Problems with end times not showing up on printed monthly calendar
Adam M. Ray
Several days ago, I noticed that whenever I print a montly calendar the end times of appointments disappeared. They appear on my screen view of the monthly calendar. I have not made any setting changes nor changed anything about my system (Microsoft Office 2007, running under Windows 7), they just disappeared on their own. I even checked and unchecked the "Show end time box" (View-->Current View-->Customize Current View-->Other Settings) to see if that would help but it doesn't (it does cause them to appear or disappear on the screen view of the calendar, so it appears to be working properly). I have tried changing the print font as well (which does seem to work) but the end times still do not print on the monthly calendar view.
Any help would be much appreciated.
Adam M. Ray
I use Landscape (just like I always have been). I have always adjusted the appointments font to be small (5 pt Segoe UI) to ensure that there is enough space.
americancurl
It used to work fine, but recently it's disappeared. I've been trying all forums, checked on colleagues' machines etc. Some work, mostly don't. The older version seems to work just fine. Microsoft Office just got more complicated. Things were simpler on the oder version.
Hmm. I thought i found all the threads about this and updated them when we discovered the cause is the July updates. The end time is missing and words break weird. The august hotfix repairs word wrap in the printouts, but not the end times. A future update, possibly as early as october, will address the end times.
Details on the July update: http://www.slipstick.com/emo/2010/up100805.htm#1 - uninstall the MS10-045 update and you'll have the end times back.
August hotfix: http://www.slipstick.com/emo/2010/up100902.htm#2
C problems Using Outlook 1
P outlook.com problems Using Outlook 0
