Auto forwarded emails don't contain email body......help!
KOTULCN
I created a rule to forward all of my incoming email in outlook 2010 but the forwarded emails only show the To/From and subject but the body of the email is not sent. I have tried deleting the rule and redoing it but nothing fixes it. I just upgraded from OffIce 2007 and I never had this issue before the upgrade. I have searched online but have not found any answers. Anyone have any ideas how I can fix this?
KOTULCN
Are the bodies missing from the copy in Sent items?
(I assume its a bug but will check with my contacts).
Actually NO the email body is not in the sent item! I went back through the rule but everything is the way it should be! Any ideas on why it is like that?
The last i heard they were trying to repro. Even if they did repro, it would be at least Oct (probably ever later) before it would be updated.
KOTULCN
Just curious if there was any update! I amactually really thinking about uninstalling the program and going back to 2007!
No, i haven't heard any thing more about it. They don't usually tell me anything until its ready to be released.
Was there ever an answer to this? I have just installed outlook 2010 and have exactly the same issue. The email body is missing when "forwarding all" messages via a rule. Has it been able to be replicated?
B Outlook 2010 auto-forward deletes message text from forwarded email Using Outlook 7
B Outlook 2016 Auto-archive creates new folder Using Outlook 4
P [SOLVED] Auto remove [EXTERNAL] from subject Using Outlook 10
B Auto open PDF Outlook VBA and Custom Forms 0
J Auto Accept Notifications from a shared icloud calendar? Using Outlook 4
