Outlook 2010 Setting to Prompt 'Send before Exiting'__
TheMinkx
Prior versions would notifiy me that I have email messages in my outbox before exiting the app. I do not want messages sent immediately. So I have that setting Off. I do not want to leave Outlook when messages are still waiting in the Outbox to be sent. That setting in 2007 worked, but I cannot locate it in Outlook 2010.
Thanks for your assistance,
Marc
N
Niranjan I K
Try the following steps:
l Open Outlook 2010 > press and hold Ctrl + Alt + S
l In the Send/Receive Groups window check the check box which reads as "Perform an automatic send/receive when exiting."
l Close the window to apply the setting and then restart Outlook.
TheMinkx
Niranjan,
That's not what I asked for. I think I was clear about the process I need. I know how to accomplish what you have described.
In prior versions Outlook would prompt me that I have messages waiting to be sent before exiting. 2010 seems to have done away with this feature.
Marc
S Setting up Outlook 2010 to work with custom domain outlook.com account BCM (Business Contact Manager) 3
J Outlook 2010 - email address disappears when setting up new contact Using Outlook 0
M setting up 2 separate businesses in Outlook 2010 Using Outlook 2
D Outlook 2010 - email address disappears when setting up new contact Using Outlook 3
P How to reset stand alone Outlook 2010 so no account/setting - back to defaults Using Outlook 2
L Cannot change my setting on Microsoft Outlook 2010 from IMAP to POP. Using Outlook 1
U Outlook 2010 - Mail: setting to show email address with sender name? Calendar: decline attendance w/ Using Outlook 2
A Creating personal folders on outlook 2010 and setting properties. Using Outlook 3
M SMTP times out when setting up an account in outlook 2010? Using Outlook 2
A Problem Setting up Outlook Anywhere for Exchange 2010 Exchange Server Administration 17
J Outlook 2010- Emails deleted off POP server even though setting it set to leave them Using Outlook 6
K will I loose Outlook Express setting if I change from Office Professional 2007 to Office Professional Plus 2010 Using Outlook 1
L Problem setting up Outlook Email 2010 Using Outlook 1
E Setting up an Email Address in Outlook 2010 Using Outlook 2
C My Outlook 2010 'connection setting' are lost every time I restart outlook Using Outlook 1
P AutoArchiving setting in MS outlook 2003, 2007 & 2010 Using Outlook 1
J Outlook 2010 reading pane option - want to permanently adjust the zoom setting. Using Outlook 13
A Setting up Outlook 2010 with exchange server Using Outlook 1
C setting up outlook 2010 Using Outlook 1
J Outlook 2010: Send from setting Using Outlook 4
S Is there a configuration or setting in Outlook (2007 or 2010) that allows users to rename "shared" c Using Outlook 3
T Setting Closest GC value per KB 319206 in Outlook 2010... can it be done? Using Outlook 1
L Setting up multiple email accounts on Outlook 2010 Using Outlook 5
S Having trouble setting up different email accounts in Outlook 2010. Using Outlook 3
J Outlook 2010 - Setting default account to create new email Using Outlook 3
T Why does outlook 2010 convert only some forum notifications to plain text? Using Outlook 2
