using Outlook 1
D Received emails show only red X's no images - Email set for HTML. Prevent download of images is OFF Using Outlook 6
D Images showing up as X's in Outlook 2003 emails. Outlook is set to HTML and Prevent Picture downloa Using Outlook 2
V Prevent appointments not yet accepted from showing up in Calendars Using Outlook 3
B Prevent changing of appointment time or date by other users Using Outlook 1
B how do you prevent email adressess from popping when sending a new email Using Outlook 1
J When I try to click on a link embedded in an email I get an error that says that computer restrictions prevent access. Call the system administrator Using Outlook 1
E Prevent Looping Message using transport rule Exchange Server Administration 4
G Prevent Changes in text of Original e-mail Using Outlook 1
A Prevent "forwarding" with the meeting invite Using Outlook 1
G Prevent my AT&T email from being imported into Outlook 2003 when I open outlook. Using Outlook 1
M How can I prevent calendar items from appearing conversation threads in my Inbox? Using Outlook 3
G How do I prevent the Outlook 2010 Reminder window from staying on top of other windows after clickin Using Outlook 5
U Prevent mailbox owner delegating access Exchange Server Administration 2
T Prevent Task Accepted and task update messages from deleting in Task OL2007 inbox. (I received a task update message in my Inbox, but it disappeared.) Using Outlook 7
L Prevent Exchange from becoming default account on Windows 7 Using Outlook 5
K How to prevent that Outlook is sending before my add-in is finished? Outlook VBA and Custom Forms 5
K Prevent sending Excel files as attachements Outlook VBA and Custom Forms 1
C Prevent Outlook from sending an email with a blank Subject Line Outlook VBA and Custom Forms 3
A Script to either modify "from" address or prevent a reply being se Outlook VBA and Custom Forms 2
J prevent user from installing wrong version of add-in Outlook VBA and Custom Forms 2
Z Prevent Changes to Custom Form Outlook VBA and Custom Forms 1
norbertlars Exchange 2007 - quota not shown in clients Exchange Server Administration 2
P Newly created IMAP subfolders not showing up on email clients away from computer. Using Outlook 3
blashmet Outlook Signature Distorted in Other Email Clients Using Outlook 9
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
